Re: Engine Builders...I'm ready to pull my hair out!!!!!!
[Re: DemonDust]
#434997
08/12/09 01:19 PM
08/12/09 01:19 PM
Posts: 1,880 USA
Ron Silva
USA
YES! Show a picture! I will be needing one of those tools soon and there is a Sears nearby.
SRT DEMON ONE SEAT
[Re: rowin4]
#435001
08/12/09 10:33 PM
08/12/09 10:33 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
If you ever want to change out the pistons, how are the snap rings removed? ![](/ubbthreads/images/graemlins/popcrn.gif)
In the close up pic of the piston you can see a little pocket around the 4 o clock position. You can fit a very small screw driver in there and pop the ring very easily out. I tried it and it was no problem.
[Re: rowin4]
#435003
08/12/09 10:44 PM
08/12/09 10:44 PM
Posts: 3,695 nc
emarine01
nc
[Re: DemonDust]
#435005
08/13/09 03:03 PM
08/13/09 03:03 PM
Posts: 388 Michigan
SD800
Every two stroke motor I have built has circlips in them, fun little devils aren't they.even more fun when you drop one down in the crankcase ![](/ubbthreads/images/graemlins/rant.gif) . the tool to install them are great but I just use a screw driver, been doing it since I was 12 when I had to replace a piston in my old Moto-Ski,Snowmobile for you warm weather guys. To remove them just use a pic, most pistons have a notch where you can get behind the circlip and pop it out, wear saftey glasses when doing this or you'll shoot your eye out!!!!
You'll have plenty of time to sleep when your dead, let's go
