Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438356
08/15/09 01:14 PM
08/15/09 01:14 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
So I'm looking at the 250 pump and find that it's 40 bucks more than the 140 and it doesn't come with a regulator. Man what gives.... I'm about ready to push the car out front and leave it.. I just and at my witts end.
I need a new filter, that's for sure, but now I need a new pump, plus regulator, plus extra line and fittings, to run a return.. Whens it gona stop. see what happens when you try to make something better.. I should have left the blue holley on it and been done with it...
Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438357
08/15/09 01:30 PM
08/15/09 01:30 PM
Deerfield, Ohio
Deerfield, Ohio
SOOOOOOOOOOO nobodys got anything else for me.. Come on guys..
Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438358
08/15/09 01:38 PM
08/15/09 01:38 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
You have to watch that you have adequate atmospheric pressure (venting) on your fuel tank/cell whenever you increase the volume of the pump, the inlet side of the pump should really (ideally) be gravity fed (it really shouldn't "suck"), 2 thinks would cause a pressure differential the first is a restriction the secongd is a lack of atmoshpheric pressure on the fuel in the tank.
Increasing the flow rate can amplify a problem you didn't know you had until you made the swap.
Don't forget G-forces have an effect on your effective flow rate, G forces effectively multiply the mass of the fuel in terms of GPM or Pounds/hr that's why harder launching cars have much bigger pumps than would need to run on a Dyno.
Check the obvious things first....don't throw the baby out with the bathwater.
WIZE
In Car:
Re: Bad night at the track [Re: Cab_Burge] #438359
08/15/09 02:37 PM
08/15/09 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cab`s right.........I don`t remember the exact numbers but my flow #`s went WAY up by adding a second filter but have since dumped the frams and use a Mallory 500 series canister filter. Somethings not right and like stated, I would disconnect the fuel lines at the carb and see how many seconds it takes to flow a gallon......it should be around 20-25 seconds I would think at your et. Good luck.
Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438360
08/15/09 05:22 PM
08/15/09 05:22 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The 250 pump has a return port in the pump body. You don't need to put a return regulator and plumb the related line from the front unless you want too.
The return line can be very short depending on pump and cell location.
Re: Bad night at the track "UPADATE" [Re: RobX4406] #438361
08/15/09 06:19 PM
08/15/09 06:19 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
I always ask this, do you have a liquid filled fuel pressure guage, if so drain the liquid out of it cause they're not accurate.
From what you said the filter maybe the main problem, I would change it and try it first.
Re: Bad night at the track "UPADATE" [Re: Dodgeman67] #438362
08/15/09 07:14 PM
08/15/09 07:14 PM
Deerfield, Ohio
Deerfield, Ohio
No liquid filled gauges.
Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438363
08/15/09 07:27 PM
08/15/09 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Take your gas cap off and re-do your flow test
Re: Bad night at the track "UPADATE" [Re: MR_P_BODY] #438364
08/15/09 08:05 PM
08/15/09 08:05 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
good idea...
Re: Bad night at the track "UPADATE" [Re: Quicksilver440] #438365
08/15/09 08:39 PM
08/15/09 08:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I heard Fram filters cause a big restriction??
Re: Bad night at the track "UPADATE" [Re: Quicksilver440] #438366
08/15/09 08:46 PM
08/15/09 08:46 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Not sure what the problem is but I am
curious what your running in your Duster.
I am building a Big Block Demon and I live
not too far from you.
I would like to run high 9's like you.
Re: Bad night at the track "UPADATE" [Re: MR_P_BODY] #438367
08/15/09 09:26 PM
08/15/09 09:26 PM
Deerfield, Ohio
Deerfield, Ohio
Took cap off with the same results, So I went back to summit and got the Mallory 250 with bypass regulator with all the fittings and hose to do it. I was going to re-use the stock tank, but decided that I already here I might as well stick a cell in it. Plus I guess that at the performance level we're at its a smart move. Plus that pump is just to big to put back where the old pump was so its going in the trunk, along with the new Mallory filter good to 500 gph. So we'll see if thats enough to feed it...
Re: Bad night at the track [Re: 70dusterjohn] #438368
08/15/09 09:37 PM
08/15/09 09:37 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Nope It had fuel in it, I even put more in it.. I am running a fram filter. I was thinks that might be it. But any how its got two -8 off the tank to a Y then to the fram fiter, to the pump with -8 and to the front of the car with -8 to the regulator, and two -8s to the carb..
IMO Fram fuel filters are junk. Further more they are not intended to be suction side filters. I am not at all surprised you are having problems. Your pump is cavitating and will soon be ruined if it isn't already. You need to get a suction side filter to keep crap out of your pump and a pressure side filter for the finer stuff that gets into your carb. RobbMc from this board has everything you need.
Re: Bad night at the track "UPADATE" [Re: Dodgem] #438369
08/16/09 01:58 PM
08/16/09 01:58 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Point of reference. My Mallory 140 sucked 1 gallon in 25 seconds through my OLD Fram and 1/2" lines. That's free-flow to the regulator. I changed to a stated 500gpm stainless mesh canister filter and it flowed exactly the same.
It ran 10.39@128 on E53 last night but was a little rich on that run with 94/95 jets.
Re: Bad night at the track "UPADATE" [Re: 70dusterjohn] #438370
08/16/09 02:28 PM
08/16/09 02:28 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
wish i would have read this sooner.....
take the pump back and go with a magnafuel.
we are running about the same motor set up.
i have 1/2" alum line to a magnafuel regulator (they have 2 outlets)
also run a magnafuel filter. best stuff on the market. (prostock cars run there stuff)
btw i do not work for or get any benifits for pushing magnafuel products.
the only issue is.... they are a little pricey.
i would also install a fuel cell
Re: Bad night at the track "UPADATE" [Re: @#$%&*!] #438371
08/16/09 07:12 PM
08/16/09 07:12 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
It ran [Email]10.39@128[/Email] on E53 last night but was a little rich on that run with 94/95 jets.
THE CORRECT way to plumb a high perf fuel system-any HP fuel system is to use a 100 micron filter before the pump and a 10 micron after. You also need at least a number 10(12 is better for some bigger pumps) or two number 8's y'd on the inbound into the 100 micron filter then outbound to the pump. Anything other than this may well cause the pump to cavitate and by your description that exactly what your's is doing. If you plumb your present pump correctly it probably will do the job.
Re: Bad night at the track [Re: BobR] #438372
08/16/09 08:50 PM
08/16/09 08:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Took the words out of my mouth.
Re: Bad night at the track "UPADATE" [Re: BobR] #438373
08/16/09 09:08 PM
08/16/09 09:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
Inlet plumbing always needs to be bigger(2 sizes) on all fluid pumping systems. Gas pumps need to be gravity fed because gasoline cavitates real easy.
