Nitromethane
#384303
07/23/09 02:55 PM
07/23/09 02:55 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
What do you think of this guys !? Really works !? Dangerous !?
Sorry, had to translate it on Google...
"The nitromethane is applied as combustible in race cars, rockets and aircrafts. The oxygen contained in the nitromethane allows a lesser air burning (oxygen) atmospheric in comparison with other hydrocarbons with the gasoline. To burn 1 kg of gasoline 14.6 kg of air (oxygen) are necessary, 1 kg of nitromethane need only 1.7 kg, a time that each cycle of the engine can contain only one limited amount of air, can burn 8.7 times nitromethane than the gasoline (the level of the sea).
However, the set free energy for the nitromethane is lesser, while the burning of the gasoline liberates between 42 and 44 million Joules for kilo (MJ/kg), the nitromethane liberates 11.3 MJ/kg. From these data, one concludes that the nitromethane generates 2.3 times approximately more than the power of the gasoline when combined in the certain ratio with atmospheric air. The nitromethane (CH3NO2) is miscible in alcohol, methanol, that are methylic alcohol, gasoline, among others, being usually combined with the two first ones. In general 10% are applied in 5% mixtures, for engines of high tax of compression or with turbo, and of up to 40% for engines of low tax of compression and natural aspiration. Had to the power increase, it is recommended reinforcement in the engine to prevent reduction of the useful life. The profit of power with the nitromethane happens of the presence of oxygen in its molecule, causing a effect of similar overfeeding to the one of nitrous oxide (NO2).
This oxygen is used in the fuel burning, allowing the injection of bigger amount of fuel.
Part of the molecule (CH3) also is combustible and the N does not participate of the burning, forming N2.
The profit in the use of the nitromethane is not accurately for increase of the calorific power, but for allowing the injection of more combustible for one same air mass, since it loads part of the oxygen for the burning in its proper molecule.
Mixtures with alcohol, methanol and nitromethane attack components not proteges, as injector peaks and other parts citizens the corrosion. This to a large extent happens for these fuels to contain oxygen in its molecules. Alcohol and methanol, in turn, increase the antiknock index (IAD), that it indicates the trend to the detonation of the fuel, in the direct ratio of the mixture. The gasoline they mixed gain octanagem.
The components of the engine and its regulation must be adjusted for the use of the new mixture when this will be being used.
The literature found in the site is only for informal consultation, the Nitrometano ProŽ Magma is vendido for fuel purpose, as additive, we do not make responsible in them for no damage or bad use of the product. Before preparing its fuel a specialist always consults, takes all the necessary precautions for the manuscript."
Re: Nitromethane
[Re: HemiGreg]
#384305
07/23/09 04:06 PM
07/23/09 04:06 PM
Posts: 8,165 Left Coast
BobR
Left Coast
uh yea!! why do you think they have Nitro funny cars making 4000 hp. tuning got to be special for it
Actually nitro burning top fuel and funny cars have something north of 6000 horsepower. It does not mix well with gasoline and you had better know what you are doing or you will ruin a lot of stuff finding out.
Post deleted by Defbob
[Re: BobR]
#384306
07/23/09 04:17 PM
07/23/09 04:17 PM
Re: Nitromethane
#384307
07/23/09 04:26 PM
07/23/09 04:26 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I agree Nitro explodes.My buddy had a nitro Harley drag bike.You should ask him about the 15K motor that was brand new.Fired and stalled.Didnt clear the cylinders and cranked it.One guy was almost killed by a big chunk of the motor that flew by his head and embedded in the wall.Rocky
Chrysler Firepower
[Re: emarine01]
#384309
07/23/09 04:30 PM
07/23/09 04:30 PM
Re: Nitromethane
#384310
07/23/09 05:30 PM
07/23/09 05:30 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
its a lot of fun... and i miss it..
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
Re: Nitromethane
[Re: kissmyaspen]
#384313
07/23/09 06:34 PM
07/23/09 06:34 PM
BobR
Left Coast
Get yourself a Procharged Outlaw 10.5 car and dig right in.
[Re: RAT PATROL]
#384315
07/24/09 10:14 AM
07/24/09 10:14 AM
Re: Nitromethane
[Re: dart_73_br]
#384317
07/24/09 04:25 PM
07/24/09 04:25 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
yep. it is a learning curve...
one of my first mistakes was to assume the percentage when at a race. weather moved i n (front) dropping temps enough that i lost around 4 full percentage points on the load.
made a differance that could be heard and felt when the bike was running...learned the hard way as i lost that round.
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: dart_73_br]
#384319
07/24/09 08:16 PM
07/24/09 08:16 PM
Re: Nitromethane
#384320
07/25/09 01:13 AM
07/25/09 01:13 AM
gremlinsteve
houston texas
yea. you need to get the specific gravities and the equipment to measure it. the percentage will always change. hence the need to measure and mix just before the pour
steve
Re: Nitromethane
[Re: gremlinsteve]
#384321
07/25/09 06:11 AM
07/25/09 06:11 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I've always wanted to play w/ nitromethane but never had the $$$.
I'd wanted to play w/ hydrazine. Until I did some research about how dangerous it is - just to handle and store. That's before you even get it in the car.
It makes that hexavalent chromium from Erin Brockovich look like vitamin water or something.
(gotta' watch that movie again... Julia Roberts... mmmm...)
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
