Re: Dodge Truck Registry 1972-1980
[Re: MachoMan]
#4157
12/18/04 06:20 PM
12/18/04 06:20 PM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
I have a 1979 dodge W150 swb PALOMINO. It was an odd-ball truck, as it was fairly loaded up, but came from the factory with a 4spd and no a/c. Attached is a pic of the window sticker. It is in the process of a restoration, and I have added factory a/c to it allong with the big bolt pattern axles to it with the 5 slot wheels. The VIN is as follows.... W14JT9S195981. This truck came out a Wrecking Yard in Northern CA, and I am glad that I saved her!! I have a couple of these trucks now, and am getting another PALOMINO from VA that is also a 4wd.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: dynotune440]
#4158
12/18/04 06:21 PM
12/18/04 06:21 PM
dynotune440
A pic of the window sticker Quote:
[Re: dynotune440]
#4159
12/18/04 06:24 PM
12/18/04 06:24 PM
dynotune440
one in it's current state..... Quote:
[Re: MachoMan]
#4160
12/20/04 11:21 AM
12/20/04 11:21 AM
Posts: 355 Sparks, Nevada
MoparMike23
Sparks, Nevada
thank you sir, kinda curious why it's all light blue. i have never seen a med blue/light blue w/that paint procedure. bet it looks sweet. i will adjust the codes and send them back to you.
I primered the truck light blue about 2 yrs ago because the surface was starting to rust.I remember when my grandfather drove the truck and the 2tone paint was nice, I plan on repainting it to original color when I find the trim that separates the two colors( about 3-4 inches down the frt. fender and runs frt. to back to the top of the tail light). Gotta say I'm a superbee fan, been restoring my bee for 6 yrs now, but you guy's are getting me excited about the trucks. Can't wait to start the truck restoration. One question for you, do you think I should go with a 440 or keep it original with the 360 2bbl? Also, Old Blue, my ramcharger, and the Bee are on the picture page 3 Thanks, Moparmike23
1969 Superbee 440-6 1977 D-150 Adventurer 2000 Jeep TJ 2018 Challenger Scat Pack Shaker 2019 Ram 2500 CTD
[Re: MachoMan]
#4163
12/24/04 11:43 PM
12/24/04 11:43 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Here is the infor on a couple of my Trucks:
'76 SWB 4x4:
W14BD6S190***
Originally brown on black Original 440 Truck, now has SB setup A/C, PS, PB 9 1/4 rear, D-44 front, probably 3.55 gears
Dont really know if its a Custom or Adventurer, but I believe its an Adventurer because it has Chrome around the taillights and has A/C.
My '72 4x4 LWB:
W14AF2S562***
360-2, Green on green 4-spd Granny gear 205 part time transfer 8 3/4 rear, D-44 front PS and brakes 3.55 gears most likely
I also have a couple of 2wds but I'll post them later on.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MachoMan]
#4164
01/29/05 01:16 PM
01/29/05 01:16 PM
I have a 1978 Dodge Macho Powerwagon. 318 2bbl (for now)727 with np203 transfercase. Dana 44 front and I think 8.25 rear with 3.55 gears. Pretty much stock at this point. I started the restore 2 years ago and finally its coming to a close.The original color scheme was orange and black with black interior. I'm keeping the interior but the exterior will be solid orange. It now has 33x12.50 tires and aftermarket wheels. I found it sitting in southern Indiana for $600 bucks. I've also located a dodge junkyard in southern Indiana if anyone is interested. Also in case someone wasn't aware the military used these trucks for years it was known as the m880. www.saturnsurplus.com has lots of parts for these trucks at really good prices. Love the thread! Tom
[Re: MachoMan]
#4165
02/05/05 08:37 PM
02/05/05 08:37 PM
Posts: 4,555 Wisconsin
beeper71
moparts member
moparts member
Wisconsin
77 150 Adventurer Club Cab Long box, 318 727 3:21 8 3/8 rear. Add ons include reciever hitch, trailer brakes ,tranny cooler, tachometer and dress up items. [
[Re: beeper71]
#4166
03/03/05 10:19 PM
03/03/05 10:19 PM
MoPar Jamie
Sarcoxie, MO, USA
D17AJ4S054*** '74 Club Cab Adventurer SE 2wd, factory 400-2v, auto, loaded, PS/PB/Air, Cruise, light package. Old USD 446 school system truck. Wheels are an add-on by me and are factory 15x8 Li'l Red style slots.
- MoPar Jamie
[Re: cdwmotorsports]
#4167
03/11/05 05:26 PM
03/11/05 05:26 PM
Posts: 1,460 Martinsville, IN
cdwmotorsports
Martinsville, IN
I have a 1978 Big Block Crewcab Shortbed 3/4 ton pickup and a 74 D100 318/727 Long bed 8 3/4 truck I will get info this weekend. Both are for sale if anyone is looking....
The Crewcab's info is 1978 Big Block Crewcab Shortbed 3/4 ton, Engine unknown had 440 in it before I got it (I presume that's what came in it and have no idea how to find out).
Pics are here for now...
http://www.cdwmotorsports.com/Vehicles-For-Sale.htm
VIN number D26BJ8S277895
outside color Green
interior color Green
transmission 727
front and/or rear axle size Dana 60
gear ratio unknown
any extra cost options(Adv SE, tach, tuff wheel, paint procedure, wheels etc...)
If the truck still has the underhood equiptment label, i would like those codes.
If the truck still has the radiator support tag (commonly known to car guys as fender tag) the info off those.
eBay-cdwmotorsports
#4168
03/13/05 02:01 AM
03/13/05 02:01 AM
dynotune440
ok, I have one for you.... 77 d200 CAMPER 900 crew cab MDH is 080916, with a low VIN number... Here are the options that the truck has.... 440, auto transmission, factory a/c, cargo light, am radio, factory dual tanks, dana 60 HD with 4.11 gears, 117 amp alternator, transmission cooler, camper wiring, add on slide out rear bumper, sliding rear window, and the cool thing...Adventurer package in powder blue and above the moulding it is light metalic blue with the standard blue interior.
[Re: MachoMan]
#4169
03/22/05 11:50 PM
03/22/05 11:50 PM
You entered the VIN Number: D13AJ8J500001
D1 MODEL DESIGNATION D100 or D150 for 80 3 BODY TYPE Conventional Cab W/Utiline (Step Side Box) A GVW CLASS 6000 lbs or less J ENGINE TYPE 400-1 8 MODEL YEAR 1978 J ASSEMBLY PLANT Windsor Plant 500001 Sequential Serial Number
First '78 truck off the second line @ Windsor plant. Adventurer SE, Copper exterior with creme yellow cab top, black SE interior, factory glass tint, am/fm/8track, woodgrain dash, tilt wheel, p/s, p/b, automatic with 2.71 SG 9 1/4 rear. Tow package (mirrors and bumper). Original wheels unknown.
[Re: MachoMan]
#4170
03/23/05 08:04 PM
03/23/05 08:04 PM
i have a spirit of 76 slant 6 3spd shortbox and i was just wondering about any info on this truck i have vin and thats it
#4171
04/21/05 04:18 PM
04/21/05 04:18 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
ok, here is my info: 72 D200 Adventurer, Camper Special D24BF2U581246 original 360, 727, now 318, 4.10 gears (the thing hates the freeway ), A/C, power Disc brakes, long bed, cruise control, monotone tan, dual gas tanks (if anyone can find me a lower tank, i would appreciate it. mine leaks when too much gas is in it.), power steering. it still has the underhood sticker, but it is pretty hard to read. i would post a pic, but it is illegible. sorry.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: MachoMan]
#4172
05/05/05 08:10 PM
05/05/05 08:10 PM
dynotune440
ok, here is another odd ball truck..... 1980 macho power wagon. it is in a wrecking yard, and was hit hard on the right front. It is a fairly basic power wagon, here is the equipment that I saw that it has..... 318 4bbl auto transmission dual tanks had tach and that was what I could see of it. I did grab the underhood plate off of it, and here are the numbers..... 019153 W1 115 CONV CAB S6 PY8805 PZ4011 PXY W14JEAS119035 HG077101 This is a factory "IMPACT BLUE" macho power wagon!! Interesting huh..
[Re: MachoMan]
#4173
05/05/05 08:14 PM
05/05/05 08:14 PM
dynotune440
here is another interesting find..... 1978 trailduster sport 440. This one has been in the wrecking yard for about 15 years now, and was a super nice rig when I first saw it. It was a roll over, and was also low mileaged too. All that is left of it is the roof and front clip. Here is the info off of the underhood tag....... 80858 PW1 106 PY8752 PZ1417 PXS AA0BD8S150966 PC833701 This was a blue and white 2-tone trailduster that was loaded up.
[Re: MachoMan]
#4174
05/06/05 03:35 PM
05/06/05 03:35 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
This registry is for Dodge trucks from 1972-1980. I currently have over 350 trucks in my database. I also include the 1970-1971 Dude package trucks, 1981 W150 and Ramcharger Macho package trucks as well as the 1987/1990 Rod Hall package trucks. Of course, the staple trucks are invited too. That being the Lil Red Express, Warlocks, Machos, Palominos, Big Horns and True Spirits.
I take any and all information on any truck from this era. So if you have a 1975 regular cab Custom D100 slant 6 w/no options shoot me what ya got. This is what I would need: VIN number: A10BD8S273817 outside color: A2 metallic silver interior color: blue transmission: 727 front and/or rear axle size: Dana 44 and 9 1/4 gear ratio: 3.55:1 any extra cost options(Adv SE, tach, tuff wheel, paint procedure, wheels etc...): SE, cruise control, A/C, factory 100 amp alt., bucket seats with console and heavily restified by me.
I would appreciate any and all info. You can be completely anonymous or give out your name and such.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: Blown_Hemi]
#4175
05/06/05 06:46 PM
05/06/05 06:46 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Ok I have a 78 LRT that is low optioned but does have suregrip 3.55s. Never restored and is my daily driver 80 miles round trip. It gets 15 MPG @ 65MPH. It has 220K miles. Vin is D13BS8J517224. I am the second owner and the orignal owner has past on to the great Mopar Heaven. He said that the engine has never been out but the Vin dont match the engine number. The engine build dates on all the parts are from 1978. Add this one to the list. My son is working on a 66 LWB Poly 318/A727 but its not in your years. DaveJ
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: MachoMan]
#4176
05/13/05 11:35 AM
05/13/05 11:35 AM
Posts: 24 Haslet, TX, USA
orioncrw
Haslet, TX, USA
Hey MACHOMAN. I would like to add the three I have to the registry. 1st. 76 black warlock 318 727 only the wheels have been changed D13BES6S340004. It is also my daily driver. 2nd. 75 D100 360 4-speed 3.91? suregrip fleetside D14BE5S099868 EX WA state forest service 3rd. 76 D110 440 833 O/D 4-speed 9 1/4 suregrip D13AB6S329378 Just started project. Should be running in a couple of weeks. I am new to this posting thing. Thanks for the thread. orioncrw@comcast.net
You can bring a man to water, but you can not make him think!
