Re: 360 Stroker info please...
[Re: patrick]
#442284
08/19/09 07:53 PM
08/19/09 07:53 PM
Posts: 4,884 Michigan
MNobody
Thanks for the info Robert, i forgot you were building one. I need Piston ideas too, something in the 10-10 1/2 comp range.
with 72cc J heads, KB forged flat tops will be 10.5:1 with a fel pro 8553PT gasket (.054" thick) will net you 10.5:1
the SCAT I beams probably won't need block clearancing. stockers will.
Cool Thanks will the Rod's out of my 318 work in the 360?
[Re: MNobody]
#442285
08/20/09 05:49 AM
08/20/09 05:49 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if it's a 73 or later 318, the rods are identical to 360 rods...you'll need to clearance the block. shoot for ~ .060" clearance between the rod bolt and the bottom of the cyl
[Re: MNobody]
#442289
08/20/09 03:20 PM
08/20/09 03:20 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
My cam is 272@050 610 lift. I have a TA 4200 convertor. It flashes 5400. If yours is a good converter. It might be very close as is. Are you going to use the cast or forge crank? Jim
