Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421366
08/08/09 01:48 AM
08/08/09 01:48 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Here's what I did:
Re: 360 swap day 3 today. update PICS! [Re: sharpie] #421367
08/08/09 08:33 AM
08/08/09 08:33 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I went to the NAPA (where I finally found one) parts store and looked at all the pre-formed hoses there. I picked one that had the closest bend and was the right diameter then just cut it down 'til it fit right. Worked great and koojs good too.
I don't even know what car the hose might have been for, only that it had the correct, or close enough, bend si it wouldn't kink.
Driving modern convenience in classic beauty
Re: 360 swap day 3 today. update PICS! [Re: Darius] #421368
08/09/09 10:50 PM
08/09/09 10:50 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline OP
Pops and I broke out the Lincoln and got some welding in. Not the best welds, but they do the job. Then again my car already tells you I am not the best painter either.
Tack'd!
Tack'd.
Ready to grind and look for holes or gaps.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421369
08/09/09 11:09 PM
08/09/09 11:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
AC to non-AC conversion?
Welds look good. If you haven't already completed the grinding use one of those 80 grit flapper wheels instead. They are a plastic backed disk full of little sandpaper squares. They offer a lot better control over the finish + less grooves and scratches than a hard disk.
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421370
08/09/09 11:11 PM
08/09/09 11:11 PM
Indeed. I chucked the A/C stuff a few months before I was 16 even, LOL!
I have, in fact, NOT completed the grinding. I will go seek one out. Thanks for the tip!
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421371
08/09/09 11:19 PM
08/09/09 11:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hardware stores usually have them. Make sure you get the right diameter so it fits inside the guard.
http://img.directindustry.com/pdf/repository_di/26411/enduro-flex-abrasive-flapdisc-19215_1b.jpg
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421372
08/09/09 11:24 PM
08/09/09 11:24 PM
Guard?
Does my grinder have a guard in the above photo?
[Guns N Roses]I lead a reckless life...[/Guns N Roses]
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421373
08/09/09 11:30 PM
08/09/09 11:30 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
For the bypass hose - how abouts this big block Olds bypass piece?
Installs to a down angle but could do a 90 degree I think.
Ride eternal, shiny and chrome
Re: 360 swap day 3 today. update PICS! [Re: DirectSubjection] #421374
08/09/09 11:43 PM
08/09/09 11:43 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I thought you posted a green firewall and you were swapin the whole thing out.
I was saying Just patch it up and weld it well
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 360 swap day 3 today. update PICS! [Re: 340SIX] #421375
08/10/09 12:23 AM
08/10/09 12:23 AM
That patch panel is from the green firewall. When I started I assumed I would not need to install the whole thing but was preparing for the worst if the stampings were "Off."
Glad it didn't come to that.
I did have to weld and redrill the bolt holes from 4 to 3. No biggie.
Re: 360 swap day 6 today. update PICS! [Re: Neil] #421376
08/10/09 12:30 AM
08/10/09 12:30 AM
Engine looks very nice.
Is this a 5.9 roller engine or an LA 360 with the magnum heads? Looks like an LA timing cover and water pump.
Might want to freshen up the trans or at least tighten the bands since it's about to see double the power it's used to.
It is going back to Marcus for some "Anger Management" classes.
He has a 9 second '69 Charger, and helped me build that trans back in '00.
Re: Started the 360 swap today. PICS! #421377
08/10/09 12:33 AM
08/10/09 12:33 AM
Using the same transmission?!
Yes. Stay tuned...Don't change the channel! We'll be right back!
I am more worried about the 8.25. I had one rebuilt back in '96, blew it up in '00 and blew it up again by '02.
Re: Started the 360 swap today. PICS! [Re: SCATPK] #421378
08/10/09 12:39 AM
08/10/09 12:39 AM
Cam, good to see you working on the ride and hope to see it in person in the near future.
Thanks. Although usually I make someone else be the designated driver and haul me.
When I moved to Davis suddenly I could not work on the Duster very much. Either the ex had me working on the '55 Buick I got her or we lived somewhere wrenching was not allowed.
I did not have a digital camera back in '03/'04 when Khal440 and I ware over-restoring his '72 Swinger in my garage (Which I basically got evicted for, but that is a whole different story)
This engine swap has been awesome. I loved dusting off the tools and digging back in again!
Who knows, next year it might be bodywork and paint! (Say it ain't so) or I may just go back to using her as a daily driver and keep the '96 Breeze as the dog car.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421379
08/10/09 12:42 AM
08/10/09 12:42 AM
Here
Here
Oh Fritz - job for Baconfest 2010.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421380
08/10/09 01:31 AM
08/10/09 01:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That having a roof over your head thing is wayyy over-rated anyway..
Good to see ya getting it done!
Re: Started the 360 swap today. PICS! [Re: 1_WILD_RT] #421381
08/10/09 01:33 AM
08/10/09 01:33 AM
Here
Here
Have you seen his guest room at Stu's?
Re: Started the 360 swap today. PICS! [Re: DirectSubjection] #421382
08/10/09 01:40 AM
08/10/09 01:40 AM
Fritz can crash on my floor or park the camper in my driveway ANYTIME!
Re: Started the 360 swap today. PICS! [Re: DirectSubjection] #421383
08/10/09 01:42 AM
08/10/09 01:42 AM
Wow, that is WAY nicer than what I am accustomed to. Given my track record at Stu's I am not so sure how happy his wife would be about me crashed out in the driveway though.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421384
08/10/09 01:42 AM
08/10/09 01:42 AM
Here
Here
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421385
08/10/09 01:44 AM
08/10/09 01:44 AM
Here
Here
Phhhhhht - better than actually inside the house.
