Re: Door latch finish [Re: 1_WILD_RT] #383230
07/26/09 02:25 AM
07/26/09 02:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
70 you can't lock the latch when the door is open, 71 & up you can...
Do they look different when installed?
Can they be interchanged or are some of the rod mechanisms different?
Anyone have a picture 70 E-body latch next to a 71 E-body latch for comparision?
Re: Door latch finish [Re: autoxcuda] #383231
07/26/09 02:33 AM
07/26/09 02:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The variation is very minor & you can't see it when the latch is bolted in, the only way you'll know is if you try to lock the inside lock with the door open... On a 70 you can bend the interlock tab & it will act liike a 71...
Re: Door latch finish [Re: 1_WILD_RT] #383232
07/26/09 02:42 AM
07/26/09 02:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So the entire latch mechanisms will interchange by bolting-in and attach to the rods the same? And you can 100% not see the difference when installed?
Re: Door latch finish [Re: autoxcuda] #383233
07/26/09 03:07 AM
07/26/09 03:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Exactly..
Re: Door latch finish [Re: 1_WILD_RT] #383234
07/27/09 06:20 PM
07/27/09 06:20 PM
cataclysm80 Offline
cataclysm80  Offline
but you would notice it after you put it on the car, got out, and tried to lock the door.
Tav
