Re: Has anyone run a 904 trans with a 340 or 360?
[Re: Dingmaster]
#433206
08/09/09 10:43 PM
08/09/09 10:43 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
I'm running a 904 behind a 402 in a 66 Dart. Trans was rebuilt, fully manual shift, 5 disk in front pack, and bolt-in sprag. Have about 50 1/4's on it and about 800 miles street use....
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: Noblewk]
#433208
08/09/09 10:52 PM
08/09/09 10:52 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have built and ran them behind every thing from 273 to 402 strokers and have not had but one go bad and it was because the goober (me)kept driving even though he blew a cooler line, he (me) kept running it till it wouldn't move and filled it again and repeated the process several times till he got to the track (fixed leak there)raced all night drove home with trans slipping, next day forward gears were all gone, burn't up the forward clutch. Other than that they hold up great behind most street small blocks when built properly. Use a 5 clutch front drum 4 rear clutches low 1st 2nd gears eliminate wavy snaprings TF1 or TF2 shift kit and you will be good to go for a long time unless you are running big inch motors with W something heads, then you gotta spend some $$$ on them. Ditch the engine to trans brackets, if you insist on running them get some from a 360 car with a 904
[Re: Wedgeman]
#433213
08/10/09 08:52 PM
08/10/09 08:52 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The low 1st gear is a great combination for the short stroke 318/340.
Do not run an old stocker 904 behind a 340. It'll be toast in no time.
[Re: MoparforLife]
#433216
08/10/09 09:07 PM
08/10/09 09:07 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
read the first post guys!!! Lots of people run either trans without the struts, infact it is hard (impossible) to run headers with them in place. The 318 and 340 use the same two struts with either the 904 or 727. There was a change on some 360 blocks that will let you run the same 318/340 strut on one side (passenger?) but a longer 360 strut is needed on the other side (may have the sides mixed up). Don't loose any sleep if you can't find them or fit them in. A torque strap of some kind is not a bad idea either, for more reasons than just no struts.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#433220
08/11/09 01:12 AM
08/11/09 01:12 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Read the first post, guys? The subject TITLE asks if people are using a 904 with a 340/360, then his POST doesn't really match the title because it goes into the braces, not the 904/340/360 title. Some people answered the title, some the post, some both. This post seemed a lot more helpful than most to me.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Dingmaster]
#433221
08/11/09 03:47 AM
08/11/09 03:47 AM
I run a prepped 904 behind my 416 stroker or 360 whichever i have in the car,with excellent results..by the way it was behind my original 318..
