Page 2 of 3 1 2 3
Re: A-Body LCA's [Re: autoxcuda] #441872
08/19/09 10:56 PM
08/19/09 10:56 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
As for the strut hole, this will take a little more thought and effort..., I'm thinking maybe pounding it out or build a puller that will pull it back into shape. I'm not positive but just getting the shape close should be good enough. I would not think that this is a precision measurment.
The tire did not lose any air, but there is some good cracks in the rubber.
I'm not looking at changing the K-Frame out.
Not the prettiest idea, BUT.... you could measure how much the strut hole is pulled in, then cut the rear poly bushing and inner sleeve that same amount. So you could make up for how much the hole is bent in and then still get you alignment numbers. I bet it's not pulled back a ton. Inspect the extra plate the factory welded to the k-member at the hole there and compart to other side. See if there is a seperation. Could even add a bead of weld on both sides of the plate for good measure.
2 things happened here.
1) full front end is Poly Bushings. If it was rubber the K-frame would not have taken so much damage.
2) The Sway Bar mounting Tab is not only bolted but also welded to the K-Frame. This also limited the about of damage that did happen. The bolt to the swaybar and lower Control arm "Shock Mount type" was also bent.... With out the lower swaybar the strut would have probably broken and the tire would have folded under and wiped out the quarter....
Looking real close to the K-Frame mounts and Frame rails I still think I'm ok for the repair. Nothing looks tweeked, bolts to the frame haven't slid, no paint or welds are cracked. There is plenty of room once I dropped the sway bar and pulled the strut to work a jig to get hole back into shape. It won't be "Perfect" but it will be "Original"
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: A-Body LCA's [Re: Noblewk] #441873
08/20/09 12:47 AM
08/20/09 12:47 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I didn't think that strut rod hole was going to be that bad. You could beat and weld it back in place.
But 68HemiB has a point that you'll have about half of the suspension apart anyway.... If you found a 64-66 A-body while you're in the yard with a good K-member for under $30, I'd snag it. $30 is cheaper than an alterkion.
On 64-66 A-body the /6 and V8 bare k-members interchange.
Re: A-Body LCA's [Re: autoxcuda] #441874
08/20/09 12:58 AM
08/20/09 12:58 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I'm surprised the rim isn't bent more. Almost looks like the tire didn't loose air? Maybe if the rim would have bent more some other parts would not have got bent.
An Alum or steel rim? Doesn't add up to me. Any tequila involved?
Re: A-Body LCA's Updated with PICS..... [Re: Noblewk] #441875
08/20/09 01:14 AM
08/20/09 01:14 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Noble...you have a pm.
Re: A-Body LCA's [Re: autoxcuda] #441876
08/20/09 10:22 PM
08/20/09 10:22 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
yea your both right, I'll see what I can find...
Re: A-Body LCA's [Re: jcc] #441877
08/20/09 10:24 PM
08/20/09 10:24 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Aluminum Center Line, they are a heavy rim though for an Aluminum Rim. I here Aluminum is going around .50 a lbs. so I'll do my part and recycle it.... ......... Tequila after I got it home....
Re: A-Body LCA's [Re: Noblewk] #441878
08/21/09 01:06 AM
08/21/09 01:06 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Noble - I just went out & looked at my old stuff; all I have is the old drum upper arms, brake drums, spindles, and ball joints..I must have re-used the original lower arms when I did the disc conversion about 10 years ago.
Anyway, my offer still stands if you can use any of it.
Larry
Re: A-Body LCA's [Re: vdriver] #441879
08/21/09 01:13 AM
08/21/09 01:13 AM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Larry
Thanks again You Rock
But as you can see I have Disks, I'm not too sure what I would need out of that, but I will give you a Ring if something comes up.
Re: A-Body LCA's [Re: Noblewk] #441880
08/22/09 01:43 PM
08/22/09 01:43 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Ok the lower is out and you can see how it folded at the end..
It also looks like the Mounting Bolt was also pulled but after looking closer there is no indication of it happening. It is out but it been that way for a while
Re: A-Body LCA's [Re: Noblewk] #441881
08/22/09 01:45 PM
08/22/09 01:45 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Here is a shot of the Strut.... Guess it needs replaced also....
Re: A-Body LCA's [Re: Noblewk] #441882
08/22/09 01:57 PM
08/22/09 01:57 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
one more of the Strut Hole from the inside. Here it looks like after I get it pulled back out and welded, I will used a weld in a big fender washer to help support it.
Re: A-Body LCA's [Re: Noblewk] #441883
08/22/09 01:59 PM
08/22/09 01:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Many years ago I used to live in San Diego, there was a Mopar only junkyard there called Sweetwater Auto Wrecking.
If they are still MoPar only and still in business they should have what you need. Granted it's been about 16 years since I lived there so who knows, but they we the go to guys back then when all else fail. Of course the Ecology yards had tons of A bodies back then too.
Another source might be the Ocean Beach area, used to be lots of early A's there being used as daily drivers, still a few there now. I know I saw a couple on Google's street view, was looking at my old rental beach house I used to rent.
Don't be the exception.
Re: A-Body LCA's [Re: Supercuda] #441884
08/22/09 02:07 PM
08/22/09 02:07 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Your right, I called Sweetwater yesterday and they didn't have an upper, but said they get them in time to time. Also called Calumet, they recommended Chula Vista..... I found the lower but I need to go pull it. I think thats where I'm off to now..
Re: A-Body LCA's [Re: Noblewk] #441885
08/22/09 04:24 PM
08/22/09 04:24 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
Success!!! Lower Control Arm and Strut at the local Pick a Part $12.97 with "Envormental fee"! Yea Baby.... Stopped in at the local suspension parts dealer, and grabbed a Control arm bushing $16.12 and replaced that at a friends shop. 20 Ton Press and Air Chisels made that a 15 Min job. Now just degrease it, swap the bumpers.
This Pic really shows the damage the lower took.
Re: A-Body LCA's [Re: Noblewk] #441886
08/25/09 10:48 AM
08/25/09 10:48 AM
KS
MoparKansas Offline
MoparKansas  Offline
KS
So suspension experts - would the weld in plates for lower control arms help prevent the lower control arm damage or transferred the damage to another component? Just wondering...
Re: A-Body LCA's [Re: MoparKansas] #441887
08/25/09 11:43 AM
08/25/09 11:43 AM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Transfer to another component.
If you are going to reinforce one part, you should reinforce other areas as well.
Re: A-Body LCA's [Re: RokketRide] #441888
08/25/09 01:39 PM
08/25/09 01:39 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
The strut hole is getting back into place, A few more pull's and a little tapping is still needed.
I will need to weld the split and time to put it back together...
Here you can see that I have the strut hole pretty much back into shape.
Re: A-Body LCA's [Re: MoparKansas] #441889
08/25/09 01:51 PM
08/25/09 01:51 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
That is a real good question.
With the damage that took place the only real up grade to the suspension was the poly bushings.
The 64-66 K-Member is not reinforced at the Strut like the 67 and up. The 72 that I pulled the Lower Control Arm and Strut from had a 1/4" plate welded to the K-Member from the factory. The only reason that I can see that they would do that is 1) they were having issues with the K-Frame Flexing or 2) the K-frames were not holding up to the "Pot Holes".
Re: A-Body LCA's [Re: Noblewk] #441890
08/25/09 01:52 PM
08/25/09 01:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
"...when you can walk on the rice paper and leave no trace, you will be ready to leave grasshopper" Looks like your almost ready to leave...
Re: A-Body LCA's [Re: Noblewk] #441891
08/25/09 02:06 PM
08/25/09 02:06 PM
Southern Cal
Noblewk Offline OP
Noblewk  Offline OP
Southern Cal
here is a pic of the Back side. Here is were you can see where a weld it needed...
Page 2 of 3 1 2 3
