up date on this problem.i pulled everything apart ,cleaned valley pan gasket,lots of silicone around the ports,cleaned up intake,some silicone stuck to it,bolted on ,started up with no smoke out the tail pipes.i probly should have mentioned it at the start that the engine was assembled by a guy who builds buicks. any way went back to basics and solved the problem.
