1974 Roadrunner K frame isolators #430129
08/06/09 04:46 PM
08/06/09 04:46 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
Helping a friend re-do his front end. His K frame isolators need to be replaced. Does anyone know where I can find these? Also, someone told me to replace them with a solid mount , has anyone done this. Pros and Cons of doing this.
Many thanks
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430130
08/06/09 04:49 PM
08/06/09 04:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
solid mounts available around, also poly. Not rubber thought.
IF YOU ASK ME... poly... solid will be fine like earliers models but after ride a Dart without isolation and my car ( with RUBBER pices made in Venezuela ), I wouldn't replace the comfort of a rubber piece... POLY as much, but never solid.
thats just my opinion. Of course Caracas streets are a mess.
Rubber pieces also keeps a safer unibody.
( I am one of those who thinks that comfort and performance can be hand in hand, ESPECIALLY on streets even with a HOT street car... I would find the way to fit an A/C on an Hemi car... yes )
Re: 1974 Roadrunner K frame isolators [Re: NachoRT74] #430131
08/06/09 04:53 PM
08/06/09 04:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Rubber was available last time I checked at the dealer but it has been a few years. They were not cheap IIRC 3642851 and 3642852
Re: 1974 Roadrunner K frame isolators [Re: mopars4ever] #430132
08/06/09 05:34 PM
08/06/09 05:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
last time I saw them on ebay, went at $250... 3 or 4 YEARS AGO
Re: 1974 Roadrunner K frame isolators [Re: NachoRT74] #430133
08/06/09 05:42 PM
08/06/09 05:42 PM
Ont, Canada
Ont, Canada
That's almost the cost of the car!!!!!
I hope there are alternatives
Anyone else
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430134
08/06/09 06:02 PM
08/06/09 06:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as I told you, poly... make a search on suspension websites and you will find them. Not that hard
Re: 1974 Roadrunner K frame isolators [Re: NachoRT74] #430135
08/06/09 07:11 PM
08/06/09 07:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought the poly ones from just suspension several years ago. They work fine and are a bit cheaper than the solid mounts. If I had to do it again I would probably just go solid instead. Nothing wrong with the poly mounts though, just I would rather replace it with a non-wear item.
Re: 1974 Roadrunner K frame isolators [Re: DaytonaTurbo] #430136
08/06/09 07:21 PM
08/06/09 07:21 PM
Ont, Canada
Ont, Canada
I just checked Just Suspension's website and I could not find them. I will try and call them tomorrow. However I did find the solid aluminum ones on Firm Feel's website for $198.
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430137
08/06/09 07:52 PM
08/06/09 07:52 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i would replace with solid. previous model years all had the k frame directly mounted to the front sub frame. no real reason not to do it this way on a 74
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430138
08/06/09 11:51 PM
08/06/09 11:51 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
i put the solids in a 73 RR. No complaints. The ride doesnt really seem any harsher to me.
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430139
08/07/09 12:07 AM
08/07/09 12:07 AM
Manitoba, Canada
Manitoba, Canada
Check out this link at mancini, if I understand this right they show the poly version for 50 bucks.
http://chucker54.stores.yahoo.net/fjmlabbososu.html
I was sure I'd gotten my poly set from just suspension, but this was like 7 years ago. Could have been energy suspension or espo or maybe it even was mancini. I'll have to dig up the box which I know I still have.
Re: 1974 Roadrunner K frame isolators [Re: DaytonaTurbo] #430140
08/07/09 12:57 AM
08/07/09 12:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
http://www.suspension.com/moparcar.htm
several vendors and mostly sure several qualities and specs. I have seen them, but can't recall all the vendors
firmfeel.com mostly sure have them too in poly and solid
by the wear fact... if rubber parts got 30 years although maybe 20 were in really full good conditions, poly must be on 40-50 years life. I don't think is something to worry about
Re: 1974 Roadrunner K frame isolators [Re: NachoRT74] #430141
08/07/09 07:54 AM
08/07/09 07:54 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
board member cudazappa sells billet aluminum ones (search the classifieds)
ESPO.com sells poly ones pretty reasonably priced (like $60/set)
CUDAZAPPA's solid isolators are the first ad, also shown are aluminum t-bar bushings
2017 Grand Cherokee Overland
Re: 1974 Roadrunner K frame isolators [Re: patrick] #430142
08/07/09 02:49 PM
08/07/09 02:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
You probably wouldn`t see any wear on them in your lifetime.
Re: 1974 Roadrunner K frame isolators [Re: mopars4ever] #430143
08/07/09 03:47 PM
08/07/09 03:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thats what I say
Re: 1974 Roadrunner K frame isolators [Re: NachoRT74] #430144
08/07/09 04:18 PM
08/07/09 04:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
thats what I say
huh!
Re: 1974 Roadrunner K frame isolators [Re: mopars4ever] #430145
08/08/09 12:16 AM
08/08/09 12:16 AM
Manitoba, Canada
Manitoba, Canada
Probably. After 6 years of daily driving the poly mounts still look like new. No regrets, I would just like to try the solid mounts in my car to feel if they'd make an ounce of difference over the poly mounts. Though mine's an original small block car with a front sway bar. I'm sure a big difference in front end rigidity there than a big block car with that huge cutout on the passenger inner fender.
Re: 1974 Roadrunner K frame isolators [Re: patrick] #430146
08/08/09 01:30 PM
08/08/09 01:30 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I just bought a set of the solids from Gary (Cudazappa) and they are sweet. I have a volare and need them to stiffen up the front to make it leave better. These things are seriously nice.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 1974 Roadrunner K frame isolators [Re: StandOnIt] #430147
08/08/09 07:24 PM
08/08/09 07:24 PM
Ont, Canada
Ont, Canada
Thanks everyone for all the leads. I will educate my cousin on the two ways he can go , and go from there.
Re: 1974 Roadrunner K frame isolators [Re: gygeneral] #430148
08/08/09 09:47 PM
08/08/09 09:47 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Be aware of rust around the frame where the mounts go.
