Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44612
09/28/07 08:25 PM
09/28/07 08:25 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Just a little for what it's worth stuff that applies to a lot of older iron and specifically to the 37 Dodge Pickups.
The VIN is only stamped in one location on these trucks (the front of the drivers side frame rail). Basically a frame or front clip swap will result in the removal of the VIN, rendering the title worthless . What I would suggest PRIOR to taking the truck apart is to check with the DMV and find out what will be required to title/register the car after it has been built.
It can be a royal pain to get the DMV stuff straightened out, but it's a lot better to do it before you put a bunch of time and or money into it and find out you have title problems.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Grampa's 1937 Dodge Truck [Re: Mike P] #44613
09/28/07 09:09 PM
09/28/07 09:09 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Thats a keeper
soon, it will be under 6 foot of snow !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Grampa's 1937 Dodge Truck [Re: bigdad] #44614
09/30/07 04:08 PM
09/30/07 04:08 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
What year did he get it stuck in the mud?
Re: Grampa's 1937 Dodge Truck [Re: Mike P] #44615
10/01/07 09:19 AM
10/01/07 09:19 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
MikeP, your truck is just killer!
Moparlee
Re: Grampa's 1937 Dodge Truck [Re: camdog440] #44616
10/01/07 04:21 PM
10/01/07 04:21 PM
Minnesota
PocketThunder Offline OP
Minnesota
The tree that grew up between the tailgate and the chain that holds the gate to the box has already died. I think it was parked there in the 60's. I'll have to ask.
69 Charger R/T. California car, 99 99 Special Order paint car, Omaha Orange. Original Paint, Interior, drivetrain, etc..
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44617
10/09/07 09:53 AM
10/09/07 09:53 AM
dogdays Offline
dogdays  Offline
I'd say keep the original frame and get all the other stuff done, then see if you want to Dak frame it. I don't see a big advantage except for the disk brakes. For sure the I-beam front axle is a lot easier to get up and running.
Great that it is a real pickup truck too, and not a grain truck.
R.
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44618
10/09/07 11:27 AM
10/09/07 11:27 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Very COOL truck, they make a great rod project
this is just my opinion, I have had a few cars and trucks with an axel, and I have had well over 30 cars with and independent frontend and the independent frontends handle and brake WAYYYYYYY better, again "just my opinon"
I would go with an independent frontend if it was my truck...
I had a volare' frontend on my 36 dodge humpback, I did that back around 1978 because I wanted my mopar to be all mopar, it drove and handeled fantastic, it was one of the first aspen/volare frontend put under a rod back then.
the only problem I had with it was I could not lower it as far down as I would have liked, because it is a little wide for an early rod.
If you go with the stock frame I would use a Mustang II style frontend like the ones from fatman.
the dakota chassis swap works good under most cars and trucks because they are a full frame chassis and not a unibody like all our other mopars, again you need to watch the width of the dakota and be carefull with wheel offset on the front.
we are doing 3 dakota frame swaps right now,
one is under a 46 dodge PU
one will be under a 42 COE
and we plan to put a 47 dodge panal truck on one.
I want these to work out and everything looks good so far but If I had to widen the front fenders to make it work then thats what I would do.
the COE and the panal truck will have the complete drivetrain in then ,5.2 efi engine and OD transmission so it will be just like driving a dakota but just a different body on it Ron..
Re: Grampa's 1937 Dodge Truck [Re: Mopar Ron] #44619
10/13/07 08:35 PM
10/13/07 08:35 PM
Amarillo, Tx
daithi2 Offline
daithi2  Offline
Amarillo, Tx
37! DO IT!
47 Dodge - turbocharged 493" 05 SRT6 - Only 10 second and fastest SRT-6
Re: Grampa's 1937 Dodge Truck [Re: daithi2] #44620
10/18/07 07:30 PM
10/18/07 07:30 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Wow, I have never actually seen a 37. I have been half interested in finding a 57 for the next project, but may reconsider! Those 37's have some nice looks!!!
Re: Grampa's 1937 Dodge Truck [Re: Devilbrad] #44621
10/28/08 10:23 PM
10/28/08 10:23 PM
Minnesota
Minnesota
So a year later and my Dad pulled the truck off the farm and down to the shop. Reason being is that Grandma and Grandpa are selling the farm and moving to town. That sucks, because all us grandkids have so many memories of going to the farm, but none of us can afford to buy it so its getting sold. Anyways, here are some updated pictures. Nothing will happen to it for probably another year, i need to build a garage for it first at my place.
Paul
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44622
10/28/08 10:23 PM
10/28/08 10:23 PM
Minnesota
Minnesota
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44623
10/28/08 10:24 PM
10/28/08 10:24 PM
Minnesota
Minnesota
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44624
10/28/08 10:24 PM
10/28/08 10:24 PM
Minnesota
Minnesota
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44625
10/28/08 10:25 PM
10/28/08 10:25 PM
Minnesota
Minnesota
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44626
10/28/08 10:28 PM
10/28/08 10:28 PM
Minnesota
Minnesota
Here is where my new detached garage will go. I am going to build it 28x28 and put scissor trusses in for additional ceiling height so i have room for a lift on one side. Then i can stack this truck and my Charger on one side and still have an open bay for another project in the future that i dont have time or money for.
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44627
10/28/08 10:31 PM
10/28/08 10:31 PM
Minnesota
Minnesota
The straight on view.
Re: Grampa's 1937 Dodge Truck [Re: PocketThunder] #44628
10/29/08 12:31 PM
10/29/08 12:31 PM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Well, at least its now safe and out of the mud. Will make a great project.
LAWFISH
Re: Grampa's 1937 Dodge Truck [Re: RUMBLON] #44629
10/29/08 10:11 PM
10/29/08 10:11 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
That will make one on the suspension..IFS all the way. Do a straight axle for the old school thing if ya want to but for a dedicated driver IFS is the only way to fly...
Re: Grampa's 1937 Dodge Truck [Re: Devilbrad] #44630
10/30/08 11:42 AM
10/30/08 11:42 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
here is my 37 Plymouth
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
