Re: lost reverse. reggin smeggin friggin dang fricken DOH! [Re: John_Kunkel] #439055
08/18/09 06:10 PM
08/18/09 06:10 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
If the VB has compression braking in 1st gear it's LBA and the band is applied/released on each 1-2 shift cycle. The stock servo needs to be rigidized and a heavier spring installed but this might have already been done when the VB was installed.
thanks. yes, the VB came with a much stiffer spring and i purchased the heavy duty retainer for it
Re: lost reverse. reggin smeggin friggin dang fricken DOH! [Re: aarcuda] #439056
08/18/09 07:11 PM
08/18/09 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Even with the correctly modified servo there is a lot of drag as the band releases on the 1-2 upshift, it was never designed to be used on a continuous basis.
