Re: RPM Redline for stock 383/4bbl
[Re: GwaiiEagle]
#441326
08/19/09 11:43 PM
08/19/09 11:43 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I spin my stock bottom 383 to 6400. no issues. 383's are pretty stout. remember that they have a forged crank and the same webbing / oiling / architecture as 440's and Hemi's, only with a smaller 3.38" stroke that does not tax this hardware nearly as hard as the RB's 3.75 stroke. I've always felt that the 383 was about as durable a workhorse as ever came out of an American auto maker.
[Re: StealthWedge67]
#441327
08/20/09 12:33 AM
08/20/09 12:33 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I saw some guys try to blow up a worn out 383 by putting a brick on the gas pedal trans in neutral, well it reved to 6000 for about 10 minutes and just sort of lost power and died, later when we pulled it apart the only damage we found was where the valves had nicked the pistons and slightly bent the valves just enough it would not run.
#441329
08/20/09 11:37 AM
08/20/09 11:37 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
It in't the bottom that will usually go. So what if they will spin 6000 or better not real likely with stock valve train that the valves will start to float on or the points distributor where the points will start to bounce. Even if you do get one that will spin that far what is the purpose. Bragging rights??? It is long done making power. Heck one of the first things we did with the magnums when new was to up grade the valve train to get rid of some of the float potential (we didn't like eyebrowed pistons or bent valves) and rework the distributor some. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Real-Fury]
#441332
08/20/09 03:00 PM
08/20/09 03:00 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Don't compare a BBD to a sbc..Its like an apple to a steaming pile of cow dung ![](/ubbthreads/images/graemlins/eyes.gif) Anyways..... The bottom end is good, forged crank, rods, and tough cast pistons. The old recommendation is not too much over 6500 or the pistons may seperate. (I don't know if I buy that, never seen or heard of a 383 or 440 piston that split..) Theres no point in worrying about heads if you have the stock cam. I would use either the 915's, 516(w/big valve) or 906s. The stock valve train should be good, unless you get wilder with the cam. Personally ,I like bigger cams, torque gets you going, but its always more fun at the topend when your horsepower kicks in and you drive by the putz in the 440 car that was just bragging about how much torque he makes...All you need is good gears and convertor ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dynorad]
#441334
08/20/09 04:03 PM
08/20/09 04:03 PM
Posts: 2,260 IL
furious70
IL
If it turns out you need to do any amount of work to the heads other than put new springs in, you should probably just buy other heads. As was said, the early, small valve heads aren't really worth putting money into.
I would agree, the article ends up with more cam than you'd want, but the engine was making 400hp/430tq with the stock cam and all the other bolt ons.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#441336
08/21/09 02:36 PM
08/21/09 02:36 PM
Posts: 130 Blanchard, OK
Real-Fury
Blanchard, OK
Thanks again everybody. ![](/ubbthreads/images/graemlins/bow.gif) Yep, 400 horses without touching the cam is very respectable.....plenty of HP for me (at least now) and it sound like most of what I bolt on now can remain if I add the right cam and heads later. Butch
