Re: Help Picking Stroker Parts Sm Blk
[Re: Scamp408]
#442723
08/19/09 11:21 AM
08/19/09 11:21 AM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Were it me, i would go with the Callies crank and compstar rods, both proven pieces that arent especially expensive.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: DavidDean]
#442725
08/19/09 12:33 PM
08/19/09 12:33 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I got my stuff for my small block from Dram. K1 crank and rods, along with custom Diamond pistons. Hopefully the block will be done soon so I can put it together.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Scamp408]
#442727
08/19/09 01:07 PM
08/19/09 01:07 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
K1 4340 4.0" 340 main W/ 2.10" GM journals K1# 340-4000EB6F ~58 lbs (catalog spec)
K1 6.125" X 2.10" X .927" GM H beam rods K1# CH6125ALLB8-A ~645 grams (catalog spec)
Diamond #51027 4.03" Bore X 1.457" CH X .927" GM pin for 4.0" Stroke SB Mopar flat tops -6.8CC reliefs. ~502 grams (catalog spec)
Diamond #09024030 File fit moly ring set (manufactured by Mahle most likely)
Clevite CB663HN or CB663HXN rod bearings
Clevite MS540H or MS540HX main bearings
Should internally balance W/no metal added.
Simple, affordable, GM journals/pins, VG machining quality, fairly light parts, & definitely strong enough to handle anything you can throw at it NA.
~11.00:1 compresion assuming an OOB ~68 CC INDY CNC combustion chamber, zero deck height & .040" X 4.125" Cometic head gasket.
[Re: Jacob Pitt]
#442732
08/19/09 02:57 PM
08/19/09 02:57 PM
Posts: 2,864 IN
Irun5snd8th
IN
I may have a set of 4.030 Diamond pistons and Eagle h beam rods in my garage. I will have to look.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Jacob Pitt]
#442733
08/19/09 03:28 PM
08/19/09 03:28 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Whats the gain if I run chevy stuff compared to mopar?
The big end of the rod is smaller, which means less mass and more clearance. I didn't have to clear anything on the block with the Chevy rods.
That make sense to me.Any more $$$$ going that route?
[Re: Scamp408]
#442734
08/19/09 03:45 PM
08/19/09 03:45 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
No.
[Re: Scamp408]
#442735
08/19/09 03:47 PM
08/19/09 03:47 PM
RyanJ
moparts member
moparts member
State College, PA
Parts are lighter to, & generally costs will be a HAIR cheaper at least with parts I suggested earlier.
You could use a Callies Crank instead of a K1, it's generally about $225-$250 more $ than a K1 4.0"/2.10" crank. Depending on where you buy them.
K1 & Callies are only ones offering off shelf 4.0" with GM journals.
Several companies offer their off shelf pistons now with the .927" GM pin to work with those Chevy Rod cranks. Diamond was first to offer it...
[Re: Hot 340]
#442738
08/20/09 05:25 AM
08/20/09 05:25 AM
Scamp408
NJ central
Lets discuss it .How does the bigger stroke set up work? I dont want to build another mistake motor because of parts decision I made on the first one(cast crank,I beams) ![](/ubbthreads/images/graemlins/smilie_help.gif)
