70 Challenger Tail Lamp house finish? Studs? Nuts?
#382417
07/21/09 08:02 PM
07/21/09 08:02 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
It looks to be some type of natural finish but does not look good when old. Whats the best way to get them looking new again? Is there some way to get them looking as new? On the chrome bezal I lost/missplaced all the studs that were in them so now need new ones. Is there a source for them or is it just make your own from threaded rods? What Nuts are the right ones to hold them on? I did find the good used lens I have had for ever in a box wraped in news paper and guess what...Ford Escorts are on sale at the local dealer ship Maybe I have been working on the car to long
Re: 70 Challenger Tail Lamp house finish? Studs? Nuts?
[Re: burdar]
#382421
07/24/09 09:02 AM
07/24/09 09:02 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I had a thread about this a while back. The suggestion was to lightly bead blast the housings to renew the look. I have not done that so I can't comment on the outcome but maybe someone who did it can.
Joe
65 Barracuda 70 Challenger
[Re: burdar]
#382422
07/28/09 06:15 PM
07/28/09 06:15 PM
Posts: 4,165 Florida
cataclysm80
The Zinc Dichromate dulls over time and turns a gray color correct?
Dulls or wears off, I'm not sure which.
Tav
[Re: jrwoodjoe]
#382423
07/28/09 06:18 PM
07/28/09 06:18 PM
cataclysm80
Joe
I haven't tried that either. I think the bead blasting would do a pretty good job at cleaning them up, but seriously doubt it would restore the original plated finish.
I'm not sure how it would turn out, but I think eastwood sells a carburetor paint. I'm thinking Challenger front turn signals should use the same coating. Not sure about the marker light backing plates.
If you're WAY into details, many original housings have black overspray in spots from when they were mounted to a fixture and painted .
Tav
[Re: JulesdaWiperman]
#382429
07/29/09 02:19 PM
07/29/09 02:19 PM
340SIX
To date I have never seen one 70-71 challenger tail light housing with zinc dichromate on them and I have seen loads of them. Very lightly bead blast them with fine grade bead. They will come out like new. If you go gently enough you will be able to keep the wave patterns in the metal when they were cast. The inside coves are painted silver and not very bright at that. Jules
Thanks the Wave Pattern is what makes me think it was some type of plating. I had tried on one spot on one part to buff it with gray emery years ago on one and it looked to take the wave look away Kinda like Galvanised pattern would look but goldish in color. I am now going threw parts that I never finished and finding things I skiped since I could not do them right.
[Re: 340SIX]
#382430
07/29/09 06:08 PM
07/29/09 06:08 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Thanks the Wave Pattern is what makes me think it was some type of plating. I had tried on one smaller parts to buff it with gray emery years ago on one and it looked to take the wave look away Kinda like Galvanised pattern would loo but goldish in color. I am now going threw parts that I never finished and finding things I skiped since I could not do them right.
Sounds like someone just described zinc dichromate....
