Re: What color Loc-Tite for convertor bolts.?
[Re: CokeBottleKid]
#434666
08/12/09 07:20 AM
08/12/09 07:20 AM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
The bolts torque/stretch is really supposed to do the work of holding the components together, if you're relying on the Loctite to hold it together you gotta wonder why....I use loctite as a measure of insurance so blue should be sufficient on most bolts, I've seen more dampenerer bolts come loose than flywheel bolts but I'd sure never put red loctite on one....
I don't think I've ever seen blue come loose on a NEW bolt that had been PROPERLY cleaned, prepared and torqued to the right spec. Reused bolts are another matter that's why I don't reuse bolts in critical areas.
[Re: Streetwize]
#434667
08/12/09 07:31 AM
08/12/09 07:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the red but I have forgotten to use anything BUT I use my impact to tighten them.... I have had 1 bolt come loose over the years(before I started using the impact on them) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 69CHARGERMD]
#434668
08/12/09 07:52 AM
08/12/09 07:52 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
[Re: beezer]
#434670
08/12/09 06:22 PM
08/12/09 06:22 PM
dartman366
Mt. Vernon, Ohio
If you absolutely, positively dont ever want it to come apart, there is a green loctite that will not let it come apart without a maximum amount of effort.
That is stud and bearing mount, not really intended for nut's and bolt's. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 360904]
#434671
08/13/09 08:10 AM
08/13/09 08:10 AM
Posts: 3,059 Swamps of South Jersey.
wildcargo
I bet WILD BILL uses BLUE
Some times blue 242, some times red 271 or 277, some times green 290 609, some times purple 222. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Streetwize]
#434673
08/13/09 10:31 AM
08/13/09 10:31 AM
Posts: 660 San Diego
formula S
San Diego
![](/ubbthreads/images/graemlins/iagree.gif)
