Re: Removing weight from pistons?
[Re: quick77rt ]
#421623
07/28/09 10:37 AM
07/28/09 10:37 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
14 grams is gigantic. Most pistons will take about 2-4 grams safely. Some of the old TRWs can take more, but many will argue what is a safe limit, and at what point are you doing more harm ( stress risers) than good. I myself stop at about 5 grams, and even at that, some pistons ( many of the strokers now) arent worth even touching. Most newer modern pistons come in finished within 2 grams across the board.
You may be able to find a lighter wrist pin like in H-11 and take the weight out there .
14 grams would not be suggested.
RIP Monte Smith
[Re: CompWedgeEngines]
#421624
07/28/09 11:25 AM
07/28/09 11:25 AM
quick77rt
Parts Problem
Parts Problem
Thanks Ive a stroker kit im changing pistons on and thats the piston weight difference... Looks like the smart (best only) way is to do it right and get a rebalance.... I will look into the pin option as well. Thanks again!
[Re: dOc !]
#421628
07/28/09 01:38 PM
07/28/09 01:38 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Diamonds are pretty beefy. Been a while since I had ahold of a Automotive Wiseco. The one in my picture is a JE. I wouldn't use a forged TRW to chock my trailer from rolling over the hill. It does depend on the piston.
[Re: S/ST 3040]
#421629
07/28/09 02:07 PM
07/28/09 02:07 PM
Posts: 30,540 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
So you would not recommend running an old-school pop-up TRW in a motor that will run over 7k rpms ?
I have not tried taking weight out of one of these 383 pistons(for my v drive boat) .... but what would the safe limit be on these ?
And what would the weight diff be on a new-age Diamond .. or even a JE ?
I would LIKE to be able to run-this up to 8k ... if I could.
[Re: S/ST 3040]
#421630
07/28/09 02:09 PM
07/28/09 02:09 PM
CompWedgeEngines
Syracuse,NY
Vic, I agree , anything is possible, but I am doubting you'd wnt to remove 14 grams from a normal small block piston. ( I am making an assumption here about what 77 R/T is working on) If you are doing a normal balance job ( which again is what I am talking about) you know a balance keyway style cutter isnt going to find 14 grams very easy in a SB stroker piston. Obviously you could ball mill some etc, but again, I am quite certain that isnt where he is headed here. A 100 gram change is basically a total piston re-work. IE: Taking one piston and making it into another or a maximum lightening effort, which then lends me to wonder about piston strength. As you know, there will be a balance between cost/sensibility and strength. Pick any two...lol. For the record, what did it cost to take 100 grams out of 8 pistons? Also, what was trying to be acomplished with those and why did they need to be done in the first place? I'd rather change wrist pins than take a crapload of weight out ( within reason). I know Diamond and I went round and round about this before, and they still like to maintain some strength as opposed to cutting the piston up too much. I can see it in NASCAR where they frequently change ( and can afford to) pistons etc, but I'll exchange a little beef for longevity anyday. Just my and opinion
RIP Monte Smith
[Re: dOc !]
#421631
07/28/09 02:12 PM
07/28/09 02:12 PM
CompWedgeEngines
Syracuse,NY
You'd see about 200 grams difference between something similar in a new style piston vs the TRWs. ( assuming flat top vs flat top) Thats considerable.That being said, for years people beat the hel* out of old heavy TRWs and they lived. Would I want to use them? No.Does that mean they are junk? No. Just a matter of budget vs expected results.
RIP Monte Smith
#421632
07/28/09 02:13 PM
07/28/09 02:13 PM
dOc !
Florida STAYcation
I had thought about this also ... but what happens with a heavy piston and a way lighter pin ...?
Is that safe ? ... and how much weight can be saved with this swap anyways?
#421633
07/28/09 02:21 PM
07/28/09 02:21 PM
S/ST 3040
Todd.......IIRC it was $148.00 +shipping (4 operations) I know what you are saying. I didn't mean 14 grams with a die-grinder weight match. That's why I started with "If you must......" About 4-5 grams is all I care to take of the pin bosses to weight match.
[Re: S/ST 3040]
#421635
07/28/09 02:50 PM
07/28/09 02:50 PM
CompWedgeEngines
Syracuse,NY
That is very reasonable then for that weight removal. About the same as new pins. Again, I think it needs to be a piston with that much material that can be removed.
Thanks.
RIP Monte Smith
[Re: Moparteacher]
#421638
07/28/09 04:28 PM
07/28/09 04:28 PM
CompWedgeEngines
Syracuse,NY
I ve got some old TRWs that have the skirts cut, profiled inner skirts, cut valve reliefs, removed underhead etc, and I got about 160grams out, but that was almost 20 years ago now. There were no options then. Amazing what good old ingenuity could do when we had no choices huh?
RIP Monte Smith
[Re: Cab_Burge]
#421639
07/28/09 04:34 PM
07/28/09 04:34 PM
CompWedgeEngines
Syracuse,NY
I did a BBC 2 years ago that came in with bearing issues. I told the owner " you have a balance or crankshaft problem" after just looking at the bearings. He did not know the whole history of the motor other than it "did not have that many laps on it". After tearing down, checked pistons, all were Ross domes, but two were a bit different forging. I took them off and found the problem. Same part #, different weights. they were each almost 28 grams different than the other 6. The guy that put it together never wieghed them, and just ordered the same part number, dome configuration looked the same, so he just threw them in. I took all the wieght out I could, swapped for lighter wrist pins and been running like a champ.
RIP Monte Smith
[Re: quick77rt ]
#421640
07/29/09 11:44 AM
07/29/09 11:44 AM
Posts: 4,213 New York
polyspheric
New York
14 grams is about .32 cubic inches; 4 holes 3/4" ID by 3/16" deep, etc.
Boffin Emeritus
[Re: polyspheric]
#421641
07/29/09 12:04 PM
07/29/09 12:04 PM
dOc !
Florida STAYcation
Doesn't this kind-of-vary between types of alum forging or casting ?
I have a couple of other follow-ups to other posts .. but will have to do that later.
