Re: oil pressure in a 440
[Re: Pacnorthcuda]
#445807
08/22/09 05:23 PM
08/22/09 05:23 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
This is in a baffled pan so very unlikely even in braking. Only time that I have seen a HV pump a pan out and it really didn't is in a dirt car wiothout the proper pick up so that the oil was pulled away from the sump from inertia of the turns on the oval. would have happened with any pump. I know that there are many here that 'think' that a HV pump can pump out a pan but it is very unlikely and will have other contributing causes like blocked or in some way restricted oil return - not the pump over pumping. If you thinkk it does that is up to you .
I know it is. I have had it happen in a street 440. Yes I stated other factors (did you even read my post?). In my case I had loose bearings, an HV pump, baffled low capaciity pan, no windage tray, and light oil. If the pan wasn't kept at 1 guart overfill the pan would go dry (under acceleration). Just becuase something hasn't happened to you doen't make it impossible. ![](/ubbthreads/images/graemlins/thumbs.gif)
The HV pump IS contributing to his situation--it HAS to. How MUCH is debatable--not IF. Its job is to pump a higher volume of oil UP into the engine--that means LESS in the pan. They are postive displacement pumps--its what they do!
If you reread my post it says "very unlikely". And your post it doesn't "HAVE TO". The pump may contribute but better find the underlying cause. Seen many times where replacing siomething 'fixes' a problem intially caused something else. I say it again a HV pump on properly built with proper adaquet oil levels engine isn't going to pump out the pan. Been around too many of them in the last 45 years.
[Re: MoparforLife]
#445808
08/22/09 05:44 PM
08/22/09 05:44 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
...and a 'properly built" engine doesn't NEED a HV pump! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Pacnorthcuda]
#445809
08/22/09 11:17 PM
08/22/09 11:17 PM
Posts: 4,872 connecticut
pnypwr
connecticut
play nice kids...so I dropped the pil, looked clean, should only had 5 or 600 miles on it, changed the filter, parts store guy gave me the wrong one, so I used a ford filter I usually keep around, basically a 51515 wix or ph8a equivilent so it hold a lil more oil, fired it and hot i have 70 psi at idle, gauge is still on it but I didnt get a chance to drive it today. but after adding my 6 qts it shows a lil over on the dipstick, so im figuring that wont hurt if it is in fact pumping the pan dry, I guess I need to pull the valve covers to make sure the returns in the head arent plugged also.
as for why its got a hi vol pump...idk it was on it when I got the engine, like i said I got it from a friend and just regasketed it and took a look inside, it all looked good!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: Pacnorthcuda]
#445811
08/23/09 01:11 AM
08/23/09 01:11 AM
Posts: 5,169 CT
GTX MATT
CT
My 273 has had an oil leak from the plug since I got it (threads were crossed at some point). It has gotten worse each time I change the oil, now its pretty bad but im not too worried about it since Im changing the engine in the next few weeks (whenever I get my tranny back). Anyway I still cruise with the car, and it does leak ALOT. I have to put a pan under it when I park it.
Anyway, its got some later model dipstick from a 360 or something on it, it reads wrong. So I know to add more oil by watching the oil pressure gauge under hard breaking. I had 50 psi hot, 30 warm, and if I've just gone a distance on the highway at 3000 rpm or so it will ocasionally dip to 20 until it cools back off. Anyway, when its low it will drop alot under hard breaking, once it dropped to 0 so I just put the car in neutral and turned it off. By the time it fired back up it had pressure. It scared me though. Anyway, my guess would simply be low on oil. I keep mine overfilled and it prevents it. I have mechanical lifters though, so I wouldnt hear a lifter tick from lack of oil. Hope this helps.
[Re: pnypwr]
#445816
08/23/09 08:57 PM
08/23/09 08:57 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
Regardless of how well you think it worked before, you said it yourself it's a mild combo. So what's the logic behind sticking an HV pump in a mild combo, what's your justification other than trying to see if you can suck your pan dry? 7qts is the min for HV IMO btw. And you're just causing unneccesary risk and eating up power for no reason ![](/ubbthreads/images/graemlins/Twocents.gif) .
[Re: CokeBottleKid]
#445817
08/23/09 10:59 PM
08/23/09 10:59 PM
pnypwr
connecticut
I didnt build the motor, I got it this way, looked at the pan no dmage so I doubt the pan to pick up clearance changed much, ive seen this in gm vehicles where the pickups fall off the pump, pulled the covers and drains are clear, doesnt rattle or knock so im not feeling excessive clearances...ill drive it tomorrow and see if its changed with a new filter, suppose the check valve could not be working and causing the pump to bypass...the needle flutter on the gauge was greatly reduced with the new oil change
