How many horns can be run on a vehicle? #429125
08/05/09 11:55 AM
08/05/09 11:55 AM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
Can more than the 2 factory horns be operated on a vehicle before it starts causing fuse blowing problems? I'd like to add 2 of those super loud of Cadillac horns to the 2 existing horn I have on my Jeep just for kicks.....will that work?
Re: How many horns can be run on a vehicle? [Re: BarryBum] #429126
08/05/09 12:00 PM
08/05/09 12:00 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just order the train horn kit!
The true redneck of horns!
It gives old ladies heart attacks.
Snap your neck, mega G-force launch, is all I want!
Re: How many horns can be run on a vehicle? [Re: BDS871Cuda] #429127
08/05/09 12:02 PM
08/05/09 12:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you used a relay you should have no trouble at all.
Re: How many horns can be run on a vehicle? [Re: stumpy] #429128
08/05/09 12:12 PM
08/05/09 12:12 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep, just use relays and you can have all the horns you want. (use the horn power wire to trigger the relay, and you are set)
Re: How many horns can be run on a vehicle? [Re: BDS871Cuda] #429129
08/05/09 12:28 PM
08/05/09 12:28 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Down to just a blue car now.
Re: How many horns can be run on a vehicle? [Re: BDS871Cuda] #429130
08/05/09 06:12 PM
08/05/09 06:12 PM
I want the one off of a fire truck except I'd probably be the one getting the heart attack. iirc JCW has the train ones
Re: How many horns can be run on a vehicle? [Re: 68HemiB] #429131
08/07/09 03:08 AM
08/07/09 03:08 AM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
I'd hate to get rear ended with that.
