Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: Started the 360 swap today. PICS! [Re: jrwoodjoe] #421306
07/30/09 01:27 PM
07/30/09 01:27 PM
Using the same transmission?!
Re: Started the 360 swap today. PICS! #421307
07/30/09 01:53 PM
07/30/09 01:53 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
and thank god he's wearing pants
Re: Started the 360 swap today. PICS! #421308
07/30/09 08:11 PM
07/30/09 08:11 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline OP
Until I collect everything I need to do my Toyota R154 5 speed swap, yes.
No real pics to add today. Did a bunch of grinding in the engine bay and got it in primer, tomorrow I paint it.
I also spent a lot of the day cleaning and masking, painting things I am reusing with semi-gloss, etc.
Tomorrow the K-frame comes out and I receive my F/S kit.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421309
07/30/09 08:54 PM
07/30/09 08:54 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Coming right along!
Be cool to see that magnum in place, and then you can find something with in a slant in it...so I can finally see that intake on something
Re: Started the 360 swap today. PICS! [Re: OzHemi] #421310
07/30/09 10:08 PM
07/30/09 10:08 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Looking good! Great pics and a very cool post to follow along with.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421311
07/31/09 12:44 AM
07/31/09 12:44 AM
Las Vegas, NV---Back Home!
Mooosman Offline
super gas
Mooosman  Offline
super gas
Any more info on this transmission swap? The R154 is a Supra transmission, isn't it?
Nick
1970 Plymouth Valiant
Re: Started the 360 swap today. PICS! [Re: Mooosman] #421312
07/31/09 12:54 AM
07/31/09 12:54 AM
The R154 Supra trans bolts to the later Dodge truck manual bellhousings. It is a 5 speed used in the '87-'92 (MKIII Turbo) and the shifter is in roughly the right location.
I have seen a full bodied, full interior MKIII at Infineon do a lot of passes with 600+ horsepower, back-halved for a Ford 9" and slicks...Stock tranny.
Sandy in Nova Scotia has one in a Mopar IIRC and I saw it advertized as a swap in kit form in Oz. Most of the tech info I find on the swap is from Marlin Crawler's forum running one behind a 5.9 Magnum in a 2WD.
Re: Started the 360 swap today. PICS! [Re: Just Cameron] #421313
07/31/09 09:16 AM
07/31/09 09:16 AM
santa rosa,ca
RTDude Offline
RTDude  Offline
santa rosa,ca
Looking good Cameron.Shoot me a PM with your phone #.I can probably drop the carb off tomorrow after work if you still need it.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421314
07/31/09 08:49 PM
07/31/09 08:49 PM
TTI's arrived this afternoon!
Once I got the old V=belt pulleys switched over (I am using an LA-style water pump)discovered that my old alternator with the stock brackets does not clear the Magnum head casting.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421315
07/31/09 09:18 PM
07/31/09 09:18 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Since you are pulling the K frame, are you going to install the works from underneath?
I remember doing headers in my A engine A body
Re: 360 swap day 3 today. update PICS! [Re: RodStRace] #421316
07/31/09 10:30 PM
07/31/09 10:30 PM
Affirmative on the car coming down on the K frame.
RTdude is bringing my carb over tomorrow after he gets off work. I am buying his old Demon since he decided his big block needed more carb.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421317
07/31/09 10:31 PM
07/31/09 10:31 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And don't worry about using the alternator, they are just overrated anyways.
Re: 360 swap day 6 today. update PICS! [Re: Just Cameron] #421318
08/01/09 10:05 PM
08/01/09 10:05 PM
So I did some grinding.
And some priming.
My ceramic coated TTi's arrived on my doorstep.
I figured out my alternator bracketry and bent the old throttle bracket from 120* to 90* to go from LA to Magnum.
RTdude stopped by with the 750 Speed Demon he gave me a killer deal on!
Torque was a big help as always, and I could not have undertaken such a project without his help lending a paw.
"Regulators! Mount up!"
Still a lot of work to be done. I have yet to drop the K frame and am still waiting on my poly F/S bushings and new shocks. Feels great to be turning wrenches again and I cannot wait to terrorize small towns with her again!
Re: 360 swap day 6 today. update PICS! [Re: Just Cameron] #421319
08/01/09 10:13 PM
08/01/09 10:13 PM
And I am just realizing after today's carb purchase, My shirt might be a little outdated. Oh, the irony!
Re: 360 swap day 6 today. update PICS! [Re: Just Cameron] #421320
08/01/09 10:16 PM
08/01/09 10:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cool '46 Dodge Coupe! Is the grinder motor a mock up of things to come?
Be sure to save the AC "delete" tape as well, someone doing an OE resto will pay big bucks for it.
Re: 360 swap day 6 today. update PICS! [Re: Alaskan_TA] #421321
08/01/09 10:34 PM
08/01/09 10:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Engine looks very nice.
Is this a 5.9 roller engine or an LA 360 with the magnum heads? Looks like an LA timing cover and water pump.
Might want to freshen up the trans or at least tighten the bands since it's about to see double the power it's used to.
Re: 360 swap day 6 today. update PICS! [Re: Neil] #421322
08/01/09 10:36 PM
08/01/09 10:36 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It's a magnum with an early timing cover.
Re: 360 swap day 6 today. update PICS! [Re: OzHemi] #421323
08/01/09 10:40 PM
08/01/09 10:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Never tinkered with a 5.9 before.
I didn't know the timing covers and water pumps were interchangable. Every time I have seen a 5.9 in an older car they have retained the serpentine belt setup so I thought that was your only choice.
Re: 360 swap day 6 today. update PICS! [Re: Neil] #421324
08/01/09 10:50 PM
08/01/09 10:50 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I only know cause the short block came from me
I bought it complete to sell the heads to a guy in Oz ages ago...Then got the rest.
Re: 360 swap day 6 today. update PICS! [Re: OzHemi] #421325
08/01/09 11:03 PM
08/01/09 11:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If it's "your" engine then how come you aren't over there helping?
