Page 3 of 6 1 2 3 4 5 6
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385964
07/27/09 09:23 PM
07/27/09 09:23 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
The 72 engine appears to be missing the idle solenoid.
Re: Detailed stock 71 340 engine pics needed [Re: Steve340] #385965
07/27/09 11:19 PM
07/27/09 11:19 PM
New Jersey Bada Bing
bremotorsports Offline
I love it when we talk small blocks.
Here are some tidbits from the engine belonging my own 71 340 Cuda convertible. One-owner car, and I am second titled owner. I have conversed with him numerous times. Carb replaced, distributor replaced, radiator hoses replaced, but otherwise never apart. Vehicle build date 3/31/71. To date, in discssions with other owners, the closest I have come to the color changeover date is 3/17/71, at least for Hamtramck cars. All blue engines I have seen have paint on the wire looms (versus no wire loom paint on the orange engines), and also do NOT have the wiring harness trough on the passenger side valve cover. Both of these observations MAY ALSO play into Windsor built engines (GW) versus Mound Road built engines (GM) as stamped on the front of the block.
First up:
Engine color dipstick tube.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385966
07/27/09 11:20 PM
07/27/09 11:20 PM
V.I.N.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385967
07/27/09 11:21 PM
07/27/09 11:21 PM
Dipstick handle:
Black
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385968
07/27/09 11:22 PM
07/27/09 11:22 PM
Standard filter attachment (no right angle adapter).
Nice and clean inside!
Notice some original blue paint residue just inboard of the filter gasket mating surface.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385969
07/27/09 11:24 PM
07/27/09 11:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Bill your dipstick is black right?
*Edit, I see you said it was, ok.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385970
07/27/09 11:24 PM
07/27/09 11:24 PM
Wire loom.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385971
07/27/09 11:26 PM
07/27/09 11:26 PM
Block casting.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385972
07/27/09 11:26 PM
07/27/09 11:26 PM
Manifold casting.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385973
07/27/09 11:27 PM
07/27/09 11:27 PM
Valve cover bolts.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385974
07/27/09 11:28 PM
07/27/09 11:28 PM
Intake manifold bolts.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385975
07/27/09 11:29 PM
07/27/09 11:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bill, looks like you have the later style intake, correct?
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385976
07/27/09 11:29 PM
07/27/09 11:29 PM
Front coil bolt. Original finish yellow zinc.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385977
07/27/09 11:30 PM
07/27/09 11:30 PM
Rear coil bolt. Original finish black phosphate.
"Lightning strike" style, plus marks at 9, 12 and 3.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385978
07/27/09 11:33 PM
07/27/09 11:33 PM
Carb bolts.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385979
07/27/09 11:33 PM
07/27/09 11:33 PM
Thermostat housing.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385980
07/27/09 11:34 PM
07/27/09 11:34 PM
Heater hose bracket bolt.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385981
07/27/09 11:36 PM
07/27/09 11:36 PM
Linkage #1
Springs are replacements, but correct colors.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385982
07/27/09 11:36 PM
07/27/09 11:36 PM
Linkage #2
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385983
07/27/09 11:37 PM
07/27/09 11:37 PM
Exhaust manifold.
