carb issue
#431604
08/08/09 05:58 PM
08/08/09 05:58 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi Guys I got my aluminum heads on my 440 and they are awesome. Yet I am having a small issue with the car upon quick accleration. When I nail it, I have a stumble and bog before it takes off. Its a Holley street avenger 770 cfm sitting on a Holley street dominator manifold on a midly built 440 engine. Mike a
1969 Dodge Dart Swinger
Re: carb issue
[Re: Dodgem]
#431606
08/08/09 06:11 PM
08/08/09 06:11 PM
MikeyT
Watertown, WI
I didn't I have a MSD probillit ditstributor. I capped off the advance port. here are a few photo's mike
Re: carb issue
[Re: MikeyT]
#431607
08/08/09 06:15 PM
08/08/09 06:15 PM
Posts: 5,620 long island NY
Ari440
long island NY
do you have that brass fuel filter in there
GET RIDE OF IT
1.39 9.85 - 137 mph
Re: carb issue
[Re: Ari440]
#431608
08/08/09 06:16 PM
08/08/09 06:16 PM
MikeyT
Watertown, WI
Yes I do, Why should i get rid of it.?
Mike
Re: carb issue
[Re: Ari440]
#431610
08/08/09 06:20 PM
08/08/09 06:20 PM
MikeyT
Watertown, WI
Got it, I'm guessing I might be making a run to the part store tonight.
Mike
Re: carb issue
[Re: MikeyT]
#431611
08/08/09 06:24 PM
08/08/09 06:24 PM
Ari440
long island NY
that fuel filter it cost me a tow home
it migth even be your problem , but it happened to me
1.39 9.85 - 137 mph
Re: carb issue
[Re: Dodgem]
#431613
08/08/09 06:41 PM
08/08/09 06:41 PM
MikeyT
Watertown, WI
I think if i remember correctly its all in at36 degrees at 2500 rpms.
Mike
Re: carb issue
[Re: MikeyT]
#431614
08/08/09 06:45 PM
08/08/09 06:45 PM
Ari440
long island NY
you may need to install lighter springs in the MSD try to get full advance at 1000-1200 rpm
1.39 9.85 - 137 mph
Re: carb issue
[Re: Ari440]
#431615
08/08/09 06:51 PM
08/08/09 06:51 PM
MikeyT
Watertown, WI
Won't that make it monster to start?
Mike
Re: carb issue
[Re: Ari440]
#431617
08/08/09 07:00 PM
08/08/09 07:00 PM
MikeyT
Watertown, WI
Ok, I'll give it a try. Can you tell me why you think it will work?
Mike
Re: carb issue
[Re: MikeyT]
#431618
08/08/09 07:13 PM
08/08/09 07:13 PM
Ari440
long island NY
I have a 72 duster and a 72 road runner
the road runner had a bad igntion swicth
both cars have tach drive distributers
duster is locked / msd retard box too
road runner is centrifical advance
at the time didnt know what the problem was and swapped distributers
the locked distributer ( from the duster ) barely started the road runner but the centrifical advance was fine *38
with a starter butten on the starter relay it whould start but not by the ignition swich
1.39 9.85 - 137 mph
Re: carb issue
[Re: MikeyT]
#431621
08/08/09 09:01 PM
08/08/09 09:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Check the basics first, timing, then give the carb a shot (engine off) to make sure you have a full pump shot right from the instant you start moving the throttle
Re: carb issue
[Re: MR_P_BODY]
#431622
08/08/09 09:06 PM
08/08/09 09:06 PM
MikeyT
Watertown, WI
Ok, now I'm brain farting here. I must be forgetting something. I remember that with old vaccuman advance Dizzy. I first set intial, then plugged vaccum advance before bringing rpm's up to 2500 and set total for 35 degrees (10+)
I was all ready to do it, but forgot how to do it on the msd dizzy! Is it as simple as me bringing up the rpm's to 1200 rpms and set my timing to 35 degrees?
Mike
Re: carb issue
[Re: MikeyT]
#431623
08/08/09 09:23 PM
08/08/09 09:23 PM
MR_P_BODY
Mike
Bring up the rpm's to 3000 and see what the total timing is.... then back at idle check it again... then slowly bring up the revs to see when it starts to increase the timing and when it reaches full timing You might need more initial and less advance timing, check it and tell us what you get
Re: carb issue
[Re: RobX4406]
#431626
08/09/09 01:17 AM
08/09/09 01:17 AM
MikeyT
Watertown, WI
WEll this has been kind of a long frustrating night. I brought intital up to 16 degrees and it ran well, but it was kind of a crap shoot. I set advance at 35 total and it seems to be working, but what a pain in the ass!
Mike
