'71 B & E with power disc brakes & 11" rear drums??? #427020
08/03/09 12:46 AM
08/03/09 12:46 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I have seen several e-bodies recently with 11" rear drums on cars with power disc brakes. Under what conditions did this happen? Also, in '69 & '70 the "normal" rear springs for cars with performance axle packages were HEMI springs, at some point in '71 it appears most 383 & 340 cars with A31 (3.91s) & A36 (3.55s) recieved the STANDARD rear springs. Anybody know why?
'71 ebodies with power disc brakes B41 & B51 (10" vs. 11" rear drums):
BS/JS w/DRUM BRAKES were 11" all around
BS23 - 383 4bbl auto A/C 2.76 open - F70-14 w/B41 & B51
(disc,??") AXLE - 101 small U joint T-BARS - 779/778 RR SPRINGS - 044/044
BS23 - HEMI 4-spd 4.10 S/G - F60-15 w/B41 & B51
(disc,??") AXLE - 026 T-BARS - 781/780 RR SPRINGS - 034/024
BS23 – 440+6 auto 4.10 S/G – E60-15 w/B41 & B51
(disc,??") AXLE – 026 T-BARS – 781/780 RR SPRINGS – 034/024
BS23 – 440+6 auto 4.10 S/G – F70-14 w/B41 & B51
BS23 - HEMI 4-spd 3.54 S/G - F60-15 **** MANUAL DRUM BRAKES ****
(11",11")AXLE - 025 T-BARS - 781/780 RR SPRINGS - 034/024
BS23 - 440+6 4-spd 3.54 S/G - E60-15 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 025 T-BARS - 781/780 RR SPRINGS - 034/024
BS23 - 440+6 4-spd 3.54 S/G - E60-15 w/B41 & B51
(disc,11") AXLE - 025 T-BARS - 781/780 RR SPRINGS - 034/024 (025 AXLE has 11" rear drums)
BS23 - HEMI 4-spd 3.54 S/G - F60-15 w/B41 & B51
(disc,10") AXLE - 024 T-BARS - 781/780 RR SPRINGS - 034/024
BS27 - 440+6 4-spd 3.54 S/G - F70-14 w/B41 & B51
BS27 - 340 auto 3.91 S/G - F70-14 **** POWER DRUM BRAKES ****
(11",11") AXLE - 023 T-BARS - 779/778 RR SPRINGS - 045/045
BP23 - 383 4bbl auto 3.91 S/G - F70-14 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 023 T-BARS - 779/778 RR SPRINGS - 044/044
BS23 - 340 auto 3.91 S/G - E60-15 w/B41 & B51
(disc,10") AXLE - 022 T-BARS - 781/780 RR SPRINGS - 034/024
BS27 - HEMI auto 3.55 S/G - F60-15 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 021 T-BARS - 781/780 RR SPRINGS - 034/024
BS23 - 383 4bbl auto 3.55 S/G - ???-?? w/B41 & B51
(disc,11") AXLE - 021 T-BARS - 779/778 RR SPRINGS - 044/044 (JIM V's 021 has 11" rear drums) tires - ??
BS23 – 340 auto 3.55 S/G – F70-14 **** MANUAL DRUM BRAKES ****
(11",11") AXLE – 021 T-BARS – 779/778 RR SPRINGS – 044/044
BS23 - 340 4-spd 3.55 S/G - F70-14 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 021 T-BARS - 779/778 RR SPRINGS - 044/044
BS27 - 340 auto A/C 3.55 S/G - F70-14 w/B41 & B51
(disc,10") AXLE - 020 T-BARS - 779/778 RR SPRINGS - 045/045
BS23 – 340 4-spd 3.23 S/G – F78-14 **** MANUAL DRUM BRAKES ****
(11",11") AXLE – 019 T-BARS – 779/778 RR SPRINGS – 044/044
JH27 - 383 4bbl auto A/C 3.23 S/G - F70-14 w/B41 & B51
(disc,11") AXLE - 017 T-BARS - 779/778 RR SPRINGS - 045/045 (017 AXLE has 11" rear drums)
BS23 – 340 4-spd 3.23 S/G – E60-15 w/B41 B51
(disc,11") AXLE – 017 T-BARS – 779/778 RR SPRINGS – 044/044 (017 AXLE has 11" rear drums)
BS23 - HEMI auto 3.23 open - F60-15 w/B41 & B51
(disc,10") AXLE - 016 T-BARS - 781/780 RR SPRINGS - 034/024
BS23 - 383 4bbl auto A/C 3.23 open - F70-14 w/B41 & B51
(disc,10") AXLE - 016 T-BARS - 779/778 RR SPRINGS - 044/044
BS23 - 383 4bbl auto 3.23 open - F70-14 w/B41 & B51
BS27 - 340 auto 3.23 open - F70-14 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 015 small U joint T-BARS - 779/778 RR SPRINGS - 045/045
JH23 - 340 3-spd 3.23 open - E60-15 **** MANUAL DRUM BRAKES ****
(11",11") AXLE - 015 small U joint T-BARS - 779/778 RR SPRINGS - 044/044
BS23 – 340 auto 3.23 S/G – F70-14 w/B41 B51
(disc,10") AXLE – 014 small U joint T-BARS – 779/778 RR SPRINGS – 044/044
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427021
08/03/09 11:00 AM
08/03/09 11:00 AM
New Jersey Bada Bing
bremotorsports Offline
Dan,
I don't know if any sense will EVER be made out of this deal.
FYI: The Juliano BS27V1B is a column shift automatic, front disc brakes, with an 026 axle (4.10 Dana) per the broadcast sheet, but has always had the 11" rear brakes. The entire history from new is known.
One of the other cars I referenced is BS23V1B370411. Manual trans and built for Canada. 11" rear brakes from new.
Bill Rolik
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: bremotorsports] #427022
08/03/09 11:22 AM
08/03/09 11:22 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
my BS23V1 05/26/71 build date 3.55 8.75 727auto front disc/11" rear drums has the 024/034 springs - Joe
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427023
08/03/09 11:31 AM
08/03/09 11:31 AM
cataclysm80 Offline
cataclysm80  Offline
Good to see this got its own thread.
Tav
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: shakerjoe] #427024
08/03/09 11:38 AM
08/03/09 11:38 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Joe, does your car have a b'cast sheet? Is the AXLE 021?
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427025
08/03/09 11:41 AM
08/03/09 11:41 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Has anybody seen a '71 4.10 e-body with 10" rear drums, or a b'cast with other than 026 for the rear axle?
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: cataclysm80] #427026
08/03/09 11:43 AM
08/03/09 11:43 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Tav
this one got de-railed - T/A AAR front disc brakes?
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427027
08/03/09 11:50 AM
08/03/09 11:50 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
no sheet, where would I look for the 021 - have pics of my brake drums, but they're too big , don't know how to resize them - Joe
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: shakerjoe] #427028
08/03/09 11:56 AM
08/03/09 11:56 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I don't know if the 021 would be found anywhere, I think your 11" rear drum 8-3/4 w/3.55s would be the same AXLE as Jim V's "hemi71x" original 383 car.
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: shakerjoe] #427029
08/03/09 12:15 PM
08/03/09 12:15 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Here are pics of "shakerjoe's" 11" rear drums, complete with remnants of the original red paint.
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427030
08/03/09 01:31 PM
08/03/09 01:31 PM
cataclysm80 Offline
cataclysm80  Offline
Does this help?
All 71 'Cudas
BS23V1 – 440+6 auto 4.10 S/G – F70-14
SPD 216 - B41 B51 - P-SHAFT 775 - manual steering
BS23V1 – 440+6 auto 4.10 S/G – E60-15
SPD 518 - B41 B51 - P-SHAFT 775 - manual steering
BS23H1 – 340 4-spd 3.23 S/G – E60-15
SPD B09 - B41 B51 - P-SHAFT 636 - power steering
BS23H1 – 340 auto 3.55 S/G – F70-14
SPD 311 - B11 - P-SHAFT 636 - manual steering
BS23H1 – 340 4-spd 3.55 S/G – F70-14
SPD 105 - B11 - P-SHAFT 636 - power steering
BS23H1 – 340 auto 3.23 S/G – F70-14
SPD A16 - B41 B51 - P-SHAFT 134 - power steering
AXLE – 014 T-BARS – 779/778 RR SPRINGS – 044/044
BS23H1 – 340 4-spd 3.23 S/G – F78-14 (T34)
SPD 520 - B11 - P-SHAFT 636 - quick ratio power steering
Tav
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: 6bblgt] #427031
08/03/09 04:02 PM
08/03/09 04:02 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
thanks Dan
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: shakerjoe] #427032
08/03/09 06:50 PM
08/03/09 06:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Read the images at this link, there are at least two pages that mention the 11' drums for the E-Bodies, but it would be better to read the whole thing instead of just grabbing those pages out of context, so.....
http://www.hamtramck-historical.com/vintageAdvertising/1971PlymouthPressRelease-02.shtml
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Alaskan_TA] #427033
08/03/09 07:10 PM
08/03/09 07:10 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Barry
The only time the 11" rear drums are mentioned is when front drums are involved.
There is mention of all Cuda's being equipped with HD suspension and 11" brakes. Could they be referring to drum brakes all around?
From the 71 Plymouth Salesman's Guide
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Snoopy] #427034
08/03/09 07:28 PM
08/03/09 07:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It could be, I can not find anything else on it.
Yet......
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Alaskan_TA] #427035
08/03/09 07:31 PM
08/03/09 07:31 PM
Snoopy Offline
Snoopy  Offline
Here is listing from the 70-71 Factory Part Book for the rear drums.
70 Finned
71 Not Finned
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Snoopy] #427036
08/03/09 08:57 PM
08/03/09 08:57 PM
71 11" rear drums (both Motor Wheel and Kelsey Hayes) are fin type.
Bill Rolik
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: bremotorsports] #427037
08/03/09 10:50 PM
08/03/09 10:50 PM
Snoopy Offline
Snoopy  Offline
Odd that they make mention of it for 70 and not 71, especially with two different part numbers. Maybe the part numbers reflected the two different manufacturers?
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Snoopy] #427038
08/03/09 10:56 PM
08/03/09 10:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Possible that by '71 finned was "assumed" also?
It seems like they tended to drop abjectives now & then once items were no longer "new".
Re: '71 B & E with power disc brakes & 11" rear drums??? [Re: Snoopy] #427039
08/03/09 11:25 PM
08/03/09 11:25 PM
I have both drums on hand, and both are fin type. I also have aftermarket Budd-made drums, and they are fin-type as well. They probably just forgot to print the description, as has happened so many times before. Chrysler was also notorious for making assumptions that the parts department personnel would know how to interpret the publications, as well as the inevitable typo errors.
BR
