Re: Superbird Nose Cones
[Re: mopar4ya]
#381602
07/21/09 09:34 PM
07/21/09 09:34 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
There was these valance pieces that were suspected as repo /or original .When they were on ebay Re: Original Daytona parts on ebay « Reply #19 on: January 28, 2009, 11:54:53 AM » Quote Modify -------------------------------------------------------------------------------- That was my original thought prototype or pre production pieces.I knew they were not superbird as they appeared .As to the contour and surface area Quote from: nascarxx29 on December 29, 2008, 08:03:55 AM JohnTPR forwarded this to me . I thought that they were salvaged from a damaged whole valance.Or maybe old templates used from past engineering vendor?? Parts are in MI Quote from: nascarxx29 on December 29, 2008, 12:09:27 PM Early prototypes? With no sidemarker cuts .The earliest daytona had stick on reflectors and taped headlight door openings.Wish the guy furnished more info in the description other than they sat on the shelves for years http://cgi.ebay.com/ebaymotors/1969-dodg...1QQcmdZViewItem Re: Original Daytona parts on ebay « Reply #18 on: January 28, 2009, 11:47:46 AM » Quote -------------------------------------------------------------------------------- The guy that bought those valance halves called me about a week ago, and we had a long chat. He and I came to the conclusion that they MIGHT be race Daytona parts. More specifically, we thought that was the most likely of the possibilities due to the missing marker light recesses. There's a very slight possibility that it was a pre-production mockup piece, since I have pictures of a prototype/mockup car which has no marker lights on its valance. From what he was saying, this does not appear to be a reproduction part, due to how it was stamped/formed. The weird part is that the valance is in two pieces. He was going to look closer at the joint between the two pieces, and also take a closer look at the gauge and type of metal itself. I was thinking that a guy like Greg Kwiatkowski, who is (re-)building the actual #88 Daytona, could make good use of these. Steve, the guy that bought the parts through eBay, was debating about adding the marker light recess and using them on a real Daytona. Either way, the valance was not made to go on a regular "street" Daytona - but that does not necessarily mean it's a reproduction.
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: Aero426]
#381603
07/21/09 09:37 PM
07/21/09 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I think I going to start documenting a photo journal dedicated to "Reject NOS wingcar" stuff,....I'll start with one of my 1969 NOS Daytona fenders, passenger side I have, that has a stamped depression for a 70 marker light, but was never cut out
That fender is very likely a race part. I've seen a Daytona nose with stamped outlines for the headlights that remained unopened. That nose came direct from Don White's shop so it's pretty clear why it was that way. I would hesitate to label that nose as a reject. It just is what it is and was not intended for a street car.
I've seen, and had my share of the Wingcar "race" parts Doug, usually the skins, are just that "skins"....no inner stuctures/braces/plates/etc what so-ever, as they didn't need it,....I have 5 NOS Daytona fenders, they are pretty much fully structured bolt on pcs,....not race pcs,.....just that some have various qwerks in their completeness, and or conversion
[Re: mopar4ya]
#381604
07/21/09 09:50 PM
07/21/09 09:50 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Something else I have noticed over the years. Why are some NOS cones gray and others red in primer Were there different venders making these, or just used what ever primer was on sale that week?
Thanks Dan
In the winger world, anything is possible ,.....but generally with NOS sheetmetal, any Chrysler stock, not necessarly wingcar stuff, red primered parts are much later down the timeline of production/supply.......I generally find Gray primered, or bare(rust) NOS wingar parts as being early releases for production/supply,......I've seen a few red primered pcs over the years,....I've seen one SB NOS cone, that was brushed in red primer?.......the owner claimed he purchased it from a closing dealer as it was?
[Re: Aero426]
#381605
07/21/09 10:19 PM
07/21/09 10:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Please note that the NOS grille frame sits in the NOS nose opening like it is supposed to.
That's .......A matched set, should have no issuses there, just FYI, about 2 or more years ago when I discussed SB grille frames with Jack McGaughey, as he was contemplating making them, and I was already tooling for them, we discussed the problems with forming them, requirements, etc.....Jack wasn't surprised, just amazed at the variations in measurements from the more than several originals he had on hand, plus others he had measured when he had access to them,......he was curious on how I arrive at a "finished", or finialized deminsion to begin tooling for a part,.....and it's like I mentioned in an earlier post,.....you choose the median of all recorded deminsions you have access to, used or NOS
I remember a decade or more back when I tooled up for Daytona grille frames, I made the mistake of using an NOS grille frame, that I borrowed, the first half dozen grille frames went in the trash heap, along with the prints and tooling, because they didn't fit any nose,original or rebop, they were to short in coverage by 1/4" top to bottom, luckly I didn't release any out at the time!,.......I always made it a habit of test fitting parts, before produceing them, but I too fall victim of assumeing NOS parts fit, because their NOS,....Most of the time they do, but.....you never know until your assembling the entire assy, if it's going to have issuses?
[Re: xs29j8]
#381606
07/21/09 10:37 PM
07/21/09 10:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
When I talked to Gean Gregory at Monster Mopar last year, he said that there were differences in the recessed flange that mounts the grille frame... I do not recall what the differences were... Anyone know what they are?
XS
Perhaps Gene was talking about Superbird grille openings,....Daytonas are pretty much consistant (which is surpriseing!),.....over the decades of templateing/measuring/and taking molds off nosecones,.....the Superbirds are perhaps the worst for having a consistant opening,.......I've probally made/sold easly (lost count) over a hundred steel Daytona grille frame/screen assemblies, and never one complaint or issuse of fit,.....the superbirds on the other hand, even after determining a "median" tooling demension, I have some customers who claim it's too tight, or too loose in their grille opening,.....so the last few SB repro grille frames have been made with the customers suppling their grille openings measuement,.....and they vary greatly, not only in height and width, but side to side, across, or up or down! measurement wise,..........one of the reasons I dread tooling for the SB directional frames that complement the grille,....I've had access to a few NOS pcs, and a few original sets, and their all over the place shape wise and measurement wise and unlike my SB grille tooling, would leave me little room to adjust to desired customer specs, if and when I decide to release them
[Re: DAYCLONA]
#381607
07/21/09 10:59 PM
07/21/09 10:59 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
Just to be clear, that Bird grille frame is a random sample I grabbed to a random nose. It's a matched set now, but it sure wasn't earlier this evening. Taking a quick measurement, the NOS nose width at the fender peaks matches the nose on my Bird very closely. As close as I can measure it by myself, it's dead on.
[Re: mopar4ya]
#381608
07/21/09 11:03 PM
07/21/09 11:03 PM
Aero426
Wisconsin
Thanks Dan
All of mine have been bare steel in cosmolene. I also have a Bird hood and 70 RR decklid that were delivered in bare steel with no protection.
[Re: Aero426]
#381609
07/22/09 06:06 AM
07/22/09 06:06 AM
WINGCARS_6970
TX , NJ , FL
This statement made by superbirdtom .I what I refered to early on .You had to remove a bracket .From old nose to N.O.S. one replacing it
superbirdtom Full Member
Offline
Re: N.O.S. Superbird Nose Cone Tech VS/ Repos « Reply #1 on: Yesterday at 11:06:07 PM » Quote
-------------------------------------------------------------------------------- just to add to all the previous well coverd posts. I believe the difference is that the replacement cones if you ordered one from the dealer back in the day they didn't come with the piece that mmounts the top side of the cone to the rad support. you had to take it off the damaged one ant reweld it onto the replacement one.
And I believe that the ones that came on the cars delivered some had wiring holders that are tacked to the interior of the cone to hold the hoses and h-light wires . I believe i have seen them with and without them as a difference between stock and repop. the steel repops look damn good in my opinion.
[Re: WINGCARS_6970]
#381610
07/23/09 12:02 PM
07/23/09 12:02 PM
WINGCARS_6970
TX , NJ , FL
Re: N.O.S. Superbird Nose Cone Tech VS/ Repos « Reply #5 on: Today at 07:48:46 AM » Quote Mopar John [Here is a picture of my NOS Superbird nosecone. It is missing the closure panel. While I'm on this topic I would like to add my thoughts on the NOS vs REPRO debate. If you have a quality original car NOS is the way to go. If your building a clone thats where the repro parts belong. There are more clones going together than originals being restored and if they use up the rare parts on the clones it's sad. When you use NOS parts on your restoration be sure to include pictures of the parts with the box or label and as they are installed on the car. Also keep your receipts. Later if you decide to sell and you can prove you used NOS vs repro it will make a big differance even though it doesn't look much differant.
[Re: WINGCARS_6970]
#381611
07/23/09 12:13 PM
07/23/09 12:13 PM
WINGCARS_6970
TX , NJ , FL
So if you have a beyond salvage nose cone and you dont have that piece to transfer over.That I refered to earlier .As in the picture .That might or might not be on your NOS nose.What do you do??
[Re: WINGCARS_6970]
#381612
07/23/09 12:44 PM
07/23/09 12:44 PM
Aero426
Wisconsin
You make the piece on a sheet metal brake or buy one from Jack or Gean. That's the easy part.
[Re: Aero426]
#381613
07/23/09 01:46 PM
07/23/09 01:46 PM
WINGCARS_6970
TX , NJ , FL
Guess thats all you can do .Unless the metal nosecone vendors being as nose is made up in sections .Sell you that individual piece you need.Or any other section you might need
