Re: Tooth off on timing chain?........ [Re: racincuda] #440265
08/17/09 10:43 PM
08/17/09 10:43 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I crossed 5/7 before. Very easy to do, especially plugging back into the cap. Same pop that you are experiencing and lack of power.
Re: Tooth off on timing chain?........ [Re: Posest] #440266
08/17/09 11:03 PM
08/17/09 11:03 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I say slop in the distributor. Run a compression check to see if you didn't bend a valve.
Re: Tooth off on timing chain?........ #440267
08/18/09 07:11 AM
08/18/09 07:11 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
just checked, the timing chain (new chain) is dead on. Harmonic balancer is good
I could've sworn I posted this. Just exactly how did you check this?
Yeees, how did you check this? Need more backround, is there something new or is this the old motor you've been running 13s with for years?
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440268
08/18/09 12:09 PM
08/18/09 12:09 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
Different engine, this is a 360. And my 340 runs 12's now. heh
Swapped in new distributor drive gear, the old one was bad. Everything is fine now. Thanks for the input.
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440269
08/18/09 12:18 PM
08/18/09 12:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've seen results like this if the distributor drive gear is off a tooth, it gives all kinds of wonky timing values.
2017 Grand Cherokee Overland
Re: Tooth off on timing chain?........ [Re: patrick] #440270
08/18/09 05:31 PM
08/18/09 05:31 PM
Detroit, MI
Detroit, MI
distributor drive gear location doesn't matter so long as the distributor vacuum advance has room to allow movement for proper timing setting...
Hers must have been severely worn, or maybe she fixed another problem inadvertently when she replaced it...
Re: Tooth off on timing chain?........ [Re: CokeBottleKid] #440271
08/18/09 06:06 PM
08/18/09 06:06 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
it was severely worn
Re: Tooth off on timing chain?........ [Re: CokeBottleKid] #440272
08/19/09 08:25 AM
08/19/09 08:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it does and it doesn't, depending on where you put the plug wires. if the DD gear is off (not pointing to #1 at TDC of #1), but you put the plug wires in the same orientation as usually shown, it will show odd advance numbers, because the rotor isn't synced up with the mark on the balancer. if you orient the plug wires so that at TDC of #1, the #1 plug wire is over the dizzy rotor, things will look OK relative to the timing mark on the balancer.
Re: Tooth off on timing chain?........ [Re: patrick] #440273
08/19/09 11:41 AM
08/19/09 11:41 AM
You should be a politician. The "simple" way to say this is, that it "will be out of time" if the wires are in the wrong hole.
The ONLY REASONS that any factory manual specifies a certain way to install a dist. are:
So the assembly line folks can wrench, repeat
So the vac. advance sits OK
So the plug wires "lay" right
So a tuneup mech. sees what he expects to see.
There ARE a few engines that matter. One series are the GM V6's. On some of these engines, the dist. towers are "paired" two towers closer together, then a wide space, so if you get the wires off just one hole, it just won't run right.
When I got my first car, a 57 Chev 265, I didn't know there was a "right" way. I used to just drop the dist in and go.
Re: Tooth off on timing chain?........ #440274
08/19/09 02:20 PM
08/19/09 02:20 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'm not a politician, I'm an engineer....
