Re: 1939 lowboy dodge chronicles
[Re: Mopar Ron]
#425381
08/04/09 01:59 PM
08/04/09 01:59 PM
Posts: 1,884 Tracy, CA, USA, Earth
rabid scott
"You're Where?"
"You're Where?"
I want to make the panel truck look something like this ford coe
That is super cool!! I've never seen anything like it!!
[Re: mikeinkc]
#425382
08/04/09 02:30 PM
08/04/09 02:30 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
been a moparts stalker for many years, and a member for a few. thought i would start a build thread of my 39 dodge pickup. just a couple of weeks in, but since i bought the cab and frontend in the spring of this year, she has come along pretty good. i just chopped the cab and plan to do the doors this weekend. here is a link to my build blog. http://39lowboydodge.blogspot.com/ typically, i'm a bit of a slow worker and dont work on my stuff everyday. gotta work it in to real life when i can. criticisms? comments? questions? hit me up. the below picture, although a dorf pickup, is the inspiration for my build. i like the way it sits, the colors, the bed size, etc. thanks, mike in k.c.
If this truck is your inspiration and you want your to look similar you have to run a straight axle. Fenderless vehicles like this with indapendent front sus IMO look like SH#T very rarely do I think the MustII looks ok
[Re: hp383]
#425385
08/04/09 08:39 PM
08/04/09 08:39 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Interesting look but not for me I want to make the one I do be able to tow my car trailer so dakota chassis with the 5.7 HEMI,5 speed auto. how about COE R/T Ron... sorry Mike didn't mean to hijack your thread
[Re: 76dodgeboy]
#425386
08/04/09 08:55 PM
08/04/09 08:55 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Haha your not very good with paint or is it body work.
Didn't think it was too bad for a 30 sec chop and past.
Re: score!!!!
[Re: plmczy]
#425391
08/09/09 07:34 PM
08/09/09 07:34 PM
Posts: 38 kansas city, mo.
mikeinkc
kansas city, mo.
i took a measurement on the leaf stacks that came on this frontend and it looks like the distance from the center of the leafs to both ends are the same, so i'll probably use just one of these stacks mounted transversely and go fenderless. these tires would work great on the back, but they are way too tall for what i want in the front. i have to sort out the wheel and tire issues, but for now i'm just glad to have my axle. it is beefy! i also scored the gear box, the column and the steering wheel. i kinda like these wheels i must say though. very industrial. if i can find a housing with an 8-3/4 and the same drum pattern as the fronts, i may try and use these wheels if i can find a shorter front tire and one more wheel. by the way, these rims are 17.5 inchers with a large 6 bolt pattern. anyone know the bolt circle diameter on these rims??? i will probably "z" the frame channel the body. i want the frame hidden from the view for the most part. once i get the chop a little more finished, i'm going to start mocking up the framerails in different positions to see what is going to work best. mike in k.c.
