Re: QUEST FOR TENS
[Re: S/ST 3040]
#427364
08/04/09 11:06 AM
08/04/09 11:06 AM
Posts: 2,709 NJ central
Scamp408
NJ central
Sorry I have the reg tti for the eddies and the 1-7/8 for indys INTAKE
Opens: 21.0 BTDC Closes: 49.0 ABDC
EXHAUST
Opens: 59.0 BBDC Closes: 15.0 ATDC
LOBE SEPERATION
108º
Duration at .050"
Intake: 250 Exhaust: 254
LOBE LIFT
Intake: .363 Exhaust: .372
Re: QUEST FOR TENS
[Re: S/ST 3040]
#427365
08/04/09 11:13 AM
08/04/09 11:13 AM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I think, as others have mentioned, a cam swap might be in order, among other things. Everything has to be right and matched to get them to run how they are capable of. My old 416 combo was a 260/266 flat tappet, 560/580 lift that i ran 1.6 rockers on(made it 598/623)it was on a 108, in at 104. Weiand excellerator, mildly ported eddies(maxed at 274 at 600 lift) TTI 1 5/8 step to 1 3/4 headers 8 inch convertor that flashed about 4900-5000, 28 inch tire with 4.30 gears(they were too steep, would have liked 4.10 like you have better)had a 1025 race demon, that was a great carb for that combo, this all was in a 3400+ pound car with full interor and bench seat, column shift at 11.8 compression. car went 10.74 at 123.70, through the mufflers so at 3150 pounds, it should be extremely easy to get in the 10's with a combo similar to the above, even if the heads are just mildly cleaned up. The above all said, there is no way i would lean on the combo you have with those eagle I beam rods amd that cast crank for any extended period of time and not expect you arent going to drive over the bottom end at some point in the very near future. So, i would step up the cam to something with 600 corrected lift and 260 ish on the intake, consider going to a 950 ish carb and perhaps more convertor, after you fortify the bottom end to handle the expected power you are going to have on tap..... I took that bottom end on my 416 above( h beams and cast crank and threw w5's on it) and changed nothing except headers and intake and went 10.30's with that swap,and proceeded to drive over the crank and ruin the shortblock, so your indy's should net you a similar gain if you have everything corect with the eddies you are currenty using and make that swap. Strokers like cam and carb, you are lacking on both currently, as well as having a solid shortblock foundation to build from.I might leave it as is until you get a good shortblock under it. Good luck
Re: QUEST FOR TENS
[Re: S/ST 3040]
#427377
08/04/09 01:40 PM
08/04/09 01:40 PM
B3422W5
Portage,michigan
SIR” I-Beam Connecting Rods
Eagle “SIR” connecting rods are forged from 5140 steel and utilize ARP 3/8” capscrew-style bolts with alignment sleeves for easier assembly. Packaged in weight-matched sets (+/- 2g). Sizing is performed by in-house CNC equipment. “SIR” rods are the perfect choice for engines UP TO 500 HP.
Re: QUEST FOR TENS
[Re: B3422W5]
#427378
08/04/09 01:57 PM
08/04/09 01:57 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I ran a set for 125 passes and was glad they made it through the season. It's not worth the risk for me to test their longevity.
I was glad to sell them for $50
Re: QUEST FOR TENS
[Re: justinp61]
#427380
08/04/09 02:18 PM
08/04/09 02:18 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I have some SIR rods in the motor I built for my Mom's Duster. This was before I heard all the horror stories. That motor doesn't make all that much power since I was told by her that she didn't want it to be to fast that she had to wear a fire jacket or put a roll bar in the car. Was shooting for 7.70's in the 1/8th and wound up with a [Email]7.39@91[/Email] so far in great air. She only turns it to 5500rpm and motor has been together for two seasons now. I wish I had put the Scat's in it, shoot I wish I had known about the Scat's beforehand.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: QUEST FOR TENS
[Re: justinp61]
#427381
08/04/09 02:20 PM
08/04/09 02:20 PM
S/ST 3040
Mine obviously lived for the time I used them. I guess it's possible the broken SIRs I've seen were just bad heat lot flukes but, I took them out at the end of the year.........after seeing several posts on the subject. I ran Ross 99626 domes (567 grams) 7400 RPM every shift and the occasional 8000 limiter burnout.........so they can't be complete junk. Just didn't care to test what others had already found out. Personally, I'd never use them again.......even in somebody else's engine.
