Hey Mike, The spings were good (new) Comp 996 1.625 diameter set up for 330# closed and 850 open. The .060" was intake, exhaust had a little more as less lift and more lash.
Yes i think it did spin a bearing first, because the broken pieces of the rod cap were nice and blue...
Piston is melted not broken.
Yes the spark plug from that cylinder is nice and silver... coated with piston.
The rest of the plugs looked fine, so i have to check the line, and nozzle to that cylinder.
Scored the cam on a few lobes and one set of lifters is stuck in the bore so will need replacing...
Pretty much a total loss except the head castings.
Oh well, I will be back bigger and faster in a few weeks.
Cheers,
Arnie
