Re: Modifying Stock K-member [Re: 69CHARGERMD] #435671
08/13/09 01:51 PM
08/13/09 01:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug, now take the stock drag link back out and send it back to Bob, cut the center out, and weld in a CM tube. Saves another couple pounds... Bob's work looks VERY nice.
Jeff
69 GTX 68 Road Runner
Re: Modifying Stock K-member [Re: JERICOGTX] #435672
08/13/09 01:59 PM
08/13/09 01:59 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Jeff,
yup,
he already did the drag link ,,,, and he did the steering shaft,,,,both are now CM...
also,,cut off the old motor mounts,,,and made motor ears,,,
he does great work,,,
thinking of getting some of his tubular A arms soon,,,
Re: Modifying Stock K-member [Re: dustaboy74] #435673
08/13/09 02:06 PM
08/13/09 02:06 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
I was wondering what you guys did to your stock k-members and what you would recommend. Pictures would be great. I am currently building a 74 duster into a drag car and am looking for ideas to what to do with my stock k member. I will most likely becutting the motor mounts off and cutting the k member and boxing it but just wanted to see any other ideas that have worked well for others.
from the looks of it youve removed enough weight already!?!
Re: Modifying Stock K-member [Re: BB70DUSTER] #435674
08/13/09 03:23 PM
08/13/09 03:23 PM
The NB Vermont
dustaboy74 Offline OP
The NB Vermont
Haha, yeah that picture is about 4 years or more old, it since has a new frame from the firewall back and 12 point cage with new wheel tubs and quarter panels, i just need to do some signature updating.
Re: Modifying Stock K-member [Re: dustaboy74] #435675
08/13/09 04:44 PM
08/13/09 04:44 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Some more of Bob's Profab work
Re: Modifying Stock K-member [Re: 70dusterjohn] #435676
08/13/09 04:56 PM
08/13/09 04:56 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
this is what happens when you have too much time on your hands in the off season.
Wait a Minute... The steerings on the wrong side... Looks good, but how is the pan clear...
with all this room i made a special pan. the base is flush with the bottom of the K frame & holds 10 litres which i think is 12 quarts. no running out of oil for me. engine fitment is REAL easy.
Re: Modifying Stock K-member [Re: nss guy] #435677
08/13/09 05:02 PM
08/13/09 05:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When it guts to this point (above) I have to wonder what the point is of keeping any of the front portion. The only purpose is to mount the stock strut rods. Why not use a tube from one side to the other with tabs for a heim-jointed strut rod ??
