Re: My turn, What will she run??
[Re: GO_Fish]
#436155
08/20/09 09:38 PM
08/20/09 09:38 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
Okay guys, thanks for the encouragement. I do need to practice shifting manually, as well as go back over things again. I'll have to play to see how much RPMs the engine likes before power falls off. Its going to be a couple weeks until I can get back to working on the car again, need to determine where the coolant leak is and fix that, as well as go over the carb and make sure the secondaries are opening completely, etc. My little brain understands how Carters work for the most part, so I like them. But you may get me to try a Holley in the end. But I think the stock exhaust is here to stay. I like the stock look, and that's part of the deal with the Carter also.
Your loosing at least 25HP by running the Manifolds over a good set of headers, but it still should be breaking 100 MPH....
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: GO_Fish]
#436156
08/21/09 12:50 PM
08/21/09 12:50 PM
Ditch the exh. manifolds they're choking that motor,not a fan of carter carbs. a holley 750 should fit the bill,get yourself some sticky tires street tires are made for the street,as for running an electric fuel pump not a bad idea and certainly won't hurt anything,but just might improve things...
