Page 2 of 5 1 2 3 4 5
Re: Hood scoop or cowl hood? [Re: an8sec70cuda] #426430
08/03/09 02:08 PM
08/03/09 02:08 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I would have to wait till I get off to e mail them but they are all on my Photobucket site
Re: Hood scoop or cowl hood? [Re: WILD BILL] #426431
08/03/09 11:15 PM
08/03/09 11:15 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Don't listen to all the old timers.Cowl hoods ROCK!If a car is faster than 9.50s it gets hard to keep the hood from lifting.
Fred keep the cowl it looks kick A$$.Lenny
Re: Hood scoop or cowl hood? [Re: 8secDart] #426432
08/03/09 11:59 PM
08/03/09 11:59 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Got that station wagons in the 9.5's do ya?
Re: Hood scoop or cowl hood? [Re: ScottSmith_Harms] #426433
08/04/09 12:06 AM
08/04/09 12:06 AM
8secDart Offline
8secDart  Offline
You just keep building them old A$$ carbs and leave the fast stuff to me.Lenny
Re: Hood scoop or cowl hood? [Re: ScottSmith_Harms] #426434
08/04/09 12:11 AM
08/04/09 12:11 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Re: Hood scoop or cowl hood? [Re: an8sec70cuda] #426435
08/04/09 01:33 AM
08/04/09 01:33 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
For a cowl hood to work, the rear of the cowl scoop needs to be close to the windshield. I only have enough room to get my fingers b/t my windshield and the back of the cowl scoop. If it doesn't get close to the windshield, it won't pull any air in.
I switched from a six pack hood to the cowl hood and saw no change in ET or MPH. Both were sealed to the carburetor.
The problem I had with the 6 pack scoop was that above 120 mph the hood tried to lift off the car REAL bad. CHIP
So your cowl hood is sealed to the carb?
As I understand gap between windshield and cowl hood scoop should be around one inch or so?
Do you have pics down of the hood? I`d really like to see how you solved this cowl hood sealing to the carb?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Hood scoop or cowl hood? [Re: cbarracuda] #426436
08/04/09 01:37 AM
08/04/09 01:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Don't worry Lenny, I can handle both just fine
*Hey Carlos, you agree? When he said "old guys", you do realize that you are a member of that club too right?
Re: Hood scoop or cowl hood? [Re: Georg] #426437
08/04/09 07:47 AM
08/04/09 07:47 AM
an8sec70cuda Offline
I used to have the carb sealed to the scoop when I had the wedge motor in the car, don't think I have any pics of the air pan I made for it. With the hemi, the carb sits so high that it's a REAL pain to seal it up, so I do not have it sealed to the carb now. I'm gonna attach a pic, see if it works. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hood scoop or cowl hood? [Re: an8sec70cuda] #426438
08/04/09 08:31 AM
08/04/09 08:31 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I personally think that most forward facing scoops are hidious. I have seen Six Pack and Hemi scoops trying to get airborne at speed. I like the "sleeker" look of a cowl for my application. The thought of goin' 150+ with a huge sail on my hood doesn't appeal to me.
Steve
Photobucket sucks
Re: Hood scoop or cowl hood? [Re: an8sec70cuda] #426439
08/04/09 08:33 AM
08/04/09 08:33 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Guys, sorry but I dont understand...do it pulls air in back of scoop then? So I make plate what seals cowl hood inside and let open only that hole what is "beside" windshield?
I thoughted that cowl hood is to let hot air out..that cold air enters through grille and leaves through cowl hood
Re: Hood scoop or cowl hood? [Re: Georg] #426440
08/04/09 08:54 AM
08/04/09 08:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No... there is a negative air pressure at the windshield
(more as you get lower to the base), that negative
supplies the air to the carb, its better to seal
the carb to the scoop (keeps the hot air out of the carb).
On a front facing scoop you need to get the inlet
up into the air flow... as a rule of thumb... take
a string and tape it to the front edge of the hood...
tape the other end to the roof line... your scoop
opening should be ABOVE that string
Re: Hood scoop or cowl hood? [Re: MR_P_BODY] #426441
08/04/09 09:54 AM
08/04/09 09:54 AM
Yep, it pulls air in to the carb from the base of the windshield. CHIP
CHIP
Re: Hood scoop or cowl hood? [Re: MR_P_BODY] #426442
08/04/09 09:54 AM
08/04/09 09:54 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
[quoteOn a front facing scoop you need to get the inlet
Bingo....how many 6pack and hemi scoops do this? None that I have ever seen, also the people talking about their 6 pack scoops catching air. My thoughts are I wonder if the air was coming through the grill and pushing it up, not necessarily from the scoop itself.
Also most of the front facing ones, to me just dont look right on the older iron. Some come out real nice, some not.
Personally I prefer the cowl scoop for many reasons. Having had a huge scoop on older iron, it was a real pain in the ass to see around at times.
Re: Hood scoop or cowl hood? [Re: MR_P_BODY] #426443
08/04/09 10:02 AM
08/04/09 10:02 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Raff knows... Trust me.
Re: Hood scoop or cowl hood? [Re: Bubba] #426444
08/04/09 10:10 AM
08/04/09 10:10 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
My old car slowed down considerably with a cowl hood. A switch back to six pack scoop and the performance was restored. Was kind of amazed, but can't really fight the numbers. Must have been somekind of an aerodynamical gremlin. I have yet to see a six pack or Hemi scoop that doesn't work, but the openings are huge and create a lot of lift, and propably don't help the drag coefficience either. You don't have any scoop limitations, so I would propably bick a modern style, reasonably high pro style front facing scoop.
Plynouth VIP '67 TT IC EFI
Re: Hood scoop or cowl hood? [Re: jyrki] #426445
08/04/09 10:29 AM
08/04/09 10:29 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I would use whatever hood I liked and there is no doubt that Mr. P knows what he is talking about,but Westcott's hood seems to stay on at 157 mph @ 8.38 so it can be done with a stock hood.
Re: Hood scoop or cowl hood? [Re: cudabunch] #426446
08/04/09 04:51 PM
08/04/09 04:51 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Cowl hoods kick a$$, its just that simple, sorry. I run in a class that mandates no foward facing hoodscoops but still wouldn't put on a god awful hideous six pack scoop if my life depended on it.
One day I will have something cool here.
Re: Hood scoop or cowl hood? [Re: sdaurity] #426447
08/04/09 05:01 PM
08/04/09 05:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Are ssah cars required to run the scoops they do??
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Hood scoop or cowl hood? [Re: B3422W5] #426448
08/04/09 05:31 PM
08/04/09 05:31 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
My Cuda had a cowl hood on it when I bought it, the hood is listed in parts for sale, it might work great, but my personal preference makes me wanna toss it! car looks like a dang camaro with it on...
You Thinking It's So Doesn't Make It a Fact
Re: Hood scoop or cowl hood? [Re: B3422W5] #426449
08/04/09 05:32 PM
08/04/09 05:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sounds just like something Joe Dirt once said
Joe Dirt also said:
"How exactly is a rainbow made? How exactly does the sun set? How exactly does a positrack rear end on a Plymouth work? It just does."
