Re: If you have 440 overheating problems,
[Re: 440sourcedotcom]
#442084
08/19/09 03:03 PM
08/19/09 03:03 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Now people are saying their engine is running perfectly cool, but they are going to remove their water pump housing anyway because of this thread. Am I missing something? Is there really that much of a sheep mentality going on here?
I removed my housing because it was easy to pull and look at, no coolant, motor not hooked up and running but dyno time.
And yes I thought it was a cat housing, which everyone sells.
Now for the question if the housing has a small opening,
IT DOES, will it cause a cooling problem, seems to have for one. Not sure for anyone else
The narrow passage is only the feed ( back to the block ) lower passage on the passage side. All other passage look fine and closely match a factory housing.
Picture included
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#442085
08/19/09 03:04 PM
08/19/09 03:04 PM
moparts
Norwich CT USA
And the drivers side , which looks fine
Tom ,
Re: If you have 440 overheating problems,440 Source,lon
#442086
08/19/09 03:05 PM
08/19/09 03:05 PM
Posts: 4,179 California
mickm
California
fwiw, (and i admit, probably nothing), i agree. if it ain't broke, don't fix it. if the pump is working, why replace it? if you ever do run into cooling issues, then you will at least have a place to start looking.
Here goes another Moparts bash fest about our company and our products when in reality the entire mopar marketplace sells the exact same part from the exact same manufacturer, and has been for many years [list] . If anyone wonders why we are no longer active in the Moparts.com community, this is exactly why.
once again, i agree. 440 source is probably the most bashed vendor on this site, from what i have seen. although i have yet to see anyone bash them because a motor grenaded, which was then specifically traced to faulty parts. i think in the end i have only seen them bashed because the parts are manufactured overseas.
if their stuff works for you, buy it. if it doesn't, don't. but what is the point in bashing them or anyone else, beyond a one time report of bad parts or bad service?
kind of a drag when someone who has provided parts for so many members cars for such a long time doesn't even want to be a part of this community anymore.
[Re: mickm]
#442087
08/19/09 03:20 PM
08/19/09 03:20 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
You say 440 Source is one of the most bashed vendors on this site!Question for you,how does one achieve that status.
[Re: I go fast]
#442088
08/19/09 03:25 PM
08/19/09 03:25 PM
mickm
California
i have no empirical data for this. it just seems to me that i have seen more posts bashing them than any other vendor. doesn't mean that is the case, just what i have noticed. which at least means the bash rate is reasonably high!
Re: If you have 440 overheating problems,440 Source,long
[Re: GTXKen]
#442089
08/19/09 03:34 PM
08/19/09 03:34 PM
Posts: 21,687 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
That's the first I have head of in the water pump problem. I think a combination of diffrent factors could be here. On the origian post where his motor is over heating, it could be a combination of factors that would add heat. No spring in hoses so they collapse with heat, low waterpump housing volume, compression ratio, bore diamiter, compression height,rearend ratio in traffic driving (ever seen what 4;10's and 3:23's diffrence in heat for cruising). I knew a guy who had a brand new engine, literatly fresh from the shop and had everything perfect and it would overheat, no matter what they did. After several trips they disassembled the block and still found nothing. Later on, the boil job done to the block was sub-par and found huge rust and debris in the water passages blocking a good deal of flow! After a correct boil and dipping, they reassembled the engine and it lost 30 degrees of over heating temp!
Now I'm not saying who is at fault or what is the cause, but assuming that a 3/4 inch in diffrence after all the hundreds of pumps/housings sold and there have been no known problems of that reported before, might be pushing the parinoid button a little to soon here. If it's such a big deal about that little volume, just take a little dremel and open it up. Come on, these car part upgrades save alot of people some cash in the long run, so why not just go that little extra step and do something that will make your self feel good that you did the work yourself.
And just so people don't say I am defending Brandon, the only thing I ever bought off him was a set of mopar performance main caps he had for sale. I have been around about 20 other of his customers motors in cars, trucks and one motorhome that used his parts, and never have heard a problem with any of those parts he sold (except an very early roller rocker set when the company first started, and that was fixed early on) and everyone pretty muc drives/races their rides frequently.
Now nobody is dog piling you B-man, just people just comparing info and tech, nothing more.
Now, where did I put that dremel at......
[Re: mickm]
#442090
08/19/09 03:40 PM
08/19/09 03:40 PM
migsBIG
San Jose,CA
I do.....
MOPARTS, where all the 'HATERS' come to play!
[Re: moparts]
#442091
08/19/09 03:40 PM
08/19/09 03:40 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If you have to ask then you haven't spent much time on here.
Simply put, their lower prices translate into larger volumes of sales. Even if their parts have the same or lower failure rate as others, the larger sales volume equals more failures and this gives the wrong perception that their parts are substandard.
Couple this with the "made in america" mentality and you end up with a company who gets bashed far more than they deserve.
If all the whiners that are against buying offshore products just didn't buy them and kept their unjustified opinions to themselves then everything would be just fine. I don't doubt for a moment that most of these individuals are hypocrites anyway, doing the bulk of their everyday shopping at Walmart!
[Re: Stanton]
#442093
08/19/09 04:08 PM
08/19/09 04:08 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
Made in America parts are better, if you need that explained, then you haven't worked on enough stuff. Cars or otherwise. I can't even begin to count the times that China crap has been bad out of the box or needed extra work to use. USA stuff is pretty good right off the jump. Thanks to the "Buying China products is a fine thing to do" mentality, I can no longer pay extra for USA products in most cases. I can't thank you all enough for the BS that has caused. If a vendor claims to be so good, and the members claim they are so good, why run from the so called unfounded criticisms? Should be easy to dispell. But no, run away and hide is the tactic. Strange way of going about things. For the record, I have only went to Wal Mart twice this summer. Once to buy motor oil that is cheaper there and the same stuff I could get anywhere. The other time was for some Advil. Yes, there are a million factors into overheating. This is one that can and has caused the problem per the member with that car. How many overheating threads have there been in the past couple of months? Did anybody think of this before? irst I have seen it, maybe those cars from the other threads have this housing.
I want my fair share
[Re: moparts]
#442094
08/19/09 04:44 PM
08/19/09 04:44 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Bashing aside... is there enough "meat" in the narrowed area to open it up to factory dimensions, with a die grinder and burr?
-Charles
#442095
08/19/09 04:53 PM
08/19/09 04:53 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I don't think anyone said that Just people wondering if their pumps were affected. Wouldn't make sense to take your pump off if you weren't having a problem.
I think it is a case of self fulfilling prophesy, no one bashed your company until started this rant
[Re: SomeCarGuy]
#442096
08/19/09 10:08 PM
08/19/09 10:08 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Let's get one thing straight here. It wasn't some little chinaman who was tired of pulling a rickshaw that suddenly said "hey, I think I'll make big block mopar parts and export them to amellica"! It is capitalistic americans who are having the stuff made by cheap labor because THEY can make a buck !!! And there's nothing wrong with that. However, when it comes to quality you have to spell it out. An american quality "guru" once said that "quality is conformance to requirements". So when you have a product made you have to specify each and every one of those requirements. That's real simple when you're dealing with local shops - they send you a prototype, you need a change, you call them up and tell them and they make adjustments. Its a little different when you're dealing with people who not only speak a different language but are also accustomed to cranking out cheap parts fast because that's what the customer has always wanted! However, make no mistake - if you spell out EXACTLY what you want to a Chinese manufacturer, you will get a product of unsurpassed quality at a price that can't be beat. The bottom line is if you have an issue with offshore quality, blame the guy that ordered it, not the guy that made it.
[Re: Stanton]
#442097
08/19/09 11:55 PM
08/19/09 11:55 PM
SomeCarGuy
Yep, I can't get made in the USA parts due to that thinking you just posted. I understand people want to make more money- not a shocker When you give people a choice of cheap versus quality, it is going to go on price as most people don't stop and think about the problems that might create. So that runs the guys making good stuff here in the US out of business. An explains why when I get something like an angle stop for a toliet, I have to get three in order to have one that works right. I blame both the guys selling i, at the same price as before no less, if not more AND the guys that think it is a great thing.
[Re: Boise Chall]
#442099
08/20/09 08:41 AM
08/20/09 08:41 AM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
Never had a bad USA part did you?LOL Ive been wrenching for over 40 years.Ever pull a factory part from your US made vehible.It made in Canada Australia Korea Mexico Pakistan etc.Wake up most not all but most US companies dont give a crap where its made.Just make it cheap so they can make more $$$$.Then lets see you have the EPA and their regs local state taxes fed taxes.Oh lets mot forget the unions.Yeah I was a union member.Not saying they are all bad but they do drive up prices.Like at the mill.We couldnt change a light bulb without calling an electrician that at that time made 16 bucks an hour or more in the 70s.Then we had to wait for 1 to 3 hours for them.They had to watch their TV in their air conditioned room.If you unscrewed the bulb they filed a grievance.Then lets see you have the fat cats knocking down insane salarys.Gee I wonder why you cant guy a US made product.Rocky
Chrysler Firepower
[Re: TonyS451]
#442101
08/20/09 09:55 AM
08/20/09 09:55 AM
I go fast
Wilmington,NC
-Charles
I was wondering about that as well.
I would "ASSUME" there is,but if that be the case,once again,why was it not done from the beginning? Now I remember,short cuts save money!
[Re: therocks]
#442102
08/20/09 10:07 AM
08/20/09 10:07 AM
SomeCarGuy
Nice straw man. You beat him up pretty well. I don't think you will find anybody that says that USA stuff doesn't fail. ANYTHING mass produced will have problems. Do you really need that concept explained to you?
Too bad that doesn't change the fact that Chinese parts are FAR more trouble prone. Enjoy your lead filled toys for your kids and so on. Enjoy repairing things again when a Chinese part fails quickly or doesn't work the first time.
[Re: SomeCarGuy]
#442103
08/20/09 11:48 AM
08/20/09 11:48 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Somebody needs to change the title of this thread, it's gotten a little sidetracked. We got another China-bashin' thread going on right now (if it hasn't been deleted yet) so those of you wanting that destination should get on the other bus...
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
