Re: Update on the street/strip project aka "Black Pig"
[Re: firefighter3931]
#385833
07/25/09 09:56 PM
07/25/09 09:56 PM
Posts: 2,567 Appalachia
RedRam
Appalachia
...It's been a long haul and waaay more work and $$ than i had originally planned...
story of my life Congrats on a beautiful ride
Re: Update on the street/strip project "Black Pig" project
#385834
07/25/09 10:02 PM
07/25/09 10:02 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
What's the induction set-up? Holley Street Dominator,and an AED carb? Need a couple things done to the X if I wanna come play in Norwalk! Hopefully,I'll have the car with me,but I will be there! Randy
Randy, the intake is a Holley SD and the carb is an AED 850 courtesy of my good friend Kam Kuda....Thanks Rob
You need to get the GTX and yourself ready for Norwalk.
Ron
[Re: Chris2581]
#385837
07/25/09 10:14 PM
07/25/09 10:14 PM
firefighter3931
Ontario,Canada
Engine pic....basic pump gas 446 by Porter Racing Heads. It made 535hp on Dwayne's dyno....runs great on UL 93. Ron
Details of engine and driveline combo??
LOOKS GREAT!!
Thanks Chris
Basic 446 with stock crank & rods balanced and zero decked with 2355 6-pack slugs. Stage 1 ported E-heads by Dwayne (300 cfm @.0600) Harland Sharp rollers, custom PRH solid flat tappet grind (.580 lift/264@.050) recurved MP distributor, Firecore 8.5mm wires, blaster SS coil and 6AL box, 2in TTI's 3.5 > 3in Dr Gas x-pipe, full 3in exhaust with Ultraflows.
Trans has all the good stuff ; billet steel drum, billet servos, billet accumulator, TA valvebody, bolt in sprag, HD band strut etc...Dynamic 9.5 converter
SS springs, CE shocks and 4.10 Dana 60 by Dr Diff. 295/65/15 Drag radials, SS brakes front disc conversion, Poly front end rebuild, frame connectors and 8pt bar...
Full stock interior with heater box as well...
Ron
[Re: 69CHARGERMD]
#385838
07/25/09 10:16 PM
07/25/09 10:16 PM
firefighter3931
Ontario,Canada
Looks great Ron,,,,,Love that Black Pig
Red stripe really set's it off,,,cant wait to see it.
by the way,,,,he just finished a case of Keiths'
LMAO....too funny !
[Re: MR_P_BODY]
#385839
07/25/09 10:18 PM
07/25/09 10:18 PM
firefighter3931
Ontario,Canada
Ron it looks great
Thanks Mr P.....i haven't forgotten your request for a 24 of Brador. See ya at Norwalk !
Nice work on your new shop, BTW
#385842
07/26/09 07:37 AM
07/26/09 07:37 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
It's been awhile since i posted anything so here are a few pics of the completed project. It's been a long haul and waaay more work and $$ than i had originally planned.
Looks like i'll finally have my car at Norwalk this fall to make some passes. Looking forward to lining up against Randy (Lab Rat) for a little head to head action.
Ron
looks great,GOOD LUCK your going to have your hands full goin up against that green GTX heads up.
[Re: Old School]
#385843
07/26/09 08:08 AM
07/26/09 08:08 AM
firefighter3931
Ontario,Canada
awesome looking car ron! i have a 68 also,love em.is this the car that you are building the BIG motor for? ooops did i just let the cat out of the bag.......
Hi Brian, yes....this is the car that the Big Engine is being built for. All the parts are at Dwayne's shop so when he has time it can go together. Dyno numbers will be posted at a later date. It's going to be a pump gas 572 and fit under the stock hood.
Lots of stuff will need upgrading....fuel system, Cal-tracs, shocks, driveshaft, torque converter, locker for the D60 etc....They're never completely finished, are they ?
Ron
[Re: bonefish]
#385844
07/26/09 08:12 AM
07/26/09 08:12 AM
firefighter3931
Ontario,Canada
Ron
Yep, the Green GTX runs awesome ....i'll be happy to stay close to Randy.
Ron
