Re: Indy 295's EZ VS Indy SR 295's [Re: DJVCuda] #383325
07/23/09 11:26 PM
07/23/09 11:26 PM
Chicagoland
chargerron69 Offline
Chicagoland
i thought they came out with the EZs to make it easier to fit headers for rb abody guys
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Indy 295's EZ VS Indy SR 295's [Re: moparniac] #383326
07/24/09 08:16 AM
07/24/09 08:16 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'll post pics tomorrow.... Still trying to figure out how to get the 2 1/8 th tti/proparts headers on lol!
Then they probably fit SR or 440-1 and they fit good.
Re: Indy 295's EZ VS Indy SR 295's [Re: chargerron69] #383327
07/24/09 08:28 AM
07/24/09 08:28 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Yes they did - so you can use a regular set of headers, but that compromise was in the exhaust port. - the intake and chamber of the heads are the same...
Re: Indy 295's EZ VS Indy SR 295's [Re: moparniac] #383328
07/24/09 08:54 AM
07/24/09 08:54 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I love the bottom end torque of my 295 lil ez's because my car is so heavy and driven on the street,but when I freshen up my motor this winter I may upgrade to -1's,a different cam and a block girdle.
your still running a stock block
Yep, "knocking on wood". The 500 cubic inch "400" is about the lightest big block Chrysler piston/rod combo out there because the piston is so short. But I am adding a girdle this winter.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Indy 295's EZ VS Indy SR 295's [Re: DJVCuda] #383329
07/24/09 01:30 PM
07/24/09 01:30 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Both have the same intake port and chamber, the only difference is the lower exhaust port on the EZ's so you can run a stock header...Thats where the SR will make more power, with its improved , and raised exhaust port...
This is what I was refering to, from a story by Steve Dulcich:
"The 440-EZ series is based upon the popular Indy SR series of heads, but with casting revisions to the intake, and a relocated exhaust port, putting the exhaust back to the stock location from the raised SR position."
Re: Indy 295's EZ VS Indy SR 295's [Re: B1Fish540] #383330
07/24/09 02:13 PM
07/24/09 02:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
When the EZs came out, they had a different "as cast" intake port than the "as cast" SR, along w/ the lower exhaust port. I haven't seen an SR in years to know if ICH ended up changing the unported SRs to have the same intake runner as the EZ. The 295 CNC ports for both castings are the same.
Re: Indy 295's EZ VS Indy SR 295's [Re: BradH] #383331
07/24/09 02:57 PM
07/24/09 02:57 PM
AndyF Offline
AndyF  Offline
From what I've seen and heard the port designs on the Indy heads have changed a few times over the years. The head porters that I talk to all seem to really like the current "CNC ready" ports.
As far as the EZ vs. SR discussion goes I'll just repeat what I've said a lot of times before: The EZ head is capable of over 800 hp so there isn't any reason to make extra work for yourself in the exhaust department unless you're shooting for more than that.
Re: Indy 295's EZ VS Indy SR 295's [Re: AndyF] #383332
07/24/09 07:35 PM
07/24/09 07:35 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I concur.... Exhaust port flow is way overrated for making power. Intake port & chamber is where the power is made, as long as exhaust port size & flow is "adequate" you can make alot of power. I've made over 800 HP with a NA SB with a 1.60" valve, port flowing 250 cfm... So.... when I hear people claiming these 1.81" valve 245-255 cfm EZ exhaust ports are a real crutch I just kind of laugh.
I just finished up my hand work on set of EZ-1's for my 448 on Wednesday & was extremely pleased with the flow results for very little amount of work.
My intake ports ended up at 286 CC with a Ferrea 6000 valve. My VJ with 33* back cut, all work done shooting for low/mid lift flow since going on small cam motor..... 233 @ .300", 326 @ .500", 353 @ .700". Heads really work well, for head with very little effort put into them, that was pretty much a bowl blend, blend CNC MW entrance into runners & full chamber work. On my bench I've had two sets of 2.19" MCH CNC E heads, both flowed identical (as they should) ~285 @ .500", peak 324 @ .700" just for something to compare to off same bench.
Exhaust went 254 @ .700" with no tube, All just seat & short turn work (about 7-8 minutes per port), I did not enlarge runner/exit size at all. The ability to use my current non SR Heddman headers is big benefit to me...
