Engine Builders...I'm ready to pull my hair out!!!!!! #434977
08/11/09 06:35 PM
08/11/09 06:35 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Ok, I've never built an engine with wire ring pin retainers. I tried getting one in and having no luck. I don't want to mar anything up with screwdrivers. So what is the trick to getting these little things in? What ever happened to a simple snap ring lol......
Thanks in advance
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434978
08/11/09 06:42 PM
08/11/09 06:42 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Stretch it out and roll it in. Like an accordian.
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: bcrproducts] #434979
08/11/09 06:43 PM
08/11/09 06:43 PM
Menomonee Falls
Menomonee Falls
Define stretch it out... like open it up and make it a bigger circle?
SDG Motorsports
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434980
08/11/09 06:54 PM
08/11/09 06:54 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
the directions for them will say to stretch them out about 1/2-3/4" of an inch.. i used to pull them apart more like a full inch.. then slip one end in place and the spin it in.. once you do one of two you will see how easy thay can be..once you pop it into pace it will stay even better since it now is spring loaded where you pulled them apart... it's like a key chain ring.. while it is together it is very hard to get started.. but if you pull them apart alittle then you can get your keys on and off easier..
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: BILLYJAY] #434981
08/11/09 06:57 PM
08/11/09 06:57 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
STOP!
Wire locks are NOT Spiro-lox!
Don't stretch anything.
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434982
08/11/09 06:58 PM
08/11/09 06:58 PM
Menomonee Falls
Menomonee Falls
I think you guys are talking about spiro locks. I just have the round wire ones.
I didn't get any instructions, just a bag with a part number from EEI
SDG Motorsports
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434983
08/11/09 07:27 PM
08/11/09 07:27 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
It's called experience......
But generally, I start them out with bottom of wire lock & place it in the groove around 5 O'clock position, & work my way counterclockwise pressing it in with a large flat blade screw driver, mainly putting alot of downward pressure on the lock around the 12-1 O'clock position. Once you do a few, they are fairly easy. Everything I have made custom now has wire locks in it, as they are superior to a sprio-lock, hence why Cup engines have them in.
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434984
08/11/09 08:08 PM
08/11/09 08:08 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
They are almost easier if you stretch it out like a coil spring, then almost thread it in, but dont thread it in forewards, thread in reverse works the best. im hopeing you are talking spiral locks?
i have gotten pretty decent at it with just my fingers..
OOOOOPS i didnt read far enough, i havent even seen wire locks.
sorry
Kasey
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: Moparnut426] #434985
08/11/09 08:15 PM
08/11/09 08:15 PM
BILLYJAY Offline
BILLYJAY  Offline
Opps..me too.. thought he was talking about spiral locks....
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: BILLYJAY] #434986
08/11/09 09:06 PM
08/11/09 09:06 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Never personally used them but whatched a guy at PRI install and take them out. He was actually pushing the product over spiral locks. He didn't use a screwdriver. It may have been the same guys who make the spiral lock removal tool. I want to say he used something about the equivalent of a long wrist pin. And he just simply popped them in all at once. The removal tool had a few tricks to it and he wasn't going out of his way to explain how it worked. He did say that was the hard part of dealing with wire locks.
I think this guy is tied in with Precision Product in NC.
Leon
Re: Engine Builders...I'm ready to pull my hair out!!!! [Re: Leon441] #434987
08/11/09 09:19 PM
08/11/09 09:19 PM
My engine builder has a tool for those and care is needed during the install.
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434988
08/11/09 09:32 PM
08/11/09 09:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
They're strange little critters, you need to get one end in the groove then work it around. I had to do a bunch of deutz's with them. They tend to fly across the shop when not doing it right... Deutz called them "circlips".
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: buildanother] #434989
08/11/09 10:26 PM
08/11/09 10:26 PM
Menomonee Falls
Menomonee Falls
Well I'm def doing it wrong lol... Several of them have flown around the garage. I haven't got one in yet as I'm waiting on a good explanation.
Ryan I'll try your method and see if I can get it to work.
A few of you guys are confused on I what I have. It's basicly .063 wire i believe made into a circle. I am not using spiro locks (the ones that look like a slinky when you pull them apart)
Wish me luck guys, I may go back out tonight and try again.
SDG Motorsports
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434990
08/11/09 10:28 PM
08/11/09 10:28 PM
Menomonee Falls
Menomonee Falls
Can someone make a wrist pin lock smiley with little c-clips flying everywhere?? I sure could use it
SDG Motorsports
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434991
08/11/09 10:40 PM
08/11/09 10:40 PM
S/ST 3040 Offline
S/ST 3040  Offline
I hope you never have to take them out or you'll be looking for a "throwing piston
and rod through plate glass window smiley".
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: S/ST 3040] #434992
08/11/09 11:28 PM
08/11/09 11:28 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Make sure the pins you have have the chamfered ends for use with the wire rings. I had a new set of pistons and pins come in with the wrong pins. You can get one in but not the other.
Bob
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: fbs63] #434993
08/12/09 01:23 AM
08/12/09 01:23 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Jesse, can you post a pic of this part you are talkeing about, Icant understand what you mean of this wire rings?
Do you mean something like this : http://www.thisoldtractor.com/gtbender/mg_images/starter_solenoid_32.jpg ?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: Georg] #434994
08/12/09 09:07 AM
08/12/09 09:07 AM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
Same basic thing... that one is a OD clip and he is
using ID clips... same thing
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: DemonDust] #434995
08/12/09 10:23 AM
08/12/09 10:23 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just went through this on a Nascar motor I was workng on and after the builder watched me TRY to get those in, he finally pulled out an installation tool that works like a charm. Don`t have a part # but I`m sure you can locate one.
Re: Engine Builders...I'm ready to pull my hair out!!!!!! [Re: MR_P_BODY] #434996
08/12/09 12:44 PM
08/12/09 12:44 PM
Menomonee Falls
Menomonee Falls
Well my fingers are sore, but they are sore from trying to install, still didn't get any in at that point.
I stepped back to give my fingers a rest, went to sears and believe it or not they had the tool to install wire locks!!!!!
Got home and 70 mins later all the locks are in and rods are attached to pistons. I'll take a pic of the tool. My batteries are dead in my cam so I'll have to get some. Once I had this tool it was so easy. If I had this from the start my fingers wouldn't be sore now, and I wouldn't have had to search the garage for wire locks
Thanks for all the help
SDG Motorsports
