melted piston crown. No nitrous... #387303
07/26/09 10:22 PM
07/26/09 10:22 PM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
What do you guys think would cause this?
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: melted piston crown. No nitrous... [Re: cudabin] #387304
07/26/09 10:29 PM
07/26/09 10:29 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Looks like the valve was hitting. then maybe detonation broke rings too lean??
Just a guess
Re: melted piston crown. No nitrous... [Re: Dodgem] #387305
07/26/09 10:30 PM
07/26/09 10:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Was the head gasket gone between the cylinders??
is that piston turned in the block??
Re: melted piston crown. No nitrous... [Re: Dodgem] #387306
07/26/09 10:32 PM
07/26/09 10:32 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
exhaust valve is hitting the piston
do you have a pic of the head
1.39 9.85 - 137 mph
Re: melted piston crown. No nitrous... [Re: cudabin] #387307
07/26/09 10:37 PM
07/26/09 10:37 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
cheap gas detonation
Re: melted piston crown. No nitrous... [Re: Dodgem] #387308
07/26/09 10:39 PM
07/26/09 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
About 90* turned..... looks like it was lean on the edge
Re: melted piston crown. No nitrous... [Re: Dodgem] #387309
07/26/09 10:43 PM
07/26/09 10:43 PM
yes, why is the piston turned sideways?
looks like an assembly error started the whole thing. did you check piston to valve clearance when you put it together?
how do the other pistons look, same problem?
Re: melted piston crown. No nitrous... [Re: MR_P_BODY] #387310
07/26/09 10:43 PM
07/26/09 10:43 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
yes that piston is turned and i see what look like 3 separate cracks running down the cylinder wall. looks like it is engine tear down to me. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: melted piston crown. No nitrous... [Re: MR_P_BODY] #387311
07/26/09 10:43 PM
07/26/09 10:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I thought it was a rare offset hemi
Re: melted piston crown. No nitrous... [Re: Dodgem] #387312
07/26/09 10:46 PM
07/26/09 10:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Good chance it's water damage then???
now a broken rod cap and or rod??
Re: melted piston crown. No nitrous... [Re: Dodgem] #387313
07/26/09 10:55 PM
07/26/09 10:55 PM
cudabin Offline OP
cudabin  Offline OP
My car sputtered off the line like the rev limiter was stuck on after i let go of the transbrake, and after 60 feet... Poof !
At least 5 bent valves, 1 broken pushrod and several badly bent.
Two connecting rods #3, and #4, completely broken off and melted looking. Thats how it was able to twist...Bottoms of those pistons broken from the carnage. And #4 piston having an area on the crown melted??? Timing chain is broken , 1 set of roller lifters stuck in the block.
Broke the block and even trashed my brand new Charlie's oil pan.
Keeps the ideas coming.
Piston to valve clearance was .060" which is close, but steel rods Eagle H beams.
Worked fine for 4 seasons but just put on a terminator Alcohol injection system and had 3 good runs, 2 runs w/ a little sputtering mixed in, then the last run.
Tune up was not lean.
Re: melted piston crown. No nitrous... [Re: cudabin] #387314
07/26/09 11:06 PM
07/26/09 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check the valve springs... you could have had a broke
spring causing the sputtering
Re: melted piston crown. No nitrous... [Re: cudabin] #387315
07/26/09 11:09 PM
07/26/09 11:09 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
I was going to ask if you were running alcohol but you answered that. although your tune-up may have been ok, i would lean towards a plugged nozzle in that cylinder. that will lift a ring land like that in a hurry.
Howard
Re: melted piston crown. No nitrous... [Re: mrsmallblock] #387316
07/27/09 08:10 AM
07/27/09 08:10 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hard to tell from the pix but looks like things got real hot, is half that cly wall blue?
Re: melted piston crown. No nitrous... [Re: emarine01] #387317
07/27/09 09:58 AM
07/27/09 09:58 AM
cudabin Offline OP
cudabin  Offline OP
I will check the nozzle right away. Good sugestion.
The problem was that the first pass on Alcohol was fine, 2nd sputtered off the launch, 3rd pass was fine.
Nest weekend , first pass was fine, 2nd sputterred and 3rd ... Poof!
Being so intermittent is what puzzles me???
I have about 5 bent valves, so they will all be checked including springs.
Would the melted crown happen after the carnage, or before ???
Thanks, Arnie
Re: melted piston crown. No nitrous... [Re: cudabin] #387318
07/27/09 10:10 AM
07/27/09 10:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks, Arnie
I have never seen a melt after breakage... you are
sure its a melt and not cracked off(from what I can
see in the pic it looks like its melted). Once it
started the failure that cyl basically quit working
Re: melted piston crown. No nitrous... [Re: MR_P_BODY] #387319
07/27/09 10:23 AM
07/27/09 10:23 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Can you post a pic of the spark plug from that cyl?
Re: melted piston crown. No nitrous... [Re: MR_P_BODY] #387320
07/27/09 10:31 AM
07/27/09 10:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My guess would be and I'm no expert!
My scenario the motor was leaning out bad. that would not only melt pistons but pound out the bearings and likely rod ends of the rods. this would allow the pistons enough free travel to hit the heads/valves and thus more vent valves. I'll bet the rod bearings are pounded out of it???
Dam that makes me feel bad to see that. bin there as many of us have. You just have to suck it up ad start moving on. I say you play hard you pay hard!!
Re: melted piston crown. No nitrous... [Re: Dodgem] #387321
07/27/09 10:34 AM
07/27/09 10:34 AM
Arnie,
Is that on the exhaust or intake? If your springs were weak ouch!....
Mike
Re: melted piston crown. No nitrous... #387322
07/27/09 10:50 AM
07/27/09 10:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking it all started with a spun rod bearing
then the piston hit the valve and then all he11 broke
loose.... just a guess.
