Re: Some Turbo Duster Porn...Headers are done
[Re: joshking440]
#433742
01/06/10 06:37 PM
01/06/10 06:37 PM
Posts: 2,601 ky
headhunter
ky
Re: Some Turbo Duster Porn *UPDATED*
[Re: joshking440]
#433745
02/13/10 12:58 PM
02/13/10 12:58 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#433746
02/13/10 01:02 PM
02/13/10 01:02 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#433747
02/13/10 01:07 PM
02/13/10 01:07 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Re: Some Turbo Duster Porn...*PICS*
[Re: go green]
#433748
02/13/10 03:05 PM
02/13/10 03:05 PM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
Just a little heads up.
Don't run the stock valve train.Even if they fool you into buying the $350 super duty adjuster nuts . Don't run the stainless steel valves ( they should come in pink for how girlie they are . ) Run the 7/16 exhaust and 3/8 in the extra macho push rods from Manton .
After 15 PSI ,Pro stuff only , if not you will be buying stuff twice.
Good luck ,any questions PM me anytime .
Dean
What valves should you run ?
Re: Some more updates on the Turbo Duster Build...
[Re: joshking440]
#433755
02/14/10 11:40 AM
02/14/10 11:40 AM
Posts: 2,601 ky
headhunter
ky
Im with you on the motor plate.... its ugly!!!!!!!!! with a capital UG. My cam is 715 lift and real short on the duration. That ball bearing 88mm is a bad @$$ turbo. Is it a precision?
naw its a garrett got a great deal on one well it might be a great deal ill see when it gets here lol then i get to start on the down pipe and cross over i cant wait to see how your ride comes out it should make a ton of power with b-1s on it
[Re: hemiiroc]
#433759
02/14/10 09:35 PM
02/14/10 09:35 PM
Posts: 778 Sherwood park, Alberta.
go green
Dean
Titanium ..
The cross sectional area of this stainless valve is just not strong enough with the stock depressed center. They are not bad valve , they are just not designed to handle big cylinder preasure.
I talked to Scott Koffel about this and that was the outcome.
