Re: QUEST FOR TENS
[Re: viperblue72]
#427344
08/03/09 02:07 PM
08/03/09 02:07 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
What cam are you running?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: QUEST FOR TENS
[Re: Scamp408]
#427347
08/03/09 03:05 PM
08/03/09 03:05 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Without know any more specs for the cam and converter, it's a little on the weak side for a 408. (about 395 HP) It might be in there already with some sharp tuning but, the heads, more than likely, have the HP corked up. Good tire/gear selection. ![](/ubbthreads/images/graemlins/thumbs.gif) What are the rest of your cam specs and CR?
Re: QUEST FOR TENS
[Re: S/ST 3040]
#427348
08/03/09 05:50 PM
08/03/09 05:50 PM
Posts: 2,709 NJ central
Scamp408
NJ central
INTAKE: Duration: 304º Lift: .545 EXHAUST: Duration: 310º Lift: .558 lupo 9.5 4200 stall convert The motor was orig built for the 12s so I know the cam is weak.I talked to lupo about going to an 8in he said I may p/u a 10th but he thought is wasnt worth it.
Re: QUEST FOR TENS
[Re: Ian]
#427352
08/03/09 10:55 PM
08/03/09 10:55 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I would change the cam loosen the conv. to 5,400 and put 4.30 or 4.56 in it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: QUEST FOR TENS
[Re: bdaz smblk]
#427353
08/03/09 11:33 PM
08/03/09 11:33 PM
S/ST 3040
Since it's 11.4:1 CR. I'd use a cam like 262º/266º @ .050, 108º LSA, installed +4º .590"+ lift. Open up the heads/valve job A little more stall wouldn't hurt but, not necessary. I'd keep the 28"tire/4.10 gear......especially w/TTI (1 5/8"?) With bigger headers, open exhaust probably 10.70-10.80 ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: QUEST FOR TENS
[Re: Quicktree]
#427356
08/04/09 06:52 AM
08/04/09 06:52 AM
Jacob Pitt
Mansfield, Tx
I also don't think putting the Indy heads on with that cam, headers, carb, stall and compression would do just a whole lot for you in terms of e.t.
Re: QUEST FOR TENS
[Re: justinp61]
#427360
08/04/09 08:55 AM
08/04/09 08:55 AM
S/ST 3040
IMHO you have a couple issues, smallish carb and small headers and the 60' seems a little slow. At you're weight it should be in the 6s in the 1/8 now. My old hydraulic cammed, pump gas 340 went mid 7.20s with a best 1.533 60', it normally went 1.55-1.57. 69 Dart, 3300#, 9.5" 4400 converter with 4.30 gears. If you're chassis was sorted out you'd be there now .
He'd have to be a real chassis whiz to hit 10s @ 117.
