Re: Tell me about installing & using wide-band O2 sensor!
[Re: BradH]
#429850
08/12/09 01:56 PM
08/12/09 01:56 PM
BradH
Any known - or common - issues w/ the FAST system?
How long has it been since the Innovate LM-1 been replaced by the LM-2? Are new LM-1s still available?
Also... my "big dummy" question of the day... where do you route the sensor cable so as to be able to read the display inside the car? Do you have to run it up through a (new?) hole in the floor pan?
[Re: Tig]
#429852
08/12/09 02:41 PM
08/12/09 02:41 PM
Posts: 4,071 Mo.
racerx
Mo.
I've spoke to a few race guys who run the FAST and Innovate stand alone systems. They run leaded race fuel but change the sensor every season, a couple are blow thru turbo VW guys. The only real difference, I'm told, is the response of the sensor. The units calibrate themselves every time they are switched on as far as I'm aware. Another tip they told me was to mount the sensor at least 12 inches from an open header end as the turbulance can give false readings. I'll post results as soon as, but I'll have to fab fancy header extensions as the ends are close to the 'box crossmember / mount. I'm also ordering an extra sensor mount and 2 bungs. Thanx
Tig can u also post pic. of you're install.Thax.
[Re: convertriple]
#429854
08/13/09 03:27 AM
08/13/09 03:27 AM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Can the sensors handle some ethanol, like 10-20% they put in the premium pump fuel?
Does fuel type alter the ratio you are aiming for?
Good question ....
And how about E85 ? ... I have zip experience with it but on some of the posts I hear people running E85 as lean as 12.5 to one and still making good power.
[Re: BeEtLeJuIcE !]
#429855
08/13/09 05:21 AM
08/13/09 05:21 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
The Haze ran AV-gas for years, seems to take a while for the lead to cause damage. Wideband sensors are lambda sensors, meaning it reads A/F(stoich)/A/F(actual), so depending on what the display is setup for (typically gasoline) it doesn't matter whether you run pump gas, methanol, or E85 if it's reading 14.7 then that's stoich. When I get a steady income this will be the one I buy for general tuning. http://14point7.com/Widebands/JAW_1_041/JAW_1_041.htm
[Re: racerx]
#429856
08/13/09 01:17 PM
08/13/09 01:17 PM
Posts: 2,924 A shed in England
Tig
A shed in England
I will do, but don't expect anything soon. I've only just placed the order with a buddy and we are waiting on other stuff to be collected before it all gets sent over here. I figure a couple of months max, by which time our season is over so its an off season thing to install. Track results won't be 'till next year
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
