Re: What color Loc-Tite for convertor bolts.? [Re: beezer] #434664
08/12/09 05:54 AM
08/12/09 05:54 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I like blue as it's less hassle to remove. Properly applyed red requires 600 degrees to release. Dave
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434665
08/12/09 06:52 AM
08/12/09 06:52 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I use red for critical parts, I'd consider converter bolts critical, save the blue for interior stuff or other non-critical things...
Re: What color Loc-Tite for convertor bolts.? [Re: CokeBottleKid] #434666
08/12/09 07:20 AM
08/12/09 07:20 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The bolts torque/stretch is really supposed to do the work of holding the components together, if you're relying on the Loctite to hold it together you gotta wonder why....I use loctite as a measure of insurance so blue should be sufficient on most bolts, I've seen more dampenerer bolts come loose than flywheel bolts but I'd sure never put red loctite on one....
I don't think I've ever seen blue come loose on a NEW bolt that had been PROPERLY cleaned, prepared and torqued to the right spec. Reused bolts are another matter that's why I don't reuse bolts in critical areas.
WIZE
In Car:
Re: What color Loc-Tite for convertor bolts.? [Re: Streetwize] #434667
08/12/09 07:31 AM
08/12/09 07:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the red but I have forgotten to use anything
BUT I use my impact to tighten them.... I have had
1 bolt come loose over the years(before I started
using the impact on them)
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434668
08/12/09 07:52 AM
08/12/09 07:52 AM
an8sec70cuda Offline
Definitely use red! CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What color Loc-Tite for convertor bolts.? [Re: an8sec70cuda] #434669
08/12/09 07:56 AM
08/12/09 07:56 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
I bet WILD BILL uses BLUE
Re: What color Loc-Tite for convertor bolts.? [Re: beezer] #434670
08/12/09 06:22 PM
08/12/09 06:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If you absolutely, positively dont ever want it to come apart, there is a green loctite that will not let it come apart without a maximum amount of effort.
That is stud and bearing mount, not really intended for nut's and bolt's.
Re: What color Loc-Tite for convertor bolts.? [Re: 360904] #434671
08/13/09 08:10 AM
08/13/09 08:10 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Some times blue 242, some times red 271 or 277, some times green 290 609, some times purple 222.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434672
08/13/09 08:46 AM
08/13/09 08:46 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I use BLUE on DIESEL convertors and have no problems .
Re: What color Loc-Tite for convertor bolts.? [Re: Streetwize] #434673
08/13/09 10:31 AM
08/13/09 10:31 AM
San Diego
formula S Offline
formula S  Offline
San Diego
