Re: Blocking intake manifold exhaust crossover
[Re: IcorkSOAK]
#444500
08/20/09 07:33 PM
08/20/09 07:33 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Depends on your local climate. If you live and drive in a year-round mild climate, it can work fine. But, not great in Winter/cold climates. Fuel is not atomized as well, so fuel-economy / emissions are worse.
It's a summer-only car and not driven in the winter. Especially our winters.
NOT a good idea as far as MPG and general street-manners. If you are having hot-start probs .. just insulate the carb from the hot intake.
I bought an insulator that goes between the carb and intake but after installing it, the carb was too high to fit under the air grabber unit.
It's about 1/2 inch thick so I might try to file it down to half that and see if it will fit.
[Re: DaytonaTurbo]
#444505
08/20/09 09:16 PM
08/20/09 09:16 PM
Posts: 5,025 WI
Dcuda69
WI
Exh crossover serves 3 functions 1. Heat the intake charge to help emissions and cold drivability 2. provide heat for the bi-metallic choke stat 3. provide exhaust gas for EGR systems NONE are required for even a mild build! Most carbs have electric chokes,perf engines don't use EGR and who cares about cold drivability? BLOCK IT OFF!!
[Re: Neil]
#444506
08/20/09 09:19 PM
08/20/09 09:19 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Maybe you should consider (or fabricate your own) carburetor heat-deflector plate:
Here's the Post:
I had a vapor-lock/carb-heat problem, so I bought/installed one under the carb on my '71 Charger. Holley makes/sells them, but I don't see it at Summit Racing or on Holley.com, though it may be there someplace (Jegs, etc.) Or, make one out of Aluminum sheet.
Here is a photo of one on a Chevy from the internet above.
Or this one a Moparts member fabricated out of "Plexiglass?"
Similar Moparts Post
[Re: Neil]
#444508
08/21/09 08:10 AM
08/21/09 08:10 AM
Posts: 21,132 Niles , Ohio
therocks
Niles , Ohio
Block it.We have all ours blocked.Neither has chokes and I run a Dominator on mine.How many people drive their cars in the winter?They were installed to heat the intake when these cars were daily drivers.That and if you worry about gas milage get a Prius.My 440 gets maybe 4 MPG.That and my aluminum heads now dont have any heat cross overs.Rocky
Chrysler Firepower
[Re: moparcanuk]
#444509
08/21/09 08:20 AM
08/21/09 08:20 AM
Posts: 3,305 West Coast, USA
jbc426
West Coast, USA
Are you still running stock manifolds with an exhaust butterfly valves? You can likely block it, and never notice the slightly extended warm up time until the fuel stops collecting along the manifold and intake runners, which can cause a temporary lean condition on initial warm up. You will also noticed improved drivability once warmed up. Mopars like cool dense air, which I have always referred to as horsepower air on those foggy chilly mornings.
I blocked it on my old VW engine at one time. On our VERY cold sub 50 degree days here in California, it used to ice the carb and cause stalling, because the carb was mounted so far from any other heat source.
On our beloved V8's, heatsoak from the heads and valley of the motor prevent that in all but the coldest climates.
I can't do this on my slant 6 though, because it would likely have cold start/drivability problems on all but the warmest days without the heat from the exhaust to keep the fuel from collecting along the inside of the intake on start-up. The nearly instant heat from the exhaust, really helps vaporize the intake charge and gets the engine running smoothly quickly. After the first 5 minutes though, the same heat begins to rob me of performance. I've used heat shields to try to make this issue less noticable and aid with hot start issues. It's been pretty effective. Much more so than the infamous "fuel line mod" touted by some slant 6'rs...
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 383man]
#444510
08/21/09 08:32 AM
08/21/09 08:32 AM
Posts: 130 Blanchard, OK
Real-Fury
Blanchard, OK
Hey 383man, I was going to PM you to see how you were turning those high 11's with a 383. Now that I see under your hood I don't have to ask that question. Beautiful car. Saw the burnout photo on the 62-65 Mopar site. Butch
[Re: Real-Fury]
#444511
08/21/09 09:42 AM
08/21/09 09:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Hey 383man,
Butch
Thank you for the kind words. Ron
[Re: 383man]
#444512
08/21/09 10:56 AM
08/21/09 10:56 AM
Posts: 4,851 Holland MI Ottawa
2boltmain
Holland MI Ottawa
An oval track friend told me he has always packed furnace cement into the cyl head cavity.
Keep old mopars alive.
[Re: 2boltmain]
#444513
08/21/09 11:37 AM
08/21/09 11:37 AM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
....... My 440 gets maybe 4 MPG. ....if you worry about gas milage get a Prius. THIS is something I would not be proud of !! Your 440 is soitenly NOT fuel efficent ... I would think you could "cruise" with a furr-real Pro Stock car and get better MPG than that .. Performance and fuel mileage and efficiency CAN come-together ...LOOK at some of the newer cars .... the FIRST being the recent Corvettes. IIRC ... a dead-stock OEM vehicle that runs in the 11's ...and gets nearly 30 mpg. VERY impressive ...IMO.
[Re: IcorkSOAK]
#444514
08/21/09 03:07 PM
08/21/09 03:07 PM
therocks
Niles , Ohio
Doc I built a race car not a fuel economey car and yes its street driven.With 12.5 pistons almost .600 lift cam and Dominator its not fuel friendly.Fast but not fuel efficent.So like I said if you want fuel economey get a prius.How many of these cars here actually get driven?I mean daily.My kids 300 does and he gets probally 12 or 14 mpg and its a 62.Thats if he keeps his foot out of it.Rocky
Chrysler Firepower
[Re: moparcanuk]
#444516
08/23/09 12:55 AM
08/23/09 12:55 AM
Posts: 1,465 oklahoma
forphorty
oklahoma
I'm running stock intake and manifolds. I'm thinking of just installing a valley gasket that has the exhaust crossover holes blocked. That sounds like the easiest way to do it for me.
I just use the gasket with the holes blocked, works fine, but they will sometimes burn through after several years.
