Re: Home Head Porting TOOLS 101..... [Re: LSP] #4122
10/10/03 11:27 AM
10/10/03 11:27 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
cool...........way cool...ya head stud!!! ......now...back to work!!!!!!need those w6 heads finished...no more time"glamorizing"your trade............ ......................seriously...great info ryan.....keep up the super work you are doing...we are lucky to have ya on the board!!!!!
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Home Head Porting TOOLS 101..... [Re: B3422W5] #4123
10/10/03 11:40 AM
10/10/03 11:40 AM
LMBO!!!!! Easy dark one... it's just a little head porting....
I think the safety precautions he gave us are as, or as more important as the good porting advice and tool tech.
Re: Home Head Porting TOOLS 101..... [Re: B3422W5] #4124
10/10/03 11:57 AM
10/10/03 11:57 AM
Wow, good info... great pics!Nice to see that a pro makes a mess at it too!First time i tried it i got those "high speed steel" bits,next to worthless.Boy did they make the head sing though.next attempt was with a two flute router bit,man was that baby hard to hold on to.But it did work a lot better than the steel bits!
Re: Home Head Porting TOOLS 101..... #4125
10/10/03 01:13 PM
10/10/03 01:13 PM
San Diego
StrokedDart Offline
StrokedDart  Offline
San Diego
Good post Ryan...now when are you going to experiment on that batten w2??
1968 Dart
Re: Home Head Porting TOOLS 101..... #4126
10/10/03 01:26 PM
10/10/03 01:26 PM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4127
10/10/03 02:02 PM
10/10/03 02:02 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
Many thanks for posting this info. Might have an opportunity to put this to use on a set of magnum heads.
I've recentely (3 months) had a piece of steel drilled out of my eye. It sucks. I took care to use my glasses and some sealed goggles, but I actually got the chip in my hair and it washed out into my eye later that night . Maybe a hair net is in order
Hope this gets to the tech archives. It would be great if you could make a general post about where to look for air, and augment it with where you found good results on the various mopar heads you've worked on so far. You're becoming a real faucet of knowledge. The board is a much better place because of great guys like yourself!!!
Greg
Re: Home Head Porting TOOLS 101..... [Re: Dartman75] #4128
10/11/03 07:51 AM
10/11/03 07:51 AM
I've heard Roger Helgensen sells special course cut carbides that make cast Iron grinding almost as quick as aluminum. Ever tried em?
Vizard and some of those guys use the old vacuum suction on the port trick to rid themselves of "brake dust"
With the small amount of porting I've attempted I kinda prefer the front exhaust air grinders as it blows the chips out so I can see what and how much I'm cutting. Squeezing the trigger can be a pain and the airs' insaciable propencity to pick up heat while expanding makes it a smite cold on the nubs, ah fingers, but heh. It's just a hobby here so no biggie.
Re: Home Head Porting TOOLS 101..... #4129
10/11/03 09:16 PM
10/11/03 09:16 PM
W8, you there?
Re: Home Head Porting TOOLS 101..... #4130
10/12/03 12:12 AM
10/12/03 12:12 AM
W8, you there?
DARKSIDE now has ryan chained to his porting table and won't let him up til his heads are done....
ryan, do you use lube on the sanding rolls or you run them dry?
Re: Home Head Porting TOOLS 101..... #4131
10/12/03 12:21 AM
10/12/03 12:21 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
W8, you there?
Actually I've been working my tail off on DARKSIDE's $1000 W6 INDY intake manifold..... You'll be seeing pics of it next week.......
Sand Rolls always should be run dry,a nd at a relatively low grinder speed for best results.
Never Tried any of Helgessen's stuff. Don't laugh, but I often use an OLD aluma cut carbide on iron, it's cuts it like butter, but if you get too much grinder speed the head will bounce around and chip the blades...........
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4132
10/12/03 12:45 AM
10/12/03 12:45 AM
That answers a few questions i had right there...
Re: Home Head Porting TOOLS 101..... #4133
10/12/03 04:37 PM
10/12/03 04:37 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
what no pic of the porter fully prepped for porting ? We don't know what a real porter looks like, it must be stylish with the holey old gloves and goggles etc .
Re: Home Head Porting TOOLS 101..... #4134
10/12/03 08:51 PM
10/12/03 08:51 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
wow kool pics and nice work you must be nuts for doing all that grinding and sand on alum.LOL
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Home Head Porting TOOLS 101..... [Re: 340SIX] #4135
10/18/03 09:01 AM
10/18/03 09:01 AM
AZ
d4rt Offline
d4rt  Offline
AZ
I take a few days away from the board and look what I nearly miss! Great info Ryan! This is something I need to learn how to do someday.....
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4136
05/05/04 10:47 AM
05/05/04 10:47 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
btt...this needs to be in the BEST OF MOPARTS
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
