Re: 70 E body AC vacuum grommet Which Way?
[Re: BartekP]
#380255
11/22/09 09:21 PM
11/22/09 09:21 PM
Posts: 4,165 Florida
cataclysm80
Where should I plug vacuum hose that goes through that grommet? Inside the car it goes to A/C box, but where is the vacuum supplied in the engine bay?
Good to see some action on this thread again!
There should be a vacuum port on your intake manifold. It is a threaded hole on the intake manifold and there are different plugs that screw into it depending on what options your car has. There is a plug with no vacuum nipple for manual brake non AC cars. There is a plug with a big vacuum nipple for power brake non AC cars. There is a plug with a big & a small vacuum nipple for power brake with AC cars. There is a plug with a big & 2 small vacuum nipples for power brake with AC & something else I'm not sure of. (the second small nipple isn't for cruise control, because that hooks to the brake booster check valve)
There may be other plugs also. There's probably one with only a small vacuum nipple for manual brake AC cars, etc.
distributor vacuum advance & PCV both go to the carb.
Anybody find out any more info about the different temperature cables?
Tav
[Re: cataclysm80]
#380256
11/23/09 06:47 AM
11/23/09 06:47 AM
Posts: 434 sweden
cuda-sweden
sweden
Tav
no,but what about this one. ive got the early? style of routing on my -70 cuda,where the temp-cable goes in to the coupe through the grommet with 2 holes,located under the blower motor.question= on my grommet with 2 holes,one of the holes has an outsticking(a couple og mm)piece molded in,its like a bit of a hose.so im wondering if that hole is for the temp-cable? or the vaccum hose?
[Re: cataclysm80]
#380258
11/24/09 02:07 AM
11/24/09 02:07 AM
Posts: 36 Poland
BartekP
Poland
Grommet in my car (1970 318 A/C) was mounted from inside - looking on a dirt, there was no cable when I bought the car but that grommet doesn't look like cable went through it, second opening in rubber nipple is quite tight
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: cuda-sweden]
#380260
11/28/09 05:33 PM
11/28/09 05:33 PM
Posts: 36 Poland
BartekP
Poland
I mount the firewall insulation pads and I noticed that my temp cable is routed through wrong hole, on the picture no1 are insulation clip holes, where should go temp cable? and what are holes 2,3,4 for?
washer foot pump & hoses?
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: cataclysm80]
#380262
11/28/09 08:09 PM
11/28/09 08:09 PM
Posts: 36 Poland
BartekP
Poland
thanks It had manual washer pump
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
