Re: Cowl Hood Scoops.. Why on a MOPAR?????
[Re: Thumperdart]
#44549
01/31/13 11:42 AM
01/31/13 11:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
one more for the haters...
I`m not a cowl hater but just think some Mopars don`t look right and as I stated before about your scoop..........I don`t think you`re drawing in much air........
not for air, it's for clearance.
[Re: Mr.Yuck]
#44550
01/31/13 11:44 AM
01/31/13 11:44 AM
Dont you run a six pack? Clearance for a factory option that fits under a flat hood?
[Re: ]
#44552
01/31/13 12:19 PM
01/31/13 12:19 PM
Mr.Yuck
Brookeville, Md
not w/ stage VI heads and 1/2" Meth/H2O plates....
[Re: Thumperdart]
#44553
01/31/13 12:22 PM
01/31/13 12:22 PM
Mr.Yuck
Brookeville, Md
Where do you draw air from?
I guess from the cowl and from what ever runs thru the engine bay. The cowl does get some air as I can see it lift durning a pass, so much so I had add an extra pin. It's maybe 4" from the windshield.
[Re: Mr.Yuck]
#44554
01/31/13 12:39 PM
01/31/13 12:39 PM
1000+sbm
[Re: 1000+sbm]
#44555
01/31/13 12:50 PM
01/31/13 12:50 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
One i painted for a buddy
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#44556
01/31/13 02:44 PM
01/31/13 02:44 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Alot of nice looking cars here. I think they look best on the E-Bodies as mentioned above since they are similar to looks of a 1ST Gen Camaro but I just can't bring myself to put one on any of my cars. Still undecided what scoop I am going to run on my Challenger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#44557
01/31/13 02:48 PM
01/31/13 02:48 PM
mikeysmopars
fresno ca
T/A Hood on a challenger is the coolest, If you need more clearance, Cut & Raise it, I have seen the extended version of the T/A hood. Anyone here got one?
[Re: mikeysmopars]
#44558
01/31/13 03:25 PM
01/31/13 03:25 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I got the cowl hood simply because I couldnt find a forward facing scoop that I liked.. everything that would fit and provide enough clearance, looked like a beached whale sitting on the hood.. Before... After... No Hood... You tell me which one looks better!!
[Re: DblOJoe]
#44561
01/31/13 04:39 PM
01/31/13 04:39 PM
1000+sbm
[Re: DblOJoe]
#44562
01/31/13 04:42 PM
01/31/13 04:42 PM
Posts: 461 Hinterland SE Qld Aust
SG duster
Six pack and Hemi scoops shouldnt be on every mopar built...
same goes for cowl scoops, some look good some dont. it realy is the preference of the owner
[Re: SG duster]
#44563
01/31/13 04:47 PM
01/31/13 04:47 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
It's all about air and air turbulence in the carb area. I have a 6pak hood/scoop and the cowl hood/scoop. I have never gotten my 6 pak set-up to make one good, clean pass.
If you like drag racing, support your local track.
