Re: 1939 lowboy dodge chronicles [Re: Mopar Ron] #425381
08/04/09 01:59 PM
08/04/09 01:59 PM
Tracy, CA, USA, Earth
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
I want to make the panel truck look something like this ford coe
That is super cool!! I've never seen anything like it!!
Re: 1939 lowboy dodge chronicles [Re: mikeinkc] #425382
08/04/09 02:30 PM
08/04/09 02:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
been a moparts stalker for many years, and a member for a few. thought i would start a build thread of my 39 dodge pickup. just a couple of weeks in, but since i bought the cab and frontend in the spring of this year, she has come along pretty good. i just chopped the cab and plan to do the doors this weekend. here is a link to my build blog. http://39lowboydodge.blogspot.com/ typically, i'm a bit of a slow worker and dont work on my stuff everyday. gotta work it in to real life when i can. criticisms? comments? questions? hit me up. the below picture, although a dorf pickup, is the inspiration for my build. i like the way it sits, the colors, the bed size, etc. thanks, mike in k.c.
If this truck is your inspiration and you want your to look similar you have to run a straight axle. Fenderless vehicles like this with indapendent front sus IMO look like SH#T very rarely do I think the MustII looks ok
Re: 1939 lowboy dodge chronicles [Re: Mopar Ron] #425383
08/04/09 03:30 PM
08/04/09 03:30 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
How about something like this
Re: 1939 lowboy dodge chronicles [Re: hp383] #425384
08/04/09 08:34 PM
08/04/09 08:34 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Haha your not very good with paint or is it body work.
Re: 1939 lowboy dodge chronicles [Re: hp383] #425385
08/04/09 08:39 PM
08/04/09 08:39 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Interesting look but not for me
I want to make the one I do be able to tow my car trailer
so dakota chassis with the 5.7 HEMI,5 speed auto.
how about COE R/T Ron...
sorry Mike didn't mean to hijack your thread
Re: 1939 lowboy dodge chronicles [Re: 76dodgeboy] #425386
08/04/09 08:55 PM
08/04/09 08:55 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Didn't think it was too bad for a 30 sec chop and past.
Re: 1939 lowboy dodge chronicles [Re: hp383] #425387
08/04/09 09:34 PM
08/04/09 09:34 PM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
since there are 39-47 dodge pickup guys here, anyone have a pair of rear fenders laying around for sale? not saying they are going on my truck just yet, but it never hurts have a source for parts. thanks, mike in k.c.
ask me about new sportone elbow side trim for your 1957 and 1958 plymouths http://39lowboydodge.blogspot.com/
Re: 1939 lowboy dodge chronicles [Re: Mopar Ron] #425388
08/04/09 09:51 PM
08/04/09 09:51 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
yours with a chop and lowered
score!!!! [Re: mikeinkc] #425389
08/09/09 11:48 AM
08/09/09 11:48 AM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
thank you craigslist! i bought a straight axle from a 1958 dodge d200 today to use on the 39. tires and wheels are monsters, but i'll figure out what i'm gonna do with them later. at least i have a good axle now. almost certain this is going to be fenderless now.
Re: score!!!! [Re: mikeinkc] #425390
08/09/09 06:58 PM
08/09/09 06:58 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
Are you going to use those leaf springs with the straight axle or are you going with a transverse spring? Do you plan on Z'ing the frame or just going to channel the cab? later shawn
Re: score!!!! [Re: plmczy] #425391
08/09/09 07:34 PM
08/09/09 07:34 PM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
i took a measurement on the leaf stacks that came on this frontend and it looks like the distance from the center of the leafs to both ends are the same, so i'll probably use just one of these stacks mounted transversely and go fenderless. these tires would work great on the back, but they are way too tall for what i want in the front. i have to sort out the wheel and tire issues, but for now i'm just glad to have my axle. it is beefy! i also scored the gear box, the column and the steering wheel. i kinda like these wheels i must say though. very industrial. if i can find a housing with an 8-3/4 and the same drum pattern as the fronts, i may try and use these wheels if i can find a shorter front tire and one more wheel. by the way, these rims are 17.5 inchers with a large 6 bolt pattern. anyone know the bolt circle diameter on these rims??? i will probably "z" the frame channel the body. i want the frame hidden from the view for the most part. once i get the chop a little more finished, i'm going to start mocking up the framerails in different positions to see what is going to work best. mike in k.c.
post chop update! [Re: mikeinkc] #425392
09/03/09 08:03 PM
09/03/09 08:03 PM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
i put the roof and passenger door back together over the last two weeks. it has turned out really nice, especially for a first time chop. drivers door will go back together over the weekend.
Re: post chop update! [Re: mikeinkc] #425393
09/03/09 08:07 PM
09/03/09 08:07 PM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
i used 14 gauge as the filler strip. i figured this would be a weak point, so i used a thicker patch all the way across. i'll finish the welds later.
Re: post chop update! [Re: mikeinkc] #425394
09/03/09 08:07 PM
09/03/09 08:07 PM
kansas city, mo.
mikeinkc Offline OP
mikeinkc  Offline OP
kansas city, mo.
another view.
