Re: A-Body LCA's
[Re: autoxcuda]
#441872
08/19/09 10:56 PM
08/19/09 10:56 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
As for the strut hole, this will take a little more thought and effort..., I'm thinking maybe pounding it out or build a puller that will pull it back into shape. I'm not positive but just getting the shape close should be good enough. I would not think that this is a precision measurment.
The tire did not lose any air, but there is some good cracks in the rubber.
I'm not looking at changing the K-Frame out.
Not the prettiest idea, BUT.... you could measure how much the strut hole is pulled in, then cut the rear poly bushing and inner sleeve that same amount. So you could make up for how much the hole is bent in and then still get you alignment numbers. I bet it's not pulled back a ton. Inspect the extra plate the factory welded to the k-member at the hole there and compart to other side. See if there is a seperation. Could even add a bead of weld on both sides of the plate for good measure.
2 things happened here.
1) full front end is Poly Bushings. If it was rubber the K-frame would not have taken so much damage.
2) The Sway Bar mounting Tab is not only bolted but also welded to the K-Frame. This also limited the about of damage that did happen. The bolt to the swaybar and lower Control arm "Shock Mount type" was also bent.... With out the lower swaybar the strut would have probably broken and the tire would have folded under and wiped out the quarter.... ![](/ubbthreads/images/graemlins/whiney.gif)
Looking real close to the K-Frame mounts and Frame rails I still think I'm ok for the repair. Nothing looks tweeked, bolts to the frame haven't slid, no paint or welds are cracked. There is plenty of room once I dropped the sway bar and pulled the strut to work a jig to get hole back into shape. It won't be "Perfect" but it will be "Original" ![](/ubbthreads/images/graemlins/laugh.gif)
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
Re: A-Body LCA's
[Re: Noblewk]
#441873
08/20/09 12:47 AM
08/20/09 12:47 AM
Posts: 27,486 So Cal
autoxcuda
So Cal
I didn't think that strut rod hole was going to be that bad. You could beat and weld it back in place.
But 68HemiB has a point that you'll have about half of the suspension apart anyway.... If you found a 64-66 A-body while you're in the yard with a good K-member for under $30, I'd snag it. $30 is cheaper than an alterkion.
On 64-66 A-body the /6 and V8 bare k-members interchange.
Re: A-Body LCA's
[Re: Noblewk]
#441883
08/22/09 01:59 PM
08/22/09 01:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Many years ago I used to live in San Diego, there was a Mopar only junkyard there called Sweetwater Auto Wrecking.
If they are still MoPar only and still in business they should have what you need. Granted it's been about 16 years since I lived there so who knows, but they we the go to guys back then when all else fail. Of course the Ecology yards had tons of A bodies back then too.
Another source might be the Ocean Beach area, used to be lots of early A's there being used as daily drivers, still a few there now. I know I saw a couple on Google's street view, was looking at my old rental beach house I used to rent.
Re: A-Body LCA's
[Re: Supercuda]
#441884
08/22/09 02:07 PM
08/22/09 02:07 PM
Noblewk
Southern Cal
Your right, I called Sweetwater yesterday and they didn't have an upper, but said they get them in time to time. Also called Calumet, they recommended Chula Vista..... I found the lower but I need to go pull it. I think thats where I'm off to now..
2000 Ram
2005 Durango Hemi.
Re: A-Body LCA's
[Re: Noblewk]
#441885
08/22/09 04:24 PM
08/22/09 04:24 PM
Noblewk
Southern Cal
Success!!! Lower Control Arm and Strut at the local Pick a Part $12.97 with "Envormental fee"! Yea Baby.... Stopped in at the local suspension parts dealer, and grabbed a Control arm bushing $16.12 ![](/ubbthreads/images/graemlins/rolleyes.gif) and replaced that at a friends shop. 20 Ton Press and Air Chisels made that a 15 Min job. Now just degrease it, swap the bumpers. This Pic really shows the damage the lower took.
2000 Ram
2005 Durango Hemi.
Re: A-Body LCA's
[Re: RokketRide]
#441888
08/25/09 01:39 PM
08/25/09 01:39 PM
Noblewk
Southern Cal
The strut hole is getting back into place, A few more pull's ![](/ubbthreads/images/graemlins/wrench.gif) and a little tapping ![](/ubbthreads/images/graemlins/hammer.gif) is still needed. I will need to weld ![](/ubbthreads/images/graemlins/weld.gif) the split and time to put it back together... Here you can see that I have the strut hole pretty much back into shape.
2000 Ram
2005 Durango Hemi.
Re: A-Body LCA's
[Re: Noblewk]
#441890
08/25/09 01:52 PM
08/25/09 01:52 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
The strut hole is getting back into place, A few more pull's and a little tapping is still needed. I will need to weld the split and time to put it back together...
"...when you can walk on the rice paper and leave no trace, you will be ready to leave grasshopper" Looks like your almost ready to leave...
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
