Re: What color Loc-Tite for convertor bolts.?
[Re: CokeBottleKid]
#434666
08/12/09 07:20 AM
08/12/09 07:20 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
The bolts torque/stretch is really supposed to do the work of holding the components together, if you're relying on the Loctite to hold it together you gotta wonder why....I use loctite as a measure of insurance so blue should be sufficient on most bolts, I've seen more dampenerer bolts come loose than flywheel bolts but I'd sure never put red loctite on one....
I don't think I've ever seen blue come loose on a NEW bolt that had been PROPERLY cleaned, prepared and torqued to the right spec. Reused bolts are another matter that's why I don't reuse bolts in critical areas.
[Re: Streetwize]
#434667
08/12/09 07:31 AM
08/12/09 07:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the red but I have forgotten to use anything BUT I use my impact to tighten them.... I have had 1 bolt come loose over the years(before I started using the impact on them)
[Re: 69CHARGERMD]
#434668
08/12/09 07:52 AM
08/12/09 07:52 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: beezer]
#434670
08/12/09 06:22 PM
08/12/09 06:22 PM
dartman366
Mt. Vernon, Ohio
If you absolutely, positively dont ever want it to come apart, there is a green loctite that will not let it come apart without a maximum amount of effort.
That is stud and bearing mount, not really intended for nut's and bolt's.
[Re: 360904]
#434671
08/13/09 08:10 AM
08/13/09 08:10 AM
Posts: 3,059 Swamps of South Jersey.
wildcargo
I bet WILD BILL uses BLUE
Some times blue 242, some times red 271 or 277, some times green 290 609, some times purple 222.
[Re: Streetwize]
#434673
08/13/09 10:31 AM
08/13/09 10:31 AM
Posts: 660 San Diego
formula S
San Diego
