Re: Need 440 head tips [Re: HP2] #43224
12/02/09 01:23 PM
12/02/09 01:23 PM
Clinton Twp. Michigan
coronet1966d Offline
i found a set of unused eddy heads on craigslist for $1100. you figure stealth heads are $900 plus shipping i think i did ok. deals are out there just keep an eye open
Re: Need 440 head tips [Re: R70RUNNER] #43225
12/02/09 05:25 PM
12/02/09 05:25 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
What ignition system are you running? what's the cureve? and was the cam degreed in? If so what did it go in at? Not that heads wouldn't improve your combo... but all done at 5K? Think there's more holding it back then the 906's
MSD6AL with MSD distributor and coil, sorry bu don't remember curve or how the cam was degreed. Easy to check ignition curve (think total timing is around 38 degrees and that it reaches that at 2500 rpm) but a little more work to check cam timing. If I rember correctly it is set at zero.
Well, maybe I wasn't clear enough. I can rev it beyond 6k but you get the feeling that it isn't very happy after 5k. Like it gets out of breath.
I'm using a fresh 3 inch K&N filter with filter top, Hooker Super Comp headers coupled to 3" exhaust with Flowmaster 42's, no pipes after the mufflers.
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Need 440 head tips [Re: HP2] #43226
12/02/09 07:23 PM
12/02/09 07:23 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
My combo was very close to the OP's. The switch to Edelbrocks from my 452's dropped me from 12.5x's @ 105 to 12.0's @ 110, no other changes.
More converter got me another 0.15 and 2 mph, intake swap got me another 1.5mph but nothing as far as ET...
Re: Need 440 head tips [Re: coronet1966d] #43227
12/03/09 12:34 PM
12/03/09 12:34 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Are the 440source heads as good as Edelbrock? They cost less and has original casting meaning that headers and plug area is roomier
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43228
12/03/09 01:30 PM
12/03/09 01:30 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
What size are you Hooker super comps? If they they are 1 7/8" they will not fit the angle plug heads. If they are 2" they will fit better but still close.
Re: Need 440 head tips [Re: GomangoCuda] #43229
12/09/09 06:55 PM
12/09/09 06:55 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
They are 1 7/8". I guess you are talking about Eddies, if I get 440 Source everything would be as original?
71 Duster 340
