Dying vinyl seats and interior parts? #39671
05/13/07 07:53 PM
05/13/07 07:53 PM
Indianapolis
Waveraider Offline OP
Indianapolis
I've been thinking about changing from a green interior to black, but don't want to spend $1000 or more to do it. Has anyone had any success (or horror stories) using vinyl die to die seats, kick panels dash, ect.? My car is also a 'vert, so the interior stands out much more then a hard top. Thanks for your input.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39672
05/13/07 08:18 PM
05/13/07 08:18 PM
chargermick Offline
chargermick  Offline
I had the same green interior in my '69 Charger, and I wanted to dye it black as a temporary change until I could afford new. That was 2 years ago, and it hasn't scratched off or lifted off yet. It looks so good and has held up so well, that I'm thinking it's permanent. I used a spray can dye made by SEM. Hardest part was getting everything really clean. I used a battery scrub brush and simple Green to clean the hell out of it. Then, just prior to spraying the dye, use a 50/50 solution of rubbing alcohol and water on a rag. It opens the pores of the vinyl and lets the dye go in deeper. It was a lot of work, but it came out great and I saved A LOT of money. I think I used 11 cans of dye for the whole interior. Less than $150. Good luck
Re: Dying vinyl seats and interior parts? [Re: chargermick] #39673
05/13/07 09:00 PM
05/13/07 09:00 PM
Indianapolis
Indianapolis
Thanks Mick. What did you do about carpet?
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39674
05/13/07 09:15 PM
05/13/07 09:15 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I havent use it YET, but this is supposed to work well for carpet and cloth.
http://www.bondo-online.com/catalog_item.asp?itemNbr=151
Doc.
Re: Dying vinyl seats and interior parts? [Re: NTOLERANCE] #39675
05/14/07 05:33 AM
05/14/07 05:33 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I did a set of '68 charger seats from green to white, but I used stuff from an auto paint supply store. I think it was SEM. 1 qt. was plenty for front and back. Worked great. Washing with tri-sodium phosphate and water with a Scotch-Brite before painting works well. I tried the can stuff on a red carpet to black on a console for the same car and it sucked. Almost a whole can on just the console carpet pieces and it still looked a little red.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39676
05/14/07 10:54 AM
05/14/07 10:54 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I usd SEM to color most of my interior from blue to black and even colored a seat from white to black. This material looked very natural and held up great for several years. I am working on 7 years (40k miles) for the door panels, visor and dash pads but I have since put new covers on the seats.
Only one word or caution clean, clean and clean again. I used an amonia based cleaner and the SEM vinyl or platic prep (as appropriate). If you even see a hint of fish eying you have not cleaned enough. Stop wipe the stuff off and clean some more.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Dying vinyl seats and interior parts? [Re: dgc333] #39677
05/14/07 02:27 PM
05/14/07 02:27 PM
Tulsa, Oklahoma
Charger_440 Offline
Charger_440  Offline
Tulsa, Oklahoma
any pics of the died interiors done w/sim dye?
Re: Dying vinyl seats and interior parts? [Re: Charger_440] #39678
05/14/07 06:49 PM
05/14/07 06:49 PM
so cal,cali
calimoparguy Offline
so cal,cali
Ive dyed several cars that i have had and have found out the key to a good job is to make sure item to be dyed is to completely cleaned.I use a strong degreaser like super clean and hot water and a scotch brite to clean and make sure to let dry all the way before dyeing and parts turn out great...
Re: Dying vinyl seats and interior parts? [Re: calimoparguy] #39679
05/15/07 08:20 PM
05/15/07 08:20 PM
Indianapolis
Indianapolis
Thanks for all of the replies. Sounds like if prepped right, I should get some good results.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39680
05/17/07 10:49 AM
05/17/07 10:49 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Half the battle to a good/great paint job is in the prep work!!
Re: Dying vinyl seats and interior parts? [Re: stubbs300 ] #39681
05/17/07 02:46 PM
05/17/07 02:46 PM
Washington, PA.
69charger383 Offline
Washington, PA.
The SEM works great. Clean with soap & water REAL good, then dry REAL good, then use the SEM vinyl prep/cleaner before painting.
Re: Dying vinyl seats and interior parts? [Re: 69charger383] #39682
12/22/07 01:04 AM
12/22/07 01:04 AM
Indianapolis
Indianapolis
Getting ready to start on this project and just thought I'd bring it back up. Thanks.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39683
12/22/07 11:58 AM
12/22/07 11:58 AM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
Ditto on the cleaning tips. I did a white to black
dye job once w/o cleaning and it lifted and scratched. Green to black w/ proper cleaning should be great!
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39684
12/22/07 01:59 PM
12/22/07 01:59 PM
Home of the Dream Cruise
FPD031 Offline
FPD031  Offline
I can understand saving the cost of the seating material, but I would sure try to find 100 bones to replace the carpet.
Re: Dying vinyl seats and interior parts? [Re: FPD031] #39685
12/24/07 03:06 PM
12/24/07 03:06 PM
Indianapolis
Indianapolis
I spent $121.50 on new carpet (plus freight) two years ago and can't return it. That price was even the discounted Moparts group buy through Dante as well. If I can die it for 25 bucks and make it look right, that's about $100 bucks I save. If it won't work, I'll pony up the cash.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39686
05/14/08 01:19 PM
05/14/08 01:19 PM
Indianapolis
Indianapolis
OK. I stopped by the paint supply shop today and they had gloss black and satin black available in both spray cans and pints. I think I want to use the spray cans, but should I use gloss or satin? thanks.
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39687
05/14/08 03:46 PM
05/14/08 03:46 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
If you are looking at the SEM stuff the general consensus seems to be Landau Black. I just did all that research last week, and did my A-pillars and Kick panels yesterday.
Looks great - but then again its only a day old.
BTW - I ordered my SEM paint through sjdiscountools.com. About $9 a can IIRC. It shipped the next day after placing my order.
Re: Dying vinyl seats and interior parts? [Re: Gusteve] #39688
05/14/08 09:53 PM
05/14/08 09:53 PM
Indianapolis
Indianapolis
Ahh man, I just bought two cans of the Satin Black. And they're an hour south of where I live. maybe I can trade it here locally...
Re: Dying vinyl seats and interior parts? [Re: Waveraider] #39689
05/15/08 07:08 AM
05/15/08 07:08 AM
Flint, MI
Gusteve Offline
Gusteve  Offline
Flint, MI
As mentioned above - also be sure you get the prep stuff, too. Vinal Prep and Sand Free for the plastic.
BTW - the sjdiscounttools place that I bought from is in Ohio - so if you are in Indy that's one day shipping for UPS ground.
Re: Dying vinyl seats and interior parts? [Re: Gusteve] #39690
05/15/08 08:29 AM
05/15/08 08:29 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Lots of going from another color to black. How about going from black to white? I'd like to try it instead of getting the new crappy fitting E-body door panels. Does it cover good enough?
